Hey... i just bought the 910 and i was told that you can not play DVD's while the vehicle is moving. Is there any way around this?
Thank you
Thank you
Thank you
That's what the "Parking Brake Bypass" is for ![]()
There's a hardware bypass and a software bypass you can do. Check the F series boards for details.
i had a shop hook it up and they did put a switch that im suppose ot flip. but when i do it turns on/off the bluebooth option and map.. do you think they hooked it up incorrectly?
I have been told that the video is connected with the GPS system and when the vehicle starts moving the gps senses the motion and shuts of fthe video. is this true?
I know they have agreen cable and ground running the switch.. anyone knows the color of the cable?
i have firmware 3.0
do you know where i can get the software with instructions??
thanks
There's a hardware bypass and a software bypass you can do. Check the F series boards for details.i have firmware 3.0
thanks
f-series forum on the hacks thread section
they have it installed correctly
it is true
This bypass works for the 910 too. It works great, just watch the video. I can call dial, watch videos and everything as if I was parked. Let me know if you need help. Good luck
Try this thread. I did the hardware bypass, so I'm not familiar with the alternative method.
