I was wondering if anyone knew if the bypass for the z110bt model is the same as the Z 1-3 models. I know this unit just came out but I thought Iwould try. I am on my way to pick mine up and will be installing it tonight. Any tips would be great.
AVIC Z110BT Bypass?
I have the exact same question...mine will be here tomorrow from CF. Any information would be awesome!
Hey guys, I am installing an AVIC-Z110BT wondering if theres a confirmed bypass for it yet?
same question here ,just got my unit today.
anyone have any luck on this yet? i really need this bypass, is it possible to use a relay, like on the AVHP units? Take pin 85 and 87 to ground, 86 goes to your amp turn on wire, and 30 goes to your parking brake wire.
Ok I got the install but have not been able to get the bypass to work as of yet. The 2 ground wire is not like the other models. The main power wire harness is the same but the harness with all the rca's is different. It does take a different IPOD cable then the other models as well. I bought a fix off ebay tonight and this guy says to use the relay just like MDEW06 said. So I am going to try that tomorrow and will let you know what I come up with.
Thanks for the ebay tips ,is this what the guy was talking about ?
AVHP bypass video
I put mine in today, without a bypass untill it becomes more clear how it is done.
Are there any open pin locations in either harness?
There are a couple of open pins on the rca plug.
The ebay bypass I got was just a simple email explaining how to hook up a relay, he says it will work. I plan on putting in the relay later today I will keep you posted.
Guys,
Here are some pictures of the connector in question. BTW, the power connector is the same as the ones dating all the the way back to the D3, no change there.
Were you able to get it to work ?
Not yet, someone asked what the connector looked like, and I just got mine outta the box. I'm going to try the relay bypass if I can find a 5 pin 40 amp relay. I just went to Advance Auto Parts, and that was a waste of time. Headed to Pep Boys now.
Dont waste your time with the relay it does not work. I just hooked up the relay and got the e brake warning and once you get to about 5 mph you can no longer enter addresses or watch a movie. I really dont care much about the movie but I want to be able to enter a address with out pulling over. So any idea's
Also if anyone is interested I have a extra one of these Avic Z110Bt if some one is looking for one. Brand new box has not even been opened.
Did you try resetting the Z110BT after you added the relay?
No I have not reset the unit, I will go try that and see if that helps
To all:
I installed the relay, and also did system resets, and it is definitely not in bypassed mode. Still get the e-brake message, and the menu items on the various screen gray out after you hit speed.
LAME!! The dude on eBay should be reported as a fraud...glad I didn't spend any money on that!
If anyone comes up with something, please advise!
-BN-
Reset did not work either. It does not have a regular reset button like other models. So I restored everything back to factory settings and the relay bypass does not work
ok, so ill admit i was wrong about the relay, and people wanna be a fuckin smart ass about it, then use a fuckin toggle switch. always works, stop being lazy and flip the dam switch, until someone from pioneer tells us how to do it the "easy way"
Mdew06,
I don't think anyone was being a smartass with you. They just stated that the ebay seller that is selling this as a viable bypass should be reported. We appreciate any efforts in finding the new bypass...
Mdew06,I don't think anyone was being a smartass with you. They just stated that the ebay seller that is selling this as a viable bypass should be reported. We appreciate any efforts in finding the new bypass...
Mdew06 "is" that ebay seller,this is his link on z110bt bypass sale for $20 ,he should definitely do a refund to whoever spent that money with him.
Mdew ought not "fuckin" be so "fuckin" up "fuckin" tight. He also shouldn't be trying to make a buck on something he obviously didn't "fuckin" test..."fucker". I don't have a problem with someone making some dough on a solution that has been tested and works, and I'd gladly give up some coin for that, but to post a "solution" and ask $20 bucks for it, when it was obviously never tested is shady at best, and irresponsible.
How 'bout that? Yeah, I can use that word too, but it doesn't make me tough, cool or anything else. A toggle isn't going to work either, since when it's thrown the system is going to get a speed error from the VSS line, and still disable everything that we're trying to have enabled. I suppose you could leave that unhooked, but that defeats a lot of the accuracy of the GPS system depending on your driving conditions, but I'm not sure that would work either since it will calculate the speed information from the GPS antenna as well.
-B-
well then everyone is outta luck until someone from pioneer figures this out. and i did refund that guys money back, so im sorry. so until someone gets this bypass, have fun using the stupid parking brake, lol. glad i didnt buy this unit.
You should feel shame about yourself ,you were selling a z110bt bypass trick on ebay and gurantee it,but in the same time ,you came up to this board and asked people how to do it ? WTF ! ,you clearly have no idea if your trick is going to work or not.
There is another seller on ebay that is claiming to have a bypass for the z110bt.
Has anyone checked this out yet?
