Complete 3.0 Install Guide
By Retell · Jul 18, 2009in Hacks/Mods💬 968 posts👁️ 380,894 views
Page 27 of 39
Posted Feb 02, 2010 · 16:08 UTC#651
Well it looks like DropBox has killed my public shared files:( I guess you guys were eating up their bandwidth, haha...
here is a copy of the email from Dropbox:
This email is an automated notification from Dropbox that your Public links have been temporarily suspended on account of generating excessive traffic. Your Dropbox will continue to function completely normally with the exception of Public links.
Posted Feb 02, 2010 · 20:07 UTC#652
And the links dont work.. could someone upload them please ?
Links are at the end of page 40...
thanks, i will try it out this evening if i have time or else tomorrow. Just to make sure, this update is for all f series right ? so also European ?
Posted Feb 03, 2010 · 23:28 UTC#653
Can't speak to other units, I only used it to update two F700BT series models in the US.
Posted Feb 03, 2010 · 23:30 UTC#654
Meanwhile, my megaupload links are still up and working fine =D
I'm moving some new servers into my datacenter later this month...if needed I will upload them there as well so we can do away with the restrictions on how much/fast you can download at a time.
Posted Feb 04, 2010 · 01:43 UTC#655
In MyItGuy's 2 files which "My Flash Disk" do we load onto the navi? Or do we copy both "My flash disk" contents over into the navi?
Also, why are the 2 wince.bins?
Thanks ahead of time!
Posted Feb 04, 2010 · 05:12 UTC#656
You unrar both files as part of a single process. You should not have any duplicate files.
Posted Feb 04, 2010 · 06:02 UTC#657
Hey MyITGuy I downloaded both your files. I used WinRar and extracted them to my desktop. Should there be only 4 items?
My Flash disk
Testmode
Winceimg
Winceimg.cks
So When I put this onto my 2 Gig Scard and follow the install step by step the update "SHOULD" work. Correct :mrgreen:
Thanks for the downloads!
Posted Feb 06, 2010 · 15:09 UTC#658
My Flash disk
Testmode
Winceimg
Winceimg.cks
As I also mentioned in my response to your PM, yes those are all of the files you need. Place them all onto the SD Card and ignore any mention of swapping SD Cards in the instructions.
Posted Feb 06, 2010 · 15:46 UTC#659
What are the differents between the 2 RAR file you uploaded?
Posted Feb 06, 2010 · 19:46 UTC#660
My Flash disk
Testmode
Winceimg
Winceimg.cks
Thank you sir I will give it a shot tonight...hope this works. Oh as I was extracting the files I had to extract the second one first then the first one. It told me on the first download that things were missing. I did the second one first and all seemed to extract fine but It did ask me if I wanted to copy duplicate files. If I open each, say winceimg, what should I see? Should I see it as a VLC file? That's what showed up lol. Sorry for the questions but I don't want to brick it lol I did IDT mod when I bought the unit and I was shattin bricks but all went well.
Posted Feb 07, 2010 · 03:29 UTC#661
The two rar's make up the complete set of files you need. There's two so it complies with the space requirements by megaupload so users can download the files without having a membership.
Posted Feb 07, 2010 · 03:30 UTC#662
My Flash disk
Testmode
Winceimg
Winceimg.cks
You may want to re-download the files then, you should only have to unrar the .rar file and there shouldn't be any errors.
Posted Feb 07, 2010 · 07:34 UTC#663
Ok I just re downloaded the two files from page 40. In part 1 there is a My Flash Disk. In it there is APL and APL2. In Part 2 there is also a My Flash Disk Also contain the APL and APL2 BUT in the second download there is
ALP3 , Datadump, extradumpfiles and about 12 other things. Now when I open the part 1 APL there is a whole bunch of files in it. Part 2 APL has nothing in it. Now in part 1 APL2 there is just IGo8 but in Part 2 APL2 there is IGo8 and VBT.
Now when I extract both downloads into my SD card I get the following errors
You Need to have the following volume to continue extraction "AppsData\Local\Temp\3.0 Update part 2-1.rar" The required file is absent.
also
AppsData\Local\Temp\3.0 Update part 1-1.rar CRC Failed in MY Flash Drive Disk\APL2\IGO/CONTENT\MAP\USA_Tennessee.fbl. This file is corrupt
SO can I assume This didn't work correctly lol.
Posted Feb 08, 2010 · 04:34 UTC#664
also
I'm guessing something your doing along the way is not working as intended. You're only supposed to unrar 1 file, which will then extract the contents from both files.
800 downloads and only two issues reported, the first was user error and I'm assuming this one will be as well.
Posted Feb 09, 2010 · 05:10 UTC#665
I'm using winrar....what do you think I may be doing wrong. Basically I downloaded the part one file using winrar...then the part two download. I then extracted the part one download to my SD card. Then the part two. As I was extracting the part one download it told me something from the part two download was missing. So I then extracted part two onto the sd card. I'm not too sure what I'm doing wrong lol I'm just about to toss it in the trash hahaha. Is there one .zip file that has everything I need? Can or could it be emailed? Then just extract it onto the sd and go?
Posted Feb 09, 2010 · 15:37 UTC#666
Try extracting it to your local hard drive first, then copy/move it to your SD Card. Have you tried downloading part two again?
Also, can you clarify what you mean when you say "downloaded the part one file using winrar"? You should be downloading the files to disk prior to opening/running WinRar.
Here's the MD5 hashes to ensure the files were not corrupted as part of the download:
3.0 Update.part1.rar 100% 668efaf567c8a83224b241629cd288c0
3.0 Update.part2.rar 100% 4cc44e1cd265d6381a8da77c5c16cbfb
Also, no it cannot be e-mailed. Most e-mail servers have a limit of 10MB, this file is over 1.5GB in size. FTP or services such as MegaUpload are the only way to go. If you want to wait until early March I can place it on my FTP server once I get my servers in the data center.
Posted Feb 09, 2010 · 22:13 UTC#667
will this work on the f90 ?
Posted Feb 09, 2010 · 22:50 UTC#668
will this work on a F7010BT? also does anyone know how to bypass the video/nav block?
Posted Feb 10, 2010 · 18:39 UTC#669
my map isnt showing street names in 3d mode. they show up in both 2d modes, anyone else having this problem or know a solution?
Posted Feb 10, 2010 · 19:22 UTC#670
Change the viewing angle and settings.
I set the smart zoom to
- zoomed: 80m 65 degree
- standard: 150m 78 degree
Posted Feb 10, 2010 · 21:52 UTC#671
How to change the angle? in some data.zip file?
Posted Feb 11, 2010 · 04:07 UTC#672
I am downloading the two files from megaupload.com, but I assume those are just the two 3.0 update files. Does anyone have a link to a working WinCEIMG file or do I even need that?
Posted Feb 11, 2010 · 09:24 UTC#673
It's included in the files.
Posted Feb 11, 2010 · 14:08 UTC#674
Can anyone confirm that the rars on megaupload will work on a european F900BT?
Posted Feb 11, 2010 · 16:24 UTC#675
I downloaded the files and there is a part 1 file and part 2 file. I thought that both these were the 3.0 update files. Step 4 says "put in your sd card with the winceimg files". Step 9 says " delete all the files from the sd card and put the testmode folder, DATA file, and the flash dump from torrent on". Are the DATA and flash dump files included in the files from megaupload also and are they named DATA and flash dump?
Page 27 of 39
