Australian Map Update (R17 Maps Page 23)
By 34by151 · Mar 29, 2009in Hacks/Mods💬 481 posts👁️ 97,204 views
Page 2 of 20
Posted Apr 15, 2009 · 10:44 UTC#26
On the station names I can only guess that it was cut out because other warning stuff on the EU version not supported in OZ. It was probably easer to cut the lot out rather than just remove some functions.
On SUNA, In Sydney it quite good but don't expect it to magically give you clear roads. Peak hour is still peak hour.
What I have noticed it is not reporting slow traffic if it is not abnormal. As an example I the M5 is useless toll road expect to often be doing under 60 in a 110 zone. SUNA wont report that because that is normal. If it was down to say 40 (an abnormal speed) expect to see a warning
As another example I was driving to the northern beaches of Sydney today. From where I was you could go via the spit or around Northbridge. Now which ever way you go your stuck getting around the waterways if you hit traffic. No chance of going another way. Normally I'd go via the spit which is the way the AVIC also routes you. Along the way (in the harbor tunnel) TMC received an accident report and routed me the other way around with a nice “accident ahead re-routing†message. As one of my guys also was going to the same place in another car I thought give this a go. I got their 25min ahead of him. Not that that really proves anything but I did not encounter abnormal traffic along the way and the others were in bumper to bumper getting around the accident
Cheers
34by151
Posted Apr 15, 2009 · 16:52 UTC#27
Thanks for that detailed report! It seems TMC and SUNA are alive and well and that's great. Respect to you 34by151 for "enabling" this feature with your map package!
Posted Apr 17, 2009 · 13:18 UTC#28
Some new info:
When I compared the UK "version 2" firmware update to the US/AUS "version 2", there were some differences but only in a few files including data.zip. Also the UK version upgrade had a whole bunch of extra language files in the igo/content folder, about 15 extra languages.
Note that when I compared the version 2 updates between USA and AUS, they were identical.
TO see for yourself, download the updates from UK and US sites, and compare with WinMerge freeware.
Posted Apr 17, 2009 · 15:07 UTC#29
Cool Thanks for posting this up!! I'd like to keep my current modded Data.zip etc What part/files do i need to download if I only want to update the Australian Map to 15.1, phoneme file & the SUNA TMC traffic Management?
Cheers
Justin
Posted Apr 17, 2009 · 21:17 UTC#30
Justin,
Just apply both updates and rename the stock data.zip. Read the instructions all is quite clear in the posts and in the readme in the download. If you are asking how to use the stock data.zip with the TMC screen mod you will have to add that to the stock data.zip yourself. Read my post on the TMC screen changes and you can cut/paste the code.
If you are having troubles after that ask.
Cheers
34by151
Posted May 12, 2009 · 13:57 UTC#31
900bt, AUS version
map update works great, many thanx to the author! I really appreciate the bloody dog being replaced with the female voice, beeping not cuting off music, soooo much more 21st century :-)
TMC seems to never lock on a station though, it did lock quickly with the stock software. Now it sort of has 80-90% signal on one tation, but always gives up with a few secs and displays 'no signal', even though the indicator is going over 80%. (on manual tuning this is stable, on auto it just scans through a few times and gives up within seconds)
The other MODs of the MAP screen are very good and again much appreciated. I found the displayed "current speed" has some redraw issues while stationary, on occasions.
Had anyone the TMC problem?? Or have I mixed up something (like the gtimatts data.zip with the OZ one :-)
thanx
Posted May 12, 2009 · 20:58 UTC#32
I travel to Brissy quite a bit and I can't seem to get TMC to display anything. We might have to wait for the pioneer map update in August to get that feature.
Posted May 13, 2009 · 13:35 UTC#33
thanx for sharing, had a feeling I stuffed somehing up with the data.zip.
I have to correct the earlier post, that the speed indicator doesn't update correctly in he gtimat's MOD, it is actually the altitude digits, it seems the old value doesn't get cleared and the new sits on top, eventually it ges cleared, I wish someone told me where to look, I would find time to try to fix this...
Posted May 13, 2009 · 21:28 UTC#34
All of GTIMatt's mods are well listed in the data.zip files (use WinRAR to access). Just post on the GTIMatt's thread and he will surely help. He was a really nice bloke and helped me set up the kph modification which he then rolled into one data.zip
Posted May 14, 2009 · 12:48 UTC#35
Just to Explain how the TMC signal meter works.
Is shows the signal strength of the data stream not the station signal strength. The problem with the auto tune is that SUNA do not have the signal on when they are not sending data. Thats why the meter goes up and down a lot. When it is very low the tuner times out. This causes it to start scanning for a new TMC station. The result of theis is you loose TMC updates because it keeps scanning. That's why I did the manual tune mod.
On my Mod I also got rid of the Tuner Enabled message and put in the tuner status. You will notice that once locked on it will display as CA-TMC. That means it is locked onto the TMC signal. CA-TMC is the data type SUNA are using. You will also notice that you have "CA-TMC (No Key)" displayed. This is because Pioneer have not included the subscription data on your unit. Probably because SUNA is not supported till the MAP Update.
The reason We have only been getting Major Road issues is because we don't have the key. I don't know about other city's but SUNA in Sydney are now not sending any data that does not need the key. Hence you unit will lock on but no longer get traffic data displayed. In Sydney they started the about 10 days ago. This has put a pause in my next release. You can go back a few posts to see what's in that. Added to that I have added a button to enter the subscription (if you pay for it). Before anyone asks you cant use a key from another unit. The key has both model encoded in it. If someone pays for SUNA on an avic maybe but I don't have that as yet to test.
We will have to wait and see if Pioneer include the key in the official map update or make us pay extra for SUNA.
I'm working on getting around this before then so bear with me on that.
On the Alt. It is map dependant. IE the data comes from the MAP not the GPS so you will see issues. This was covered in Matts thread.
Cheers
34BY151
Posted May 15, 2009 · 15:40 UTC#36
thanx 34BY151, you have answered all my questions way above expectations :-)
I thought this will be some sort of unit/subsciption key missing, thus copying my original unit keys over the one in your release, but got the same "CA-TMC (No Key)" if the signal is god enough. I just got the unit less then a month ago, so thought for that "day robbery" price they would include this "sometimes available" SUNA :-(
Sound is great, credit to Pioneer for that as always, but no NTFS support is a shocker, since other WindowsCE machines have it. (thin clients running ce 5 and 6)
On top, they should hire people like you, to design the map interface for them :-) the original sucks more than some El Cheepo GPSes out there... (and hire me to look for bugs and flaws :-) ) Credit for the night version though,that is very nice, but the day is not up to the price tag.
To the key, I wonder if there will be some keygens or map unlocks, or rather EZRider hacks that remove the key, as most of PocketPC software have (tomtom,mio,igo,destinator,route66, etc. I have tested all of them on my PDA prior to this AVIC toy)
One should be able to get a decent unit without hax and MODs :-) at least from Pioneer... The world is far from perfect :-)
Posted May 15, 2009 · 15:49 UTC#37
Are you sure about that? I've never seen a WinCE device with NTFS support...
Posted May 16, 2009 · 01:47 UTC#38
I am going to double check that. I know CE 3 and 4 don't have ntfs for sure. Haven't had a 5 this year and need to get my hands on that HP t5530 again (CE 6) to make sure I am not misleading on this. :?
If Apple can have ntfs support, on top Parragon made a full implementation (more than 4 kb blocks and full security, why wouldn't it be on CE 5 or 6, I wonder... or just custom implemented for such a great company as Pioneer is, this is not the $300 cheapo unit, but one would expect Nokia to put a radio tuner on every phone and yet it doesn't happen.
Am I too demanding, or do the big companies just don't give a ... :-)
Posted May 17, 2009 · 02:45 UTC#39
I don't think Microsoft is pushing NTFS on CE devices, because while a far better file system than FAT, it is more CPU intensive than FAT. And generally, CE devices do not have as much storage as desktop systems.
FAT32 is sufficient for storage needs of something like AVIC... It's Pioneer's brain-dead interface to mass storage devices that is a problem here...
Posted May 17, 2009 · 04:28 UTC#40
I agree, who will have a Divx of more than 4 GB in continuous size :-) therefore fat32 is plenty and they made sure you cannot use the usb/sd for everything, that is definitely brain dead.
Has anyone MODed their unit within the initial trial of SUNA ?
How did you go?
Again, GREAT map interface MOD thanx to 34by151 & GTIMatt, I love it every day more and more, thanx again!! :-)
Posted May 24, 2009 · 10:09 UTC#42
Hi all,
Thanks 34by151 for your magnificent work (and all others whose mods were included in the download). I've put it in and the maps and voice work perfectly. However where I used to be able to pick up TMC information such as road work / accident etc and see this in the traffic screen and on the map, I now see nothing. The unit is telling me it is connected to 104.3 (the station I have always auto connected to to get suna info) but that there is no traffic information.
Does anyone have any idea as to where I've gone wrong?
Thanks in advance,
Clutrz
Posted May 24, 2009 · 10:35 UTC#44
Do I need all 3 of these? Or are they links to the same thing?
Thanks.
http://www.4shared.com/file/95580165/5b ... part1.html
http://www.4shared.com/file/95583929/2a ... part2.html
http://www.4shared.com/file/95577170/2d ... part3.html
You'll need them all, plus the other links further on in the posts to get the updated data.zip and phoneme stuff.
cheers,
Clutrz
Thanks Clutrz,
What's the best way to combine them? I'm assuming I need to.
Cheers,
Linc
Posted May 24, 2009 · 13:34 UTC#45
you just download them and expand the first using lets say RAR (www.rarlabs.com) the rest of them are spanned archives, they will be used in the expand process automatically. What to do after that is covered earlier (testmode, backup, etc)
Posted May 24, 2009 · 23:44 UTC#46
Thanks for the help guys all good now. I am use to rar archives being [name].rar, .r00, .r01 etc
Posted May 25, 2009 · 14:56 UTC#47
final proof, no NTFS on windows CE 6 either :-(
the three thin clients we use have linux,XPe and CE 5 and 6, I must have gotten confused. Sorry for creating hopes... :oops:
Posted May 31, 2009 · 11:59 UTC#48
Hi 34by151 just have a question about the first update you made. I've just bought a new Australian Version AVIC F900BT with V2 all ready on it. I've downloaded the 3 files you've first provided and found the test mode file to let me into the windows section. I deleted the sound files to get rid of the beep which works fine but I can't find the files "My Flash Disk\Update\APL2\iGo\CONTENT" and "My Flash Disk\Update\APL2\iGo\LICENSE" I dont have anything with "update" in it i.e i have found "My Flash Disk\APL2\iGo\CONTENT" and "My Flash Disk\APL2\iGo\LICENSE" which I added ".bak" too as instructed
But I don't quite understand this section (listed below) as I don't have anything saying SD Card\Update, and if I try to copy the first update file you provided from the storage card to the flash disk it says it's too big and will only replace some files until storage is full.
8. Copy The directories below SD Card\Update to "My Flash Disk". When asked say yes to overwriting files. Copies of the overwritten Files are contained in this release. The Main Files overwritten are DATA.ZIP EZRIDER.EXE and SYS.TXT copies of the original files will be copied to you flash drive as DATA.BAK, EZRIDER.BAK and STS.BAK These are the files from The V2.0 Firmware update
Many Thanks Glen
Posted Jul 19, 2009 · 17:03 UTC#49
to all the australian F900BT owners. I'm about to install my aussie F900BT as well, and was going to do the full hardware bypass(move the mute pin, ground both mute and parking brake wires) when I saw on one of the bypass threads that the EU units don't need the moving of the mute pin, and grounding of the mute wire(which is definitely needed on the US units otherwise they get the warning msg), and is actually detrimental ie. will drain the battery faster. I just saw on this post that the aussie version is identical to the EU version so now I'm not sure whether I should do the full hardware bypass or just ground the parking brake. I tend to leave my car sitting for maybe a week at a time, so wanted to be sure.
Can anyone with an aussie F900BT confirm if the whole mute wire business is required for ours?
BTW, I love the work on the aussie specific stuff, I'm looking forward to trying the mods out, and hopefully seeing if I can contribute any of my own, being a techie geek. thanks to all the contributers!
Posted Jul 21, 2009 · 15:07 UTC#50
Just ground the park wire, that is all the AUS ver. needs. Works for my f900bt. No pin magic, no software changes... :)
Page 2 of 20
