[sOLVED]
Howdy everyone. I recently installed the AVIC-F90BT in my Toyota Tundra 2004. Other than the PAC-TATO (convert proprietary JBL digital signal in RCA analog) and the PAC SWI-PS (steering wheel control interface), it was a pretty standard install (only other thing was the double-din install kit).
My problem is with getting the bypasses to work.
For the hardware bypass, I did two things.
1.) Following the instructions in http://www.avic411.com/forum/viewtopic.php?t=17013, I moved the mute wire pin to the adjacent row (4th pin from the edge)
2.) Grounded the parking break wire (long green wire if I remember right) to the ground for the radio.
This solved the problem of not being able to modify the settings while parked, but after I headed out onto the road, it popped up a window telling my parking break is improperly configured... thus (after moving), the radio disabled everything it disables while in motion.
For the software bypass, I followed the information in the http://www.avic411.com/forum/viewtopic.php?t=17715 post. I downloaded the data.zip to an SD card, modified the pioneer.ini file (had to use WinZip - using explorer mode said the pioneer.ini file was read only), made a backup of the original data.zip file, and then copied the newly modified file into its place on the AVIC-F90BT.
I would suspect I have two problems, although both may be resolved with one solution.
1.) I get the message when I start driving about the parking break being improperly configured.
2.) The unit still disables all the other sections of the interface while in motion.
Any help or direction would be greatly appreciated.
