Australian Map Update (R17 Maps Page 23)
By 34by151 · Mar 29, 2009in Hacks/Mods💬 481 posts👁️ 97,204 views
Page 1 of 20
Posted Mar 29, 2009 · 10:20 UTC#1
Usual Disclaimer:
These files are for hobbyist use only. Use them at your own risk I can not be responsible for your actions if something goes wrong. Make sure you take a backup of your system prior to any changes
Contained in this release:
Test mode setup for Australia
Australian Map Update Sensis R15.1 with 3d Buildings
SUNA TMC traffic Management
Key Beep removal mod
Updated DATA.ZIP
Updated SYS.TXT
Updated Fonts
This release has been tested on the Australian AVIC-F900BT
Download files from
http://www.4shared.com/file/95580165/5b ... part1.html
http://www.4shared.com/file/95583929/2a ... part2.html
http://www.4shared.com/file/95577170/2d ... part3.html
Links:
Sensis
http://www.sensis.com.au
SUNA
http://www.sunatraffic.com.au/home.html
Key Beep Mod
http://avic411.com/forum/viewtopic.php?t=17249
DATA.ZIP
Many thanks to GTIMatt for posting his data.zip and to lacehim for the Kph version. Included in the release is the second version of lacehim's changes. For info on this data.zip see http://www.avic411.com/forum/viewtopic.php?f=34&t=23003&p=155294&hilit=risk#p155294
SYS.TXT
Many tweaks added over time, too many to list here
Fonts
I have included the fonts need by the mods contained in this release.
Test Mode
Read the AVIC411 Faq's http://avic411.com/forum/viewtopic.php?f=32&t=19170'>http://avic411.com/forum/viewtopic.php?f=32&t=19170
Instructions
This update will just fit on a 1Gb SD card but it is advisable to use a SD card greater than 1Gb.
1. Start you AVIC normally and verify you have the V2 Firmware installed.
Check Pioneer website for info and download of the V2.0 Firmware and how to check you have it installed http://Https://www.pioneer.com.au/avicf900btDownload.aspx
2. Check your map version.
Go into Settings / Navi Settings / About / Maps
Your Maps will display Sensis R14 or similar
3. Extract this update to the root of an empty SD card. Do not modify the directory structure
4. Insert the SD card and Start the AVIC
5. Use Test mode to backup your unit. A Directory called "Backup" has been created on the SD card for your backup. Copy your "Flash Disk" to this directory
Read the AVIC411 Faq's If you are unsure on Test Mode
6. Rename or Delete the Following Directories on "My Flash Disk". I recommend you rename the directories but it's up to you.
Rename My Flash Disk\Update\APL2\iGo\CONTENT to My Flash Disk\Update\APL2\iGo\CONTENT.bak
Rename My Flash Disk\Update\APL2\iGo\LICENSE to My Flash Disk\Update\APL2\iGo\LICENSE.bak
7. If you don't want the key beep mod skip this step. Go into My Flash Disk\DATA\Sound and delete the files PSG1Hi.wav, PSG1Low.wav, PSG2Hi.wav and PSG2Low.wav. Don't worry renamed copies of these files are contained in this update. These are called 1PSG1Hi.wav, 1PSG1Low.wav, 1PSG2Hi.wav and 1PSG2Low.wav To reverse this mod later just rename the files back to normal.
8. Copy The directories below SD Card\Update to "My Flash Disk". When asked say yes to overwriting files. Copies of the overwritten Files are contained in this release. The Main Files overwritten are DATA.ZIP EZRIDER.EXE and SYS.TXT copies of the original files will be copied to you flash drive as DATA.BAK, EZRIDER.BAK and STS.BAK These are the files from The V2.0 Firmware update
9. Restart Your AVIC
10. Verify you have the new Maps
The Map will now be "Australia R15dot1 Sensis [081027]
I have held back some updates to the standard TMC Traffic, The Phoneme file and some other mods. Once these are fully tested I will release these Updates as well
Posted Mar 29, 2009 · 23:45 UTC#2
Excellent post 34by151 :D Keep up the good work.
Posted Apr 06, 2009 · 01:57 UTC#3
Just got a reply from Aussie Pioneer regarding the map update in August 2009.
"The 2009 update due to be released in August will be Sensis version 15.1"
All the above by 34by151 works great on my F900BT. Thanks for all your hard work 34by151.
Posted Apr 06, 2009 · 09:44 UTC#4
Thanks Guys,
I have tested the phoneme update and that will be in my next release. I have also tested the Auto/Manual tune for the TMC and am completeing the screen changes. I'm hoping to release both this weekend.
Update will have
Phoneme File added to the 15.1Maps to give proper voice prompts on some roads
GTIMatt's latest Data.zip
New TMC options added to above for Auto / Manual Tune
New TMC icons for different event types
Options to exclude event type from route recalc
Options to include TMC text with icon on map
When Manual tune is selected up /down tune buttons apper on the TMC Contol center for Tuning.
On boot tuner will find the first valid TMC signal an lock on. You can then manually tune from that point.
I have not worked out how to start on the last saved TMC station as yet but will keep working on that.
Cheers
34by151
Posted Apr 07, 2009 · 10:43 UTC#5
Looking forward to the update. Something new to try. :D
Posted Apr 10, 2009 · 13:11 UTC#6
Really nice. Love the tweaks.
Posted Apr 11, 2009 · 12:27 UTC#7
How does SUNA TMS work? Do you have to register for it somewhere? What station carries the correct RDS/TMC data?
Posted Apr 11, 2009 · 12:37 UTC#8
Aussie units are pre registered for SUNA however the maps don't support it. I dont' know if the V1.0 units are registered or not my unit was shipped with V2.0.
If you add my update SUNA will start working. You will see both traffic data in the control center and icons on the map.
For those of you that have PM'd and emailed me about the update I'm still working on the screen changes. I hope to get that out to everyone before the end of the long weekend
For details on SUNA and the stations see the SUNA website using the link I posted
Cheers
34by151
Posted Apr 11, 2009 · 14:25 UTC#9
My unit had 2.0 out of the box and I could see some traffic information (on the separate screen but not on the map). unfortunately I managed to delete everything (by mistake) and didnt have a chance to explore it further.
Posted Apr 12, 2009 · 06:26 UTC#10
In the traffic events screen press one of the events and it will take you to the event on the map.
Posted Apr 12, 2009 · 06:42 UTC#11
Updated Release
Usual Disclaimer:
* Phoneme File added to the 15.1Maps to give proper voice prompts on some roads
* GTIMatt's latest Data.zip (09 Apr)
* Swapped the position of the Delete Route and Voice Mute buttons
* New TMC options added to above for Auto / Manual Tune
* New manual tune buttons, press for 0.1mhz change, long press seek next station
Held back , still testing
* New TMC icons for different event types
* Options to exclude event type from route recalc
* Options to include TMC text with icon on map
* sys.txt Variable to set Tuner start mode
Download files from:
http://www.4shared.com/file/98059420/fd ... date1.html
Instructions:
1. Download files
2. Extract to the SD card overwriting files from the first release
3. Follow the instructions from the first release
Cheers
34by151
Posted Apr 12, 2009 · 08:11 UTC#12
Great work. Thank you for that. I'll give it a try later on. Any plans for the future relases?
Posted Apr 12, 2009 · 16:45 UTC#13
Thanks mate! Legend!! :P
I don't have an AVIC F series yet but I want to get one...... could someone order a 900BT or 90BT from the US for a lot cheaper and put these maps on?
If yes, how would one then register a US unit for SUNA?
Ta!
PS SUNA is now being broadcast over 101.1FM in Melbourne and 97.3FM in Brisbane and on 106.5FM in Sydney.
Posted Apr 13, 2009 · 02:19 UTC#14
I have Updated the DATA.zip file
Added the TMC and signal status to the menu.
This will show
* Testing when you fin a new station
* No TMC signal id the station does not have TMC
* TMC Present if a TMC data is found
* TMC data type and key if TMC is found and locked on
Screen Pic Here
http://www.4shared.com/file/98207775/97213a46/tmc.html
download the new data.zip here
http://www.4shared.com/file/98207724/9d51fe95/DATA.html
Cheers
34by151
Posted Apr 13, 2009 · 06:46 UTC#15
Thanks heaps for this, 34by151 !!!
Would you please be able to start a CHANGELOG or readme.txt so that user who would like
to use other data.zip mods in the future know what the differences are?
(say for example someone wanted to use a data.zip from another modder than GTIMatt...)
Posted Apr 13, 2009 · 08:13 UTC#16
Here you go.
TMC mod
FILE: tmc_800_480.ui
Change: Replaced
File: templates_800_480.ui
Change: Added line
New Files
File: ui_pioneer\800_480\TMC_mode.bmp
Function: Auto/Manual Tune checkbox
File: ui_pioneer\800_480\746_32K_MN-053_32c.bmp
Function: Search up button, mirror of 800_480\746_32K_MN-053_32b.bmp
Cheers.
34by151
Posted Apr 13, 2009 · 08:37 UTC#17
As posted before I have held over the mods below as I am still testing them
Status:
Completed but untested in traffic.
* The new Icons spific to the event type show on the map screen. I am working on displaying the traffic speed alongside side the icon. Pressing the Icon on the map screen shows the event text
* New screen For Event types. An extra button next to both "use traffic info" and "Recalc to avoid traffic" for custom options.
* "Use traffic info" custom button is enabled when on, this allows you to turn on and off event types. Turing off will also stop display of event type on map. Enabled options, on (shows icon , and speed), Speed (shows speed only) and Icon (icon only)
* "Recalc to avoid traffic" custom button is enabled when on, this allows you to turn on and off recalc for event types
Incomplete
Variable to set startup mode of tuner to auto or manual. This is not working as yet.
I must also say that when ever you enter the TMC Control Centre the tuner will show Auto. This is because the button defaults to this state not the current state. If you change to manual it will stay that way when you exit the screen but change to auto if you re-enter the screen. The unit will also default to Auto on reboot. This will change when I get the variables working.
Oh yeah, On the old TMC screen the message "TMC Present" is bogus. It just text and has no meaning.
IE does not show any status like my code does now. Also the Signal meter does not show anything to do with TMC other than the radio station signal strength. IE A station with a strong signal may sill have no TMC. The new TMC status will tell you what the station is sending.
Cheers
34by151
Posted Apr 13, 2009 · 09:49 UTC#18
This is great work.
I want to import a US F90BT instead of buying the much more expensive Australian F900BT. I'm just trying to make sure that they will be equivalent....
Firstly, I have downloaded BOTH U.S. and AUS files for the "V2 update" from the respective Pioneer US and AUS websites. Doing a comparison between the files and directory structure of both updates with WinMerge reveals they are exactly identical - this is good.
Secondly, the attached Pioneer document states the only difference between F90BT and F900BT in hardware is the 4V preamp output - this is good.
Thirdly, I would like to check if the other files on the AVIC (apart from the V2 update and maps) are the same between US and AUS. - 34by151 if you have a backup of your AVIC flash on your computer, would you mind being so kind as to post a TXT file with the details of all files and directories in your backup AVIC flash? To get this, just go into command prompt (cmd), cd to the relevant directory, and type dir /s /og > dir.txt and post the resulting dir.txt
!! thanks!!
Posted Apr 14, 2009 · 05:22 UTC#19
You can get the maps going my map update should take care of that.
Read up on the threads for the UK guys importing US units.
I understand the FM tuner is not the same in the US units and you will have troubles with the TMC.
If you do import one I am after a V2.0 backup so I can look at the Voice command's latter on and a EU backup so i can look into getting the radio station names working in the FM tuner.
Cheers
34by151
Posted Apr 14, 2009 · 07:41 UTC#20
YellowLemon the US versions hardware is different but will support the aussie maps. You won't be able to recieve SUNA because the US version uses MSNDirect for traffic updates instead of TMC (SUNA). Also the radio won't turn in .1 frequencies. The US unit will only tune in .2 steps. There are plenty of threads on this, try searching. They are mostly about loading European maps, but the Aussie unit is the same as European for hardware.
Posted Apr 14, 2009 · 19:03 UTC#21
Thanks for that information lacehim! The tuning is not a problem, as all the Brisbane radio stations are on non-even-decimal frequencies like in the US. The lack of TMC though, I wonder is that hardware or just a software difference?
34by151 - When my F90BT arrives from the US I will get you a copy of the flash disk that comes with it. So you're saying the aussie units don't even display the station name / RDS ? That's ridiculous. Does the US version show the RDS station name? Guess I'll find out. Here in Brisbane only 1 single station has an RDS station name anyway, that's NOVA FM.
Posted Apr 14, 2009 · 19:38 UTC#22
US version does not show any RDS information from the built-in tuner...
Posted Apr 14, 2009 · 19:41 UTC#23
Yep that makes sense. What doesn't make sense is why the Australian version would not show the RDS data, even though it has TMC which by definition requires RDS hardware.... so it would have to be some software problem? (The other issue it is difficult to test whether RDS names are being displayed in Australia because hardly any radio stations here bother to transmit an RDS name, slackers...)
Posted Apr 15, 2009 · 09:32 UTC#24
If you check the TMC screen you will find that does show the radio station name. So the tuner does pass the names. The problem is The fields are missing on the OZ FM radio screen. I haven't done much more work on it yet other than that. When I get a full EU backup I'll start decompiling the files.
A US backup would also be helpful in looking at the voice command. Again it's not high on my list as I use the voice command on the phone to dial for now.
Testing is going well with the rest of the TMC mods all seems to be work well so far. With a bit of luck I can get back to doing the sys.txt stuff on the weekend
Cheers
34by151
Posted Apr 15, 2009 · 10:00 UTC#25
It baffles me as to why Euro and AUS units would not have this function.. so strange!
How useful are the SUNA TMC messages? Is it a well-implemented system with adequate traffic info? Or do you still find yourself running into traffic....
Page 1 of 20
