I know I'm digging this thread up but could someone please repost the Australian maps?
All the links are dead ![]()
hey I am new here and I have just bought this item and i know it is old, but can someone link me the full instructions and the latest maps for Australia. Thanks
Just downloaded the R19 aussie maps from here
they definatley loaded and are working fine although my map version still says 02.000400
Hi Guys,
I am a late bloomer with regards to owning AVIC. I would like to know where can I download the files from the first post. Is someone here still have them? I am buying an F500BT from US and I want to put australian map...
Please help guys,
Thanks in advance,
JH
Does anyone here have the australian firmware... bought the thing second hand and hasnt loaded since. the supposed australian firmware sd card had all the files swapped out with hardstyle. ![]()
Usual Disclaimer:
These files are for hobbyist use only. Use them at your own risk I can not be responsible for your actions if something goes wrong. Make sure you take a backup of your system prior to any changes
This Update is for V3 Firmware only
Contained in this release:
Test mode for V3
Australian Sensis R16.1 Map (Released June 09)
3D Bulidings
3D Petrol Stations
Updated POI's
Updated Speed Cam
Spoken Street Name Corections (Phoneme.ph file)
Map Warning Bypass
Updated EzRider
Updated SYS.TXT
Udated Map License files
Updated Terrain (more detailed evevations)
This release has been tested on the Australian AVIC-F900BT
Download files from
{C}http://www.4shared.com/file/160754980/9 ... part1.html{C}
{C}http://www.4shared.com/file/160828063/9 ... part2.html{C}
or
{C}http://www.4shared.com/dir/24382274/615 ... dates.html{C}
Instructions
This update will just fit on a 1Gb SD card but it is advisable to use a SD card greater than 1Gb.
1. Start your AVIC normally and verify you have the V2 Firmware installed.
2. Check your map version.
Go into Settings / Navi Settings / About / Maps
Your Maps will display Sensis R15.1
3. Check your frirmware version.
Go into Settings / System Settings / Service Information
Next to Version you must have 3.xxxxxx
4. Extract this update to the root of an empty SD card. Do not modify the directory structure and extract both files. The best software to extract with is winrar
5. Insert the SD card and Start the AVIC
6. Use Test mode to backup your unit.
Make a Directory called "Backup" on the below storage card and copy "My Flash Disk" to this directory
Read the AVIC411 Faq's If you are unsure on Test Mode or make a backup
7. Copy The directories below Storage Card\My Flash Disk to "My Flash Disk" on your AVIC.
Overwrite files as needed
8. Restart Your AVIC
9. Verify you have the new Maps
The Map will now be "Australia R16dot1 Sensis
10. Verify you have Buildings Working. Zoom into a CBD location to see buildings
11. Verify you have updated POI's.
Open POI's and search for McDonalds, you will find it under restaurants if browsing POI's
12. Verify Warning Bypass. Go to the map scraeen and restart the AVIC. Press Map and check the warning is bypassed
Enjoy
34by151
Hey man. Any chance you'd be able to reupload these somewhere? Would seriously, seriously save my life.
