3.0 MSN not working correctly?
By gotti2k7 · Aug 18, 2009in Problems/Troubleshooting💬 27 posts👁️ 4,013 views
Page 1 of 2
Posted Aug 18, 2009 · 15:59 UTC#1
I just finished the 3.0 this morning. I checked the MSN and the status says the firmware is not correct. Anyone having problems with there MSN besides me?
Posted Aug 18, 2009 · 18:50 UTC#2
I am having the same issue. I called Pioneer and they want me to send the unit back. I am going to reset it back to 2.0 and check it then try to update it again.
Posted Aug 18, 2009 · 20:12 UTC#3
Prolly same thing im gonna do. Im not gonna send my radio back just to fix that. Holy shiz. What else can go wrong...UHHH
Posted Aug 18, 2009 · 21:01 UTC#4
did not work even in 2.0 said the same thing
Posted Aug 18, 2009 · 21:50 UTC#5
I just got done with the 3.0 again and this time it worked. I don't know why but all I did was go back to 2.0 and start the upgrade I did not do 2.06. so maybe that was it this time.
Posted Aug 18, 2009 · 23:46 UTC#6
So you took it back to 2.0, then just installed the second SD card, not the first?
Posted Aug 19, 2009 · 01:16 UTC#7
No I took it back to 2.0 then the 1st (2.1) then the 2nd (3.0xxx). 2.06 was the update to fix the DST. I used this topic to get back to 2.0 http://avic411.com/forum/viewtopic.php?f=33&t=25424
Posted Aug 19, 2009 · 04:46 UTC#8
I have same issue, after 3.0 I can't get the F90 to connect to do the MSN portion of the upgrade. Not a brilliant idea to push the upgrade over the air, makes no sense when they could have put it on the memory card. Pioneer or Microsoft could get smart, they could still post a downloadable version of the update.
The MSN service could be nice but at this point I may never subscribe as it's never got the data I need in a timely fashion, having to wait 15-30 minutes for the data to update, heck I'm to the destination already and it's just now got some data??
Just out of curiosity, out of those people having issue who has a valid subscription vs an expired trial like I have?
Posted Aug 19, 2009 · 12:50 UTC#9
Interesting... when I looked at the update card, there is MSN firmware right on the card. On the other hand, I have seen many times that MSN receiver in the AVIC locks up if you turn the unit off before iGO had booted completely... You have to hit reset afterwards...
Posted Aug 19, 2009 · 15:43 UTC#10
Same Problem here. I called Pioneer for an assist and they response surprised me a little. "We (tech support) have not installed this update on any of our systems yet. I'll pass your information to Engineering and will get back to you as soon as more information is available." HAHA HAHAHAHAHA HA ...... still laughing ...... I'll try and update the MSN firmware manually (testmode) if that doesnt work i'll roll-back and try again.
Posted Aug 19, 2009 · 17:28 UTC#11
well that's cool i did not even think to look on the card, the install guide indicated that it seems to need to "connect" over the air to complete doing the upgrade for MSN. MSN service is "iffy" near my home but I travel through the Phoenix area daily and the signal strength there is peretty good from several sources.
I'll be interested in your "testmode" results if you get to it, I will take a look at the upgrade card again later as well.
Posted Aug 19, 2009 · 20:50 UTC#12
My MSN DIrect signal had always been "iffy" at best, and I live/work in areas that are supposed to have good coverage. I was lucky to ever see 1 bar on the status page, and that was rare.
After applying the 3.0 update I purchased from Pioneer, I now have full bars most all the time.
MSN direct data used to take forever to actually populate.
Everything is current within minutes of startup now.
Quite suprised and very pleased.
Posted Aug 20, 2009 · 01:22 UTC#13
Now that I'm home I see the MSN upgrde file on the sd card. The upgrade manual refers to having a MSN connection and it taking 8 minutes to get the MSN firmware upgraded. The file on the sd card is only 1.5 mb I can't imagine that file would take 8 minutes to process onto the unit.
Anyways I've no clue how to force it to run the upgrade at this point. It looks like I have to wait for someone to figure it out, Pioneer to provide a solution, Though under warranty I don't intend to send the unit back for something like this that should be repairable by a simple install file. I also can try rolling back to 2.0 and running the upgrade again an unpleasant 2-3 hour process, or simply ignoring the problem and never having/using MSN direct.
Posted Aug 20, 2009 · 16:46 UTC#14
Ok. I had this problem at first. The instruction for upgrade the MSN is not very clear (when you think the upgrade is all done but the MSN is actually not part of it, and it will not get upgraded until you have the upgrade SD in the unit and try to use the MSN the first times). These are the steps I took.
1. When the unit is still turn off, insert the 2nd upgrade SD into the unit.
2. Turn your key to ACC to start the unit.
3. The unit knows not to upgrade the system firmware again since it is the same version already.
4. With the SD in the unit, go to MSN Direct main menu, click at the bottom where shows "status".
5. Wait for the status screen to show and then just follow the instructions.
I think this is it. Sorry, I am writing this from memory. I will try to verify this when I got home.
Posted Aug 21, 2009 · 16:08 UTC#15
My first attemp simply failed to work for unknown reasons when following the instructions exactly as written, most seem to be having sucess. I did get the firmware update to work right last night.
1. Turn the car or stereo on as you would normally. This does not do a reboot of the unit and that is what is needed for the Avic to see the upgrade card properly.
2. After starting the unit I Re-instered SD card #2 from the 3.0 update
3. I Hit the reset button to force the Avic to do a full reboot and recognize the SD card properly
4. followed the directions for the MSN direct update
a. Wait for top menu after booting fully
b. Select Destinations
c. Select MSN direct
d. Select Status
If you are as lucky as I am you isimply watch the pretty progress bar until it completes and you are done! You can go select the two hidden spots on the screen to verify things went proper.
Posted Aug 25, 2009 · 19:52 UTC#16
This is correct! I just did this with my F90BT and it installed the firmware for MSN Direct. The funny thing is, 10 mins prior to reading your post, I was on the phone with MSN's customer support canceling my subscription. Looks like I need to purchase it again.
Posted Aug 31, 2009 · 05:55 UTC#17
Thanks, I had a problem with MSN direct, I did not complete the MSN portion of the update so it would not work and any time I put either SD card in I got a card read error. The key to resolving this for me and getting the MSN update is to turn the car OFF. Put in the SD 2, start the car, allow the system to boot, wait for MSN to connect, then go to "Status" and the updates starts on its own, 8 minutes later your done. Thanks to the previous poster for pointing out the steps, particularly inserting the update SD only when the car is OFF.
Posted Aug 31, 2009 · 15:15 UTC#18
You're welcome. :wink:
Posted Sep 08, 2009 · 21:33 UTC#19
My issue is, I think a little different. Mine tells me it is connecting to MSN Direct under the status tab, but, I am not showing any signal. I called MSNDirect and they told me it was a known issue with Pioneer. I called Pioneer and they told me I need to buy an FM booster to boost teh signal. I live in the LA area and the coverage for it is exceptional for the area. Does anyone know about having to install an FM booster and if so, any suggestions on a reputable device?
Posted Sep 09, 2009 · 13:39 UTC#20
+1
Posted Sep 09, 2009 · 20:23 UTC#21
I canceled mine a long time ago because it never really worked well. I just realized that it is now working! I'd wait before renewing to see if it actually stops working.
Posted Sep 10, 2009 · 18:05 UTC#22
I also live in theLA area but don't have this problem. Let me ask you a question. Have you done a reset (by pressing that little pin next to the reject) after the 3.0 update? If not, try that because it usually helps.
Good luck.
Posted Sep 10, 2009 · 21:07 UTC#23
I haven't done the reset yet. I will try it and let you know.
Posted Sep 14, 2009 · 14:17 UTC#24
Teset worked perfectly. I think it is rather funny that Pioneer told me to buy an FM booster rather than reset the system. I guess that is why this forum is here.
Thx.
Posted Sep 14, 2009 · 23:12 UTC#25
Thx.
Good. And you're welcome.
Page 1 of 2
