replacement screen
By Tuning Haus · Aug 10, 2009in General💬 5 posts👁️ 2,603 views
Posted Aug 10, 2009 · 09:38 UTC#1
hi i had a few accidental scratches on my z1 screen and although it still works, together with the scratches and the few odd spots, i was wondering if there is a "replacement" screen?
if so how much and how hard is it to replace?
thanks
Posted Aug 10, 2009 · 12:14 UTC#2
thanks
Posted Aug 10, 2009 · 18:31 UTC#3
The touch screen can be order from Pioneer and easily swapped out.
part # CSX1093, its only $50.09 + shipping.
See this thread for instructions and pictures:
viewtopic.php?f=19&t=22062
Posted Sep 24, 2009 · 07:27 UTC#4
Wow, I spent $200 and sent my Z1 in to Pioneer to fix a cracked screen, someone tried to steal my radio... Pioneer fixed the screen and sent the unit back, but the software seems to be updated? The thing is, my bypass is no longer working and I can't do an address search, even when my car is in park....
Posted Sep 24, 2009 · 23:44 UTC#5
If you were using the ducatiboy circuit or the flasher bypass, they will no longer work since Pioneer updated your software. You need to look under the Hacks section for the two wire bypass. It's very easy to do.
