usb problem.
By TimboCummins · Jun 19, 2009in Problems/Troubleshooting💬 14 posts👁️ 1,397 views
Posted Jun 19, 2009 · 01:45 UTC#1
Just purchased the CD-UB100 USB adapter. The unit will only detect the USB thumb drive if I disconnect and reconnect the ip out cable. This has to be accomplished each time the USB thumb drive is reconnected. Works 0% of the time if you just insert the thumb drive and works 100% of the time if you disconnect and reconnect the ip cable.
I have reset the unit several times. I have replaced the unit and all wiring with another unit. I have directly connected the thumb drive to the CD-UB100, the results are the same. I have varied the CD-UB100’s position in the daisy chain and no change. Any ideas. Tried searching long enough. Thanks
http://dodgetruckworld.tenmagazines.com/gallery/Timbocummins/396297.jpg
http://dodgetruckworld.tenmagazines.com/gallery/Timbocummins/396302.jpg
Posted Jun 19, 2009 · 07:27 UTC#2
Have you tried switching the source on the Z unit? That's a dumb question to ask, I know... but it's the only thing I can think of. :(
Posted Jun 19, 2009 · 09:30 UTC#3
maybe this could be the solution , i had the same problem connecting a hard drive to the F900
viewtopic.php?f=34&t=24960
Posted Jun 19, 2009 · 13:43 UTC#4
The USB is currently recognized as ext1. How do I change that to another source?
Thanks for the response
Posted Jun 19, 2009 · 17:42 UTC#5
I'm sorry I was pretty vague... I meant actually going into the Z interface and chooing the flash drive through there (like pressing AUX1 or EXT1, whatever it is) I was thinking maybe that would make it work somehow. I honestly have never hooked anything up to USB on my Z so I dunno for sure.
Posted Jun 19, 2009 · 19:11 UTC#6
Thanks however I have tired every setting there is. Nothing seems to work except unplugging the ip connector or resetting each time a different or the same thumb drive is inserted.
Posted Jun 19, 2009 · 23:47 UTC#7
What kind of thumbdrive? Which file system is it running? Are you using proprietary software to add files to it or just drag/drop?
Posted Jun 19, 2009 · 23:56 UTC#8
I have tried several thumb drives and get the same result; I have formatted all drives with fat32. I just drag and drop to add the files.
Thank you for your response.
Posted Jun 20, 2009 · 02:30 UTC#9
Which Avic? Z1, 2 or 3? Native or upgrade?
Posted Jun 20, 2009 · 17:16 UTC#10
avic z1 was recent rebuild under warrenty
Posted Jun 20, 2009 · 17:20 UTC#11
Hmmmm :?: No clue. Maybe you have a bad CD-UB100? You might want to try doing the available software upgrade to your unit...at least to the Z2 software and see if that fixes it. Also, return the CD-UB100 and get a new one.
Posted Jun 20, 2009 · 17:50 UTC#12
the unit has already been returned and the new one does the same thing.
scared to death to try an update, I will live with the current situation. I just keep the entire usb unit in my glove box and reconnect the ip cable when switching drives. Thanks for all the input
Posted Jun 20, 2009 · 21:34 UTC#13
Everything is better after an update :D
Posted Jun 24, 2009 · 00:18 UTC#14
If you say everything is better after an update then maybe I should do it. I am just so happy with the unit as is and willing to live with this usb problem. I have had problems with updates with other equipment in the past but if you say it should go well then I will give it thought. I guess you are talking about the z3 update, will this erase my stored music?
