After walking through all the steps, everything looks to be ok but the system constantly reboots every 5 minutes. I hear the new button sounds, and can check the system info and it shows I am running 3.0 firmware. But the "System Startup" message never goes away, and the whole unit reboots after 5 minutes.
I am thinking it is the WinCE update. When booting into testmode, and checking the WinCE version, it shows that it is 5.0. I thought I read here (somewhere??) that it should be 6.x. I grabbed all the files from page one in this thread, and didn't get any errors at any stage. I am running a F900BT. Any help would be much appriciated!
That happened to me when I used the hacked ezrider. Try using the ezrider that comes with the download.
Not using the hacked EZrider, just the stock one from the download.
To be clear, I followed the instructions here exactly as listed. After everything comes up, the unit reboots after 5 minutes. I've tried updated to 3.1, and the update went fine...but still get a reboot after 5 minutes.
I went ahead and restored my backup, and verified everything is fine with 2.0 software. I then walked through the steps here again to update to 3.0, and I get the same thing.
Not sure why it isn't working for me, when others have no issues (and no, i'm not a dumb noob...i'm a CS major and have mod'ed most of the equipment I own). crilleym, you mentioned this happened to you initially. What exactly did you do to correct it? What EZrider file did you copy to repalce on your unit?
