The update from Pioneer and it's contents:
Checking the old version number:
Step 1: With the unit off, insert SD Card 1, and turn the unit on. The first update process will begin.
Step 2: After the update, the unit will restart. Take out SD Card 1, and once the system boots up, insert SD Card 2. You will be presented with a Device ID Screen Write this number down, and hop over to PioneerNavigationUpdate.com and input the device number and media number found on the inside of the SD case. The site will then generate a password for you. Write this down or print it. Go back to your AVIC and enter the password It will confirm the update process and then present you with a new update screen. Once that update completes, it will ask you if you would like to keep your splash screen. (a nice touch) After asking, the AVIC will go back to the standard upgrade screen that we all know and love, this time updating the APL. Data. and CE Image. Once that finishes, the AVIC will reboot, and you'll be back at the Top Menu.
Step 3: Updating the MSN Direct Firmware
Go to the Destination menu:
Then go to MSN Direct
Then click Status. The update will begin automatically.
Once that finishes, your all set! Enjoy 3.020100!
