A few things I have noticed about 3.01
By eppler · Jul 23, 2009in Hacks/Mods💬 12 posts👁️ 2,499 views
Posted Jul 23, 2009 · 14:48 UTC#1
I installed 3.0 then 3.01 last night and these are things I just noticed on my way to work this morning.
1 in 3d mode road name does not show unless I am zoomed in real close.
2 there is limited angel adjustment in 3d.
3 Curser does not stay on road (could not find setting in menu for this).
4 HWY sings suck! (but I can see the need for them sometimes).
But otherwise it is a good update so far.
Posted Jul 23, 2009 · 15:57 UTC#2
1 is controlled (to some degree) by font size on 3D map (roadsign_lines_per_screen setting in [3d_config]), and to a larger degree by settings in color_scheme's [clip_planes] section
2 There are limits set for tilt in SYS.TXT (3d_max_tiltlevel and 3d_min_tiltlevel in [ma[]
3 There should still be something like 'Snap to Road' in settings.
4 THat's really TeleAtlas' problem. Once EzRider is hacked we might be able to use Navteq maps...
Posted Jul 23, 2009 · 16:56 UTC#3
i now have finaly 3.0 on my f900bt EU but how can i get 3.1 on it?.
if i do it whit the office pioneer update is not working
can sombody tell me?.
Posted Jul 23, 2009 · 17:22 UTC#4
Yea... if you actually used the search function and did not post in an arbitrary topic you would have come across this:
http://avic411.com/forum/viewtopic.php?f=34&t=25878
Posted Jul 23, 2009 · 17:28 UTC#5
Follow this link and then follow their directions.
http://www.pioneerelectronics.com/PUSA/ ... 10BT?tab=F
1 I will play with settings. Cannot remember if larger setting is more or less displayed.
2 No settings like that in my sys.txt but seen some else added them I will test to see if it works
3 In 2.xx there was a setting for 'Snap to Road' but I have not seen it in 3.01.
Edited: It is set to snap to road but it is off center to the left edge of the road. Seen some were how to change that in 2.xx will see if I can find it and if it works on 3.01
4 dam!!!
Posted Jul 23, 2009 · 18:00 UTC#6
I'm not sure about anyone else but i have noticed after doing the update my sound quality (via radio, ipod, etc) sucks. I know this mainly to update maps and a few other bugs and what not but if you go into sound settings, you no longer see what preset your EQ is set to (Powerful, Natural, etc) unless you press the EQ button. Same for a few other options within the sound settings. Everything else is decent for me for now but my system def doesn't hit the same way it used to pre 3.010
Posted Jul 23, 2009 · 18:06 UTC#7
I have not noticed that but I can get AM here in Houston and before 3.01I could not get the two stations i listen to on AM.
Posted Jul 23, 2009 · 18:58 UTC#8
i get screen freeze up's while listening to sd card, go to change to next song and nothing happens. Few minutes later it will change?
Posted Jul 25, 2009 · 15:56 UTC#9
UK 7 digit postcodes no longer get an exact location. You now need to add a house number always. This really sucks.
Posted Jul 25, 2009 · 17:01 UTC#10
the UK 7 digit never gives the exact location. it the street not the actual house number.
don't beleave me? check with your next door neightbor if he has the same postcode as you...
Posted Jul 26, 2009 · 23:55 UTC#11
Where is the color_scheme's [clip_planes] section? I would like to see the street names in 3d mode.
Posted Jul 27, 2009 · 01:43 UTC#12
Check the Color Schemes thread. AFAIK, not every scheme has this section. Or do a search for clip_planes.
