Can anyone with European unit that uses TMC and uses a hacked ezrider 3 check if bluetooth and tmc are working at the same time.
Or if someone with a legit ezrider replace it with the hacked version and see if they both work together.
I have continued a thread at viewtopic.php?f=34&t=23158&start=60 and have ver 3 running on an Australian unit.
If I enable TMC then Tel.exe crashes andno bluetooth. If I disable TMC then bluetooth works and tel.exe is happy. I have made numerous changes and hacks to device.ini files and sys files and the problem seems to stem from the hacked ezrider.exe.
So
1) Do TMC and Bluetooth work with legit ezrider 3 and legit license file?
2) Do TMC and Bluetooth work with legit ezrider 3 and hacked igo world wide license file?
3) Do TMC and Bluetooth work with Hacked ezrider 3 and legit license file?
4) Do TMC and Bluetooth work with Hacked ezrider 3 and hacked igo world wide license file?
If someone in Europe could find the time to try the above expeiments for me I would be in debt to them.
Thank you
