VSS hooked up correct??
By fearziz · Nov 06, 2006in Problems/Troubleshooting💬 18 posts👁️ 3,694 views
Posted Nov 06, 2006 · 20:28 UTC#1
I'm confused on if my vss is working. If I go to the vehicle dynamics screen it will show my speed increase and decrease. If i go to the 3d calibration screen where it displays connection status, speed pulse, the distance works but the speed pulse stays 0, and the status say's "simple hybrid".
Now if i read the book it says simple hybrid means it isnt hooked up to the vss. but if it isnt, why does my vehcile dynamic screen show my speed??
im confused!
Posted Nov 07, 2006 · 00:44 UTC#2
It calculates your speed based on the gps and internal gyros. What kind of car is it? I or someone else here can probably get you the correct wire color for vss.
Posted Nov 23, 2007 · 17:29 UTC#3
The same for me. I have a Infiniti qx4 1997 and its hooked up to a white/blue wire. Is that correct? Please help
Posted Nov 27, 2007 · 06:15 UTC#4
vss wire is not always needed to show speed. sat can pick it up and show on screen how fast you are going. clip the vss wire and it will show it.
Posted Dec 02, 2007 · 09:25 UTC#5
I have a scion TC...where and what color is my vss? How will I know if my vss is connect? I'm a newbie to this type of things. i have a D2 right now. thank you in advance.
Posted Dec 02, 2007 · 22:13 UTC#6
"Orange/silver wire in the HVAC plug, when looking at the face of the plug(that goes into the hvac unit) it's to the lower right... carries the VSS signal, and is close and easy"
Posted Dec 07, 2007 · 10:46 UTC#7
I have a 2007 Toyota Camry. What wire color is my vss? Thanks
Posted Dec 07, 2007 · 21:43 UTC#9
damn that site does not have it for the 2007 camry.
Posted Dec 07, 2007 · 21:59 UTC#10
Most years are going to be the same for the camry. Toyota hasn't changed anything on that car in years.
Posted Dec 22, 2007 · 13:32 UTC#11
3rd day today where my boy and I will finish the installation. One thing though, we have a rear view camera to deal with so I was wondering how to set it up.. He told me that we'll just hook it up with the reverse lights, but wouldn't that only cut on the D1 if and only if it's in reverse? Confused if this will be able to turn on when you check up on the rear view camera while traveling forward.... I really wanted to put a switch because I feel bad about buying it from eBay (hey man, it was a good price!) So another way I saw in other threads was to connect the RED to ACC, Black to Ground, and head unit's reverse to vehicle'z reverse, correct? Where to put the switch?
Also, where and what color is the VSS wire for the 2003 Infiniti G35 Auto Coupe?
Posted Dec 23, 2007 · 01:40 UTC#12
What purpose does a rear view camera serve if you're not going in reverse?
Posted Dec 23, 2007 · 13:41 UTC#13
To see a closer look at the Po PO that is behind me.. :)
Posted Dec 27, 2007 · 00:42 UTC#14
I don't know about the D1 but on the D3 you can just power the cam up on the ground and power leads going into the unit and run the reverse wire to the reverse light and the D3 will turn the cam on when you go into reverse. Also you can go into map view and click Reverse Cam and it'll come on also.
Posted Dec 27, 2007 · 04:50 UTC#15
Yeah, I've been playing around with the D1 and I saw the REAR view camera icon so I believe it works either way.... We didn't finish the install YET but hopefully this weekend we'll open up everything again and just finish it up..
SLIM PS2
Swi-pac
Rear deck speakers
And had few questions but i'll ask another time since my girl JUST called me.. haha pc
Posted Dec 27, 2007 · 05:17 UTC#16
Also I had to set the cam power to ground I think. Because the came wouldn't come on when I went in Reverse. It would come on when I went in drive haha..
Posted Dec 29, 2007 · 14:19 UTC#17
Hey, any of you guys know the VSS wire for the 2003 Infiniti G35 Coupe?
For some reason my arrow is facing one direction and never changes (facing straight)..
Also, does the D1 only have one spot for a CD? Because I tried to put my backup CNDV-70MT East disc and it doesn't update for some reason.. I'm thinking there is already a disc in there because I can use the NAVI WITHOUT the disc.. WEIRD..........................
And the disc works because I tried it on the AVIC-80DVD and it updated perfectly fine.. Any ideas?
Posted Dec 30, 2007 · 14:03 UTC#18
Anyone?
