Official 3.x Firmware Opinion/Results Thread
By bigPHIL18 · Aug 09, 2009in General💬 42 posts👁️ 10,844 views
Page 2 of 2
Posted Aug 27, 2009 · 20:46 UTC#26
Version: 3.0
Model: F700
Legitimate: Yes (Pioneer 2 sd card set from Crutchfield)
Opinion: Copying error on SD 1, failed install
Possible Improvements: Wish I had ignored the Pioneer 2.06 upgrade notice
Report:
SD 1 inserted, install starts
install failed at 94% installed
red error screen: Copying error/Storage card/LPUE080/APL2/IGO/.....speech/components/vf ....
Rebooted:
Menu screen comes up
went to system settings
System settings
Map set : None
System ..: None
didn't proceed .....
Posted Aug 28, 2009 · 06:03 UTC#27
Version: 3.0
Model: F700
Report:
Rebooted:
System settings
Map set : None
System ..: None
I did the 2.06 upgrade and had no problem with 3.0. :?
Posted Aug 29, 2009 · 07:08 UTC#28
I did the update CNSD-100FM on my Pioneer Premier AVIC-F90BT which I paid $60 for plus $10 shipping and tax.
I had no problems with the install but did not complete the MSN portion. Took about 35 minutes when using SD card 2.
unit seems to boot faster, better touch screen reaction time, everything seems to work better, I would recommend the upgrade to anyone who has not yet upgraded. The F90BT is more what I wanted when I first purchased it.
Just wanted to add my two cents, since some people reported problems, I was expecting some but they never happened.
Pioneer :D
Posted Aug 31, 2009 · 01:53 UTC#29
Deleted quote of mmartin88005 install problem report.
MM: Perhaps it's because I had the parking brake bypass?
Posted Aug 31, 2009 · 04:38 UTC#30
F700BT. Never installed any hacks prior to the update. Installed 3.0 about 2 weeks ago.
Installed failed twice at about 96% & 98%, but hitting the button continued the install. No further install issues.
Have noticed that the USB drive I have connected to the accessory cable sometimes fails to show up, so the radio is turned off when the unit boots. Have to unplug and re-plug in the USB drive. Never had this happen before.
Bluetooth connection doesn't seem to be automatic anymore with either of our Samsung Eternities (it was before), but the Nokia N95 has no such problems. However, I can't get the N95 to transfer the entire phonebook to the unit, only one contact at a time.
Button presses are much more accurate and I get faster response. The nav is much easier to read than before. Note on the currency of the maps: a roundabout in my town that has existed less than 6 months correctly shows up on the maps!
Posted Aug 31, 2009 · 10:17 UTC#31
Oh, I have also noticed with the update that sometimes right after boot, the splash screen will flash onto the screen, then it goes to the navigation menu, and will be unresponsive for a short moment. Then after pushing a button or two, it will take me to the radio screen (being that where it was shut off at), but there is no header bar. But going back to main and forward to radio resolves it.
Posted Aug 31, 2009 · 14:40 UTC#32
My F700 has been doing great since I upgraded, but now is starting to do this exact same thing at random times, not at every bootup.
Posted Aug 31, 2009 · 15:21 UTC#33
Yea, its not at every boot. And the SD playback is just as random if its going to work or not. It will play, but the screen won't update or respond, and somehow, the right button pushes seems to get it going.
Posted Sep 01, 2009 · 07:06 UTC#34
I am glad to see I am not the only one. I thought I screwed something up or my SD card was the problem.
Posted Sep 01, 2009 · 14:43 UTC#36
Version: 3.01
Model: F90
Legitimate: Was it ordered from Pioneer? Yes
Opinion: Marginal improvement over 2.0. MSN Direct upgrade was a pleasant surprise.
- Slow boot-up. I am still out of my driveway and down 2 blocks before radio/map work
- Need to work on the presets for HD radio. Does not show station names. Why have blank buttons? Either capture the station ID, or make them edit-able
- HD radio data should scroll/rotate. Change from station to artist to song to text. Don't force users to click through different pieces of info
- STREET NAMES in 3D. OMG what have they done??? you have to zoom into '500 feet to be able to see them. You should be able to see them regardless. The further you zoom out, the less detail you see (only major roads at higher elevations). Definitely much worse in 3.01 vs 2.0. This is a MUST FIX!!!
- need more OOB color schemes beyond red and blue
Start on this list, and i'll be sure to get you some more....
** Rant mode off **
Posted Sep 03, 2009 · 11:01 UTC#37
Version: 3.02
Model: F700BT
Opinion: Significant improvement over 2.0. Changed boot order brings radio/ipod up much faster. Screen brightness dims quicker as well when booted at night with the car lights on. New maps are a big improvement over previous version. Keys seem more responsive with little lag. Sounds associated with the menu and map keys are much less annoying.
It often does not recognize my Ipod is connected. Seems worse now than with 2.0 and you have to disconnect/connect to get it to interface with the head unit. This may not be a Pioneer problem (Apple, Microsoft?) but it is annoying all the same.
Would like to see ipod/cd program pause when making/receiving a call.
Would like the nav unit to display speed and speed limit when not in a route.
Bottom line: Very pleased with this unit and update. Operates, overall, very well with few quirks. (Nothing I can't live with.)
Update: Installed XM over the weekend. No issues. Works fine.
Posted Sep 03, 2009 · 14:15 UTC#38
Just installed my new update from pioneer and have screen freezing when playing mp3 from sd card or usb!! Steering wheel controls also don't respond well when screen freezed in either mode. Did not have this problem with 2.06!! Paid for new update and this crap happens!!??
Posted Sep 06, 2009 · 20:50 UTC#39
Interesting new behavior with 3.0, it now regularly loses my hooked up 24/7 ipod in the glovebox, and by regular, I mean once a week or so, I had this once or twice total with the various 2.x releases.
Not a big deal, but somewhat annoying since I can't get ipod music until I stop if I'm on the road.
Posted Sep 10, 2009 · 22:06 UTC#40
"Interesting" is one word for it. "f-ed" is another.
The only good things about 3.01 are the button response, info text readability on the map, and key beep disable.
Otherwise, to quote Capt Kirk... "Cons....!"
-Takes just as long to boot up, if not longer.
-Music during splash screen comes on no quicker than before.
-3D Map moves slower, has less detail, and does not display all street names.
-Map acts funky and weird, sometimes freezing, and requiring multiple pushes of the map button
-Map visual setting does not retain full-screen mode, and the useless information window keeps re-appearing in the lower left quadrant whenever I re-start the system. (I think 2.0 did that, too)
-iPhone was not recognized every time I plugged it in, and when it was, would not play any music. (iPhone 3G sw ver 3.1)
-Howard Stern and Opie/Anthony still suck and aren't funny.
EDIT: Doh! I had reset the unit in an attempt to get the map working correctly, without having to turn the engine off and on again. That reset AV1 to default. That is why I had no audio from my iPhone. It's OK now. (The iPhone playback, that is. The other stuff still sucks.)
Posted Sep 14, 2009 · 05:07 UTC#41
Here is my review of the 3.x update:
I can't believe I just paid for this shit
Posted Sep 16, 2009 · 21:45 UTC#42
Got the 3.02 update done today. Best part? There are 3 map modes. 2D where North is Up, 2D Direction of Travel, and 3D direction of travel. I was waiting for the 2D direction of travel! Now it's just like my other OEM navs.
Buttons responsive. XM much quicker to change channels. Load time quicker.
So far so good. Iphone 3gs plays using my cable. First time I plugged it in it asked me to replug it in.
Worth the 80 bucks. Just for the direction of travel and the new maps.
Page 2 of 2
