Yes I did that first I'm not quite that incomp pmsl. It's not booting with those files.
Australian Map Update (R17 Maps Page 23)
Earlier you wote
I'm running your setup although It's an older beta
so is that not the case now?
Cheers
34by151
Hi 34by151,
Ok it turned out to be a problem with my Mac OS X creating hidden files on the SD Card. Formatted using VMWARE Fusion with win7 and it's all updating fine. Great work once again for the update and can't wait for the next skin.
Cheers,
OZNC
Hi 34by151
when you said "Alter the decives section of sys.txt to your model version" , I was wondering what is the model version of the European F500BT ? I wasn't sure if theres a difference in Eu F500BT and EU F900B
Also , my desire is to convert my EU F500BT to aus. At the moment I have version 1 firmware. Im a little confused right now. Can i download the v2 firmware from the aus pioneer site , or do i have to download it from the EU site since my unit is EU (and then later upload the aus maps) ??
Many thanks,
Mike
Hi 34by151,
Cheers,
OZNC
Good to hear glad you got it working and solved your Mac problem, Long live the penguin ![]()
Cheers
34by151
First up either purchase V3 from pioneer spares or download it on this forum. I'd recommend purchasing it though.
Look at the sys.txt from you backup.
Replicate the line in the [device] section to your new sys.txt
I don't have the correct device line for you off hand but you can easily search for it
Cheers
34by151
Cheers
34by151
Thanks ! I found the EW device number. Its all starting to come together now. Re: the firmware, I rang pioneer and a retailer and it is sold only as a bundle (maps + v3) for approx $200, correct?
That is a little steep, perhaps i will stick with v2 mods.
I think i might be missing something as i updated to the unofficial V3 and the R17 OZ Maps on my US Model and it works fine. What is the reason for changing the sys.txt file?
I just installed the update and map for v2....worked great! Thanx so much! ... Is it ok that its installed on 2.007 (from EU site) , rather than the aussie 2.0 ? So far so good but just want to double check.
Thanks again!
The only reason for rebooting due to map is if they are missing, so i don't think this relates to you map update. I suggest you read the unofficial update thread as the answers you need will more than likely be there.
The reason for updating the device line is it tells igo (the nav software) what model you have. This sets up the hardware used. Ie using a uk or aus model on a us unit will attempt to start the TMC hardware that you do not have. Always make sure you have the original device in sys.txt when every you replace sys.txt
cheers
34by151
I rang pioneer and a retailer and it is sold only as a bundle (maps + v3) for approx $200, correct?That is a little steep, perhaps i will stick with v2 mods.
That is correct it comes with the V15.1 map (2 generations behind). The main reason for updating is that nobody is doing any work on the V2 firmware. So if you want mods you will have to do that yourself.
V3 is an updated version of Igo (V8.3) so that also comes with new features. Al ot of the new mods exploit these features. Also the latest maps are 16.1 which are almost 2 years old now. I doubt you will have a new map update for the old version into the future.
If you think the $200 is to steep look into the unofficial update on this forum
Cheers
34by151
Yeah EU and OZ are mostly the same. The main reason for the different models is to stop the oz units using features eliminated from oz models none of which effect anything in the nav.
BTW you still need to set the device line in sys.txt correctly
For everyone with non Oz models, the new V3 skin works on all units out of the box. Longer do we have 4 versions for the hardware types;
US With MSN
US without MSN
TMC
Non TMC
The installer will ask you what Model you have (ie 500,700,900 ect)
Then it asks for your hardware region (US,EU,OZ)
From these answers it sets up the sys.txt and the variables in the nav software
In the Settings/regional screen you can select these option if you have set things incorrectly
All of the code refers to this section to enable and disable features related to hardware. IE if you cant select man if you don't have an msn model. This stop msn code starting and breaking the blutetooth functions on the other models. In fact you will never find any of the msn buttons unless you have an msn model selected.
BTW this will not make having and MSN model and MSN selected will not make MSN work outside of the US as you will not have any data received by the radio.
Cheers
34by151
[If you think the $200 is to steep look into the unofficial update on this forum
Cheers
34by151
Hi, I saw the unofficial update in a couple of places on the forum, however in one of the threads, for the EU 3.00 , they started to mention after a page that it is only an 80% upgrade for the F500 model, and in the other thread (main one on hacks/mods page), no one could confirm whether it would work with the f500 , with one of the reasons being that the button sequence code cannot be performed on the F500 due to lack of an eject button. A couple people appeared to have problems with that. So im not quite sure where to find a confirmed F500 compatible version.
Mike
I cant comment on the F500 unoficial update as I have not seen it or done one myself.
I recomend you get the oficial update, you are probally best to get the one that matches your model IE US / UK or OZ. I'd expect the US and UK ones to be cheeper
Cheers
34by151
I cant comment on the F500 unoficial update as I have not seen it or done one myself.I recomend you get the oficial update, you are probally best to get the one that matches your model IE US / UK or OZ. I'd expect the US and UK ones to be cheeper
Cheers
34by151
Thanks, but sourcing the UK one might be difficult. I did find a US one on ebay
http://cgi.ebay.com.au/NEW-Pioneer-Map- ... 1718wt_940
Which is roughly a 90 dollar saving from locally... however as you stated , wrong region.
Regarding sys.txt what i did was just alter the device line in the SD card on my laptop , then put SD card in avic unit and copy to flashdisk, etc?
US With MSN
US without MSN
TMC
Non TMC
Cheers
34by151
Where can i download the V3 skin from?
Also i have looked everywhere but i can not find the screen that shows the speedo and other info in IGO i think they call it a cruise dial, does anyone know?
thanks.
If you read or search this thread you will find all the answers
The files are here
http://www.4shared.com/dir/24382274/615 ... dates.html
Cheers
34by151
You need the first one V3UPDATE01 this has the basic mods plus the maps. The Skin starts with V3UPDATE02. You can miss V3UPDATE02 and jump right to V3UPDATE02c. If you apply betas you must install the full update before that but can jump to the last beta.
Yes i remember reading that now, i cant see the V3Update02c only V3 update 03 is this the one i want for the skin? also i do not currently have the 3d buildings in the r17 maps am i supposed to and does it have the cruise dial in IGO? thanks.
Just Apply the updates in order skipping 01 as that is the V16.1 maps. 3d buildings and cruise ar in the skin
Cheers
34by151
Hi 34by151,
Just like to send out my Thanks to you - just got my X910BT from the US with V3 on it and ran all your updates and its all looks good so far! - great unit.... need to still play with it a bit more.
Also thanks for taking the time to reply to all my PM's in the past.... i know you probably sick of the same questions...but you still answer them all!
I havnt tested it yet on the road but in my garage i can pick up the satellites and streets etc.... where as before it picked up nothing.
I'll just search around to see what futher 'hacks' are available to make this unit better!!!!
Keep up the good work!!!!
34by151, i also want to say thanks for all your help and hard work! the maps looks great, just one question with the Lang US, sounds, and speedcam files from your download site, do i need to copy these accross or is that allready done in the R17 map update? and if so is it just a matter off copying those files into he respective folders of the IGO program on the unit?
Thanks Again.
I have no message other than to also say a big THANKS to 34by151 for all his hard work and help.
34by151, i also want to say thanks for all your help and hard work! the maps looks great, just one question with the Lang US, sounds, and speedcam files from your download site, do i need to copy these accross or is that allready done in the R17 map update? and if so is it just a matter off copying those files into he respective folders of the IGO program on the unit?Thanks Again.
Just apply the V3Updates in order, follow the instructions in the thread and all will be ok
Cheers
34by151
34by151
I am having a bit of trouble. I had the R17 maps installed from page 40 and was working great, when i installed the V302a and b and then the V303 part 1 and 2 from page 14 the skin came up well but the bluetooth no longer works i read the posts and am not sure what i need to do to fix it as there is conflicting information. their are 2 bluetooth updates on the 4shared site which one and how to apply? also is the R17 map on page 40 and the V303 from page 14 the same as this change is what seems to have done it.
thanks.
