Hello everyone, ive been reading this forum for the past 2 weeks researching the Z110 and bit the bullet.
Im preping everything for the install. I have a 2008 Hyundai sonata Limited. it has the factory amp and sub woofer option.
now before i install this i was reading on this thread viewtopic.php?f=56&t=26794 on page 2 about ohm's now i have no idea what an ohm is but i got the factory specs for my car and what the speakers are receiving.
all my info on my care is from http://www.hmaservice.com its free and has all FSM info.
this is a copy from the other thread:
"The bose speakers are known to have a 1 or 2 ohm impedance .... your pioneer is designed for 4ohms or higher.
Your speaks run individually off of the stock amp - the stock amp has built in cross-overs unless your tweeters run in parallel off your door speakers, but probably not. So you would need to add some crossovers (same ones they use for components) to run your stock bose speakers but your impedance is still too low for the mid / woofer."
the harness adaptor i have is like any other system, 4 sets of speaker wire for FR FL RR RL. i assume the subwoofer does the conversion for the subwoofer and the tweaters. FYI its a factory JBL amp.
even though my new deck is 4 ohm, will the amp be able to convert it back to what i need, or do i need another adaptor?
NOW this is hyundai's info on my factory system.
Need some input. next week is when i install the head unit, XM box, and backup camera!
