"Not Enough Space" message when backing up files...
By boots · Aug 18, 2009in Hacks/Mods💬 5 posts👁️ 1,189 views
Posted Aug 18, 2009 · 17:44 UTC#1
I just got my 3.0 update from pioneer yesterday and installed it this morning. I was trying to copy all the files from "My Flash Disk" to my 8GB SD card but for some reason when I try to copy the APL 2 folder to the SD card is says that there isn't enough space on the card and that only "some" of the files will be copied. I am pretty sure that folder isn't bigger than about 7.5 GB. Does anyone know why I would be getting this message? Thanks for the help!
Posted Aug 18, 2009 · 18:16 UTC#2
was the disk empty before you copied to it?
Posted Aug 18, 2009 · 19:09 UTC#3
The SD card that I was trying to copy to only had test mode on it.
Posted Aug 18, 2009 · 21:16 UTC#5
Use this SD Card formatter to format your SD Card and try again.
http://www.sdcard.org/consumers/formatter/
Also, make sure you are not making same mistake as this thread: viewtopic.php?f=34&t=26445
Good luck.
I will have to try that SD card formatter when I get home from work to see if that works. I don't think that it's the same problem as in that thread because I am already opening up my SD card to paste the files and it still won't work. Thanks for the help!
