Awesome! i havnt made any changes to those ini's anyways... easy...
V3.0 Firmware - SpeedCam Mod
ok, im having a problem. i set my unit to notify me when approching a cam and it doesnt beep or anything ![]()
What are your sound settings at? If you have master volume low, you wont be able to hear the noise notification. Also you need to be speeding past it to hear it. Another thing to look at is under GPS settings/Warnings do you have all those saved as ON? All things to look at.
Try setting a camera near your house and then speed passed it. Thats what I did to test out sound ect.
Is there a way to set the played alarm/siren volume as higher? I like to leave my button touch settings super low so they dont play, so do to that I cant hear the alarm play at all. Is there away to go into the file and raise the volume for it when it plays? Also have found other speed traps and am wondering how do I go about adding them in? Do I import them via an SD card or do I need to add them into a file then import it in via test mode?
Thanks Much!
p.s. I have successfully combined this speedcam mod with Keepers map skin mod and software by-pass (I had a D3 and just changed out the unit didnt move the pin placement from where I had the D3 bypassed so needed the software so didnt have to cram my fingers in there to move the pin.). So to those out there it is possible to do.
In v3.0 there is an option to turn off key beeps all together and still keep the master and voice volumes at decent levels.. for nav guidance and this speed cam mod
Excellent thank you I guess I didnt look all the way through the sounds settings as I was use to V2.0
anyone have a link to a good US speedcam file? not really wanting to pay for them from gps-data-team... i live in NC so extensive NC coverage would be great!
I am going to try and use the SPUD file from CMHs mod where we did have a ton of speedcam/traps especially in my area.
i have found a garmin speedcam file that has all the cams from my area in them... is there any easy way to convert it to a txt file or a spud that igo understands?
EDIT* nm... went ahead n payed my $7....
where can i find cmh's mod? cant seem to find it since he packed up and said peace out.. would like to look through it at some things...
So I have successfully gained the SPEEDCAMS/TRAPS from CMHs mod... download this file and make sure you removed the part that says .txt . The file should read just SpeedcamUpdates.spud (forum will not allow me to upload just a .spud file so I added the .txt to it you have to remove that).
Once downloaded place with test mode in avic. Go to APL2 > iGo> Content> SPEEDCAM and paste in this .SPUD file. Make sure though that you back up the present files in there just incase this SPUD doesnt work for your avic.
This added all the old speed cams that I had in CMHs mod. Hope it works for you too.
thanks!
let me know if it works...
worked like a champ.. i put it in with the .txts from gps-data-team and as far as i can tell it has all the cams in my town
What exactly is in the data.zip that needs to be there for the speedcam to work? I'm trying to merge some mods here, and 3 I'm messing with have data.zip's...
Whats different in the data.zip that I could manually edit my other one for?
NEVERMIND - found it on page 2... gonna go give this a shot on my 3.01...
The 2.0 speedcam mod allowed you to set a distance for being alerted with beeps, and in addition had voice notifications. Anyone know how to turn that on? I'm not even sure what ui file to look at for that one!
Happy Modding
uh oh.. havnt needed to use the nav since putting on this mod.. can i just turn off speedcam in the menu for now or will i need to remove it?
yea id like this option back. Having to speed to get notified of a cam doesnt make sense to me....well kinda but still ![]()
Sorry if this is a stupid question but is the alert actually the women speaking like in the older mod?
Lower the speed limit to 30, just about everyone drives over 30 and no cop is really gonna bust you for going 5 over the speed limit. Also make sure that your master volume is turned up so that you can hear the sound. Also if you are on the map screen it pops up and shows you a big box .3 miles out.
how do i lower the speed limit? do i need to edit every single cam to 30? ![]()
I have noticed that a lot of the preset ones from the spud file I uploaded didn't have the correct or any speed attached to it.
my speed files are .txt not .spud, whats bettter and difference?
can i use this one on my EU f900bt V3.1 ?.
when i put the navigation voic off the biep of speedcam is olso off can i do somthing about it?. the speedcam biep must by always on! en the navigation voic off! is that posible?.
and can i turn the speedcam biep harder?. or a other sound?.
thanks
