Does anyone know which .bmp is the background for the volume digits? When I adjust the volume I can hardly make out the level number so I want to photoshop a new darker contrasted one.
Thanx!
Bud
Thanx!
Bud
Found it...it is in the "common" folder in the image.res file. It is "746_32K_MN-110_1_32b.bmp"
I just filled in the "bubble" with a better contrasting backdrop. The white numerals on the lt. gray background just didn't cut it.
Now I can see it! ![]()
Can you share with everyone?
I can't upload the .bmp nor a .jpg but it is here:
Image.res\Image\Common\746_32K_MN-110_1_32b.bmp.
You have to open up the file outside of the program, change the color, re-zip it and put the image_res file back into the unit. This is the only way I know how to do it.
I changed the fill to a blue/green color.
Anything darker than the white fonts will work.
Hpoe this helps,
Bud
Hpoe this helps,
Bud
Zip up the .bmp and then it will upload.(just for future reference)
I was trying that but it still would not work ![]()
Anyway, that is the file.
Well, I have found out that the reason I cannot see the phone numbers when someone is calling is because two of the background .bmp's in the Tel folder are missing entirely. They are:
and:
I have tried relentlessly with the programs I have to add these successfully to my Image.res files and I just plain GIVE UP!
Also, the disc image "icon" completely blocks out the title area when I am in the "details" screen when I am playing a CD.
Hey Guga, if you are out there can you make a revision to your Image.res for the 3.01 with these omitted files?
Thanx,
Bud
Thanx!
