Australian Map Update (R17 Maps Page 23)
By 34by151 · Mar 29, 2009in Hacks/Mods💬 481 posts👁️ 97,204 views
Page 18 of 20
Posted May 03, 2010 · 20:49 UTC#426
I am having a bit of trouble. I had the R17 maps installed from page 40 and was working great, when i installed the V302a and b and then the V303 part 1 and 2 from page 14 the skin came up well but the bluetooth no longer works i read the posts and am not sure what i need to do to fix it as there is conflicting information. their are 2 bluetooth updates on the 4shared site which one and how to apply? also is the R17 map on page 40 and the V303 from page 14 the same as this change is what seems to have done it.
thanks.
I don't know what you mean by page 40 this thread only has 29 pages
If you are having bluetooth issues it will be because MSN has been powered up, go into testmode and delete the msnd files from the save directory.
Also check you have the correct device in sys.txt
Cheers
34by151
Posted May 03, 2010 · 21:52 UTC#427
thanks 34by151,
sorry not page 40 it was page 24, where is the sys.txt located? and am i wanting to change it back to the us model code ening in UC?
Posted May 04, 2010 · 01:16 UTC#428
I deleted the Msn and Msdn files and still no bluetooth, when i try updating the BT software it keeps failing?
Posted May 05, 2010 · 14:44 UTC#429
If I remember right you have a US version?
If that is right don't put a UK or OZ BT patch on it as it does not have the same hardware.
If you must patch the BT do so with the correct version
IF the BT is not working there are plenty of threads relating the US BT issues, do a search
Cheers
34by151
Posted May 06, 2010 · 00:57 UTC#430
Yes i have the US model, i have downloaded all the different US bluetooth updates for the unit from pioneer and other sources and none of them are working it just says failed, i am thinking this is because of the fact that there is no version of bluetooth listed on the unit to update. can you please help me to copy the bluetooth software files from my original backup to the correct place in the V303 update of yours so that when i install it again it might work.
the blue light on the front of the unit comes on at the start and then it stays off.
Posted May 06, 2010 · 08:36 UTC#431
Ok, i have restored the back up from when i first loaded the r17 maps on and the bluetooth has come back and in the bluetooth software menu there is a version of Bluetooth software listed. For some reason the new skin in V302a onwards removes the bluetooth software on my unit.
34by151 can you please explain to me how i can copy the files from my back relating to the Bluetooth into the update with your 3d skin so when i re-install, it also loades the bluetooth software. also there are multiple sys.txt files all with different numbers and endings in the file so do i also need to delete all bar the UC one for me?
Thanks Again.
Posted May 07, 2010 · 09:57 UTC#432
You have a US model the has different hardware to the OZ ones. So putting on Oz or UK bluetooth patches is probally not a good thing, as is trying to downgrade them.
Try to put on the patches for your US model. If they wont load there are lots of threads dealing with this where you will you find lots of info. Just search for bluetooth
Cheers
34by151
Posted May 07, 2010 · 10:32 UTC#433
The US patches were not working, at the moment i am running the R17 maps that you posted first without the skin mods and the bluetooth works fine, i just want to know how i can copy accross the relevant files i curently have into the updated Skin map update you created so as it keeps the same bluetooth files when i do the update with your skin.
I did a search but it is not answering the problems related to what i have expierenced apart from loading in new BT software which did not work.
Posted May 07, 2010 · 16:18 UTC#434
Hi 34by151,
Just to clarify - if i downloaded and have applied ONLY the files from
V3UPDATE03.part1.rar
V3UPDATE03.part2.rar
from your site and nothing else, do I still need to then go 'backwards' and apply the older files
V3UPDATE01.part1.rar
V3UPDATE01.part2.rar
V3UPDATE02a.rar
V3UPDATE02b.rar
As you mention
Contained in this release:
Autoboot Installer
Australian Sensis (WhereIs) R17 Map (Released Feb 11 2010)
3D Buildings
3D Petrol Stations
Updated POI's
Updated Speed Cam
Spoken Street Name Corrections (Phoneme.ph file)
Map Warning Bypass
Updated EzRider
Undated Map License files
Updated Terrain (more detailed elevations)
So i am assuming that the
V3UPDATE03.part2.rar files is the most upto date package with all past updates?
Posted May 07, 2010 · 20:37 UTC#435
Update01 is the V16.1 maps
Update 02b is the skin
Update03 is the V17.1 maps
So if you want V17maps and the skin apply Updates 02b and 03
If you want to do it all in one go
download updates 02b and 03
Extract 02b to your hdd
Follow the instructions on page 23 up to step 5
Copy the files extracted for 02b to the update dir on the sd card (with the folder structure)
Resume instructions on page 23
Cheers
34by151
Posted May 11, 2010 · 09:34 UTC#436
can you please explain how i can copy the files from my back relating to the Bluetooth into the update with your 3d skin so when i re-install, it also loades the bluetooth software. also there are multiple sys.txt files all with different numbers and endings in the file so do i also need to delete all bar the UC one for me?
Posted May 12, 2010 · 09:55 UTC#437
You cant copy the BT it is installed with the OS. The best way to load new bt software is with the update feature in the phone, however this does not relate to this thread. There are lots of threads on this do a search for them.
The only file that is read is sys.txt. This must have the correct device line for your model.
Samples are provided for most models in the apl2\igo directory. You may rename the one for you model to sys.txt if you wish
Cheers
34by151
Posted May 12, 2010 · 12:38 UTC#438
Thanks I will give it a shot. The only reason i was asking here is because the BT software is totally erased when i load the new map skin on.
Posted May 12, 2010 · 20:28 UTC#439
What software are you refering to. The data.zip supplied nor any other data.zip does not contain any BT software. The BT software is part of the os boot image. If that was erased you would not get an operating system at all
Cheers
34by151
Posted May 13, 2010 · 00:14 UTC#440
I mean when the unit turns on after the New skin has been installed the Blue BT light is no longer on and when i go to the update BT software screen there is now software listed at all so for some reason it is removing it, as when i go back tot he standard R17 map the BT version and software are displayed in the update BT screen. I think Beluga had the exact same prob as me earlier in the thread but i am not sure if he managed to fix it.
Posted May 13, 2010 · 03:30 UTC#441
Maybe you should PM him. changing the map files has nothing to do the bluetooth. If you have "software not found" in the phone menu the OS has not loaded the drivers. Again lots of info on this if you search.
Cheers
34by151
Posted May 13, 2010 · 08:56 UTC#442
Hi 34by151
Im just wondering how can I verify if I have SUNA working correctly?
Just to summarise
- Im in Melbourne
- Euro F500BT with 2.07 firmware and all your 2.0/2.0a/SUNA updates installed and 15.1 maps. Working fine.
- In traffic menu, I see the blue signal that goes up and down and it says "TMC present", but I have yet to actually see any reports... it always says 'no traffic updates'.
I havnt used the unit for long yet, so perhaps I havn't encountered any situations?
Another quick thing, I noticed I have 2 DATA.zip files, one inside the APL2 folder and another in APL2/iGo. I know the iGo one is the active one, but was wondering if its normal to have 2? One is 8.77mb and the other one inside the iGo folder is 7.03mb. No problems with unit , but was wondering which one should be placed in iGo?
Best regards and THANK YOU always for the help you offer.
Mike
Posted May 13, 2010 · 09:56 UTC#443
If you have V2 firmware SUNA will not be working because you will not have a subscription.
If you upgrade to a legit V3 SUNA will be activated, that is assuming you have an OZ version Avic and Update.
Igo will ignore the extra data.zip that you have in the APL2 directory, you can delete this file
Cheers
34by151
Posted May 13, 2010 · 11:37 UTC#444
Cheers
34by151
Thanx! Regarding the last line .."assuming you have an OZ version Avic" ... If I buy the legit v3 from Pioneer Aus, Will SUNA work then? Given I do have the Euro F500BT, but if I buy the Aus v3 , wouldn't my unit be effectively the same? The only thing i can think of , changing the device line back to the EU model number...would that disallow SUNA to work?
Regards
Mike
Posted May 13, 2010 · 11:59 UTC#445
I can't answer that as I don't have a 500 or an EU500, so i can't confirm that for you.
But I think you have answered your own question. They cant be the same if you have different device ID's.
Does that mean the TMC tuner is the same, I don't know
If it is the same will the update work, Don't know
I can tell you that the EU BT update worked on Aus models, not that that is the TMC but it's hopeful.
From the OEM code I can tell you the differences are minor. The AU just has options present in the EU version commented out and bypassed.
I think this is more because pioneer did not want to spend on testing. it was cheaper just to disable. I have not found anything code wise that will not run on both.
so for a few hundred bucks for the update it is worth a punt
Cheers
34by151
Posted May 14, 2010 · 08:16 UTC#446
Thanks again 34by151, you were right. I managed to get the BT working with the new Skin and now everything is good.
Posted May 14, 2010 · 14:02 UTC#447
just one issue, whenever the phone rings the gps map comes up first and then the phone call id will show, is this normal?
Posted May 16, 2010 · 08:03 UTC#448
Yes it is
Cheers
34by151
Posted May 18, 2010 · 12:00 UTC#449
Cheers
34by151
Hi, I am just trying to get the skins to install just not 100% sure what to do - I did the V3 update03 with new maps on a X910BT US unit and seems ok so far, now i want to upgrade the skins as per your instructions i downloaded V3UPDATE02b.rar
Within this rar file is 2 directories
testmode
My Flash Disk --> inside this directory is APL, APL2, Utils
So what i did (not sure if this is correct)
I used the same directory structure when i did the V3update03 but just cleared the contents out on my SD Card
So from V3UPDATE02b.rar i copied the testmode directory into the root, then i copied the directories in the 'My Flash Disk' to the Update directory, the backup directory i just cleared from my card.
I also updated the sys.txt file to reflect my US version.
So my card just basically has
Update
testmode
WHen i turn the system on with the SD card in the head unit it goes straight to test mode , how do i then apply the V3UPDATE02b updates for the skins, i know for the V3UPDATE03 it has pop ups that drives you through the process.
Posted May 22, 2010 · 01:07 UTC#450
If you want the the V16.1 maps, use Update01 and follow the instructions posted
If you want the the V17.1 maps, use Update03 and follow the instructions posted
If you want the the Skin, use Update02b and follow the instructions posted
If you want both V17.1 maps and the skin you have 2 options
Option 1 (Both at the same time)
1. Download Update02b and Update03
2. Follow the Update03 instructions up to and including step 4
3. Extract Update02b to you hard disk
4. Copy the files extracted from Update02b on to the SD card
* copy the files to the sd card update directory
* retain the directory structure
5. Your sd card will now have in the update directory these subdirectories
APL
APL2
Utils
6. Continue on with the instructions for Update03 (step 5)
Option 2 (One at a time)
1. Follow the Update03 instructions
2. Follow the Update02b instructions
You can do either one first it does not matter
Cheers
34by151
Page 18 of 20
