Australian Map Update (R17 Maps Page 23)
By 34by151 · Mar 29, 2009in Hacks/Mods💬 481 posts👁️ 97,204 views
Page 16 of 20
Posted Apr 08, 2010 · 06:06 UTC#376
I downloaded from both the links above. then unrar them
So onto step 3
Cheers
34by151
My question is - does sys.txt and data.zip exist inside the unrar'ed folders?
Posted Apr 08, 2010 · 09:35 UTC#377
No, these have nothing to do with a map update
Cheers
34by151
Posted Apr 08, 2010 · 10:46 UTC#378
ok cheers. it went well. thanks heaps
loon
Posted Apr 08, 2010 · 22:28 UTC#379
Hey 34by151!
FIrst of kudos to you for all your hard work! Loving my unit now more than ever!
As mic18u mentioned in a previous post... I did not receive a message at the end to say the installation was complete.
I waited just over an hour and then rebooted it and it seems to have done it. When I check the version it now displays R17.
Was there something I might have been doing wrong?
Posted Apr 09, 2010 · 01:22 UTC#380
I called Pioneer Aus this morning to inquire about getting V3 for my Aus F900BT (currently on V2) they put me through to the technical department that told me to download (from the Pioneer Aus website) the v3 software for the F910BT and load that onto my unit as that was how you get V3. Does this sound correct?
He also didn't mention having to load into service menus, formatting, etc so I have to assume everything is included in the update from Pioneer. Will be giving it a try tonight I guess if anyone can confirm for me?
IF this works, then loading the V17 maps should be as easy as download, unzip onto a clean SD and insert into the unit and let it do its thing?
Posted Apr 09, 2010 · 11:53 UTC#381
Hey 34by151!
Nope all ok, don't know why you did not get the message. The installer does an xcopy of the update files the the message. It will take about as long as the pioneer update to perform
Cheers
34by151
Posted Apr 09, 2010 · 11:56 UTC#382
Even if you have the v3 update you will need the code for your unit. As far as I know you cant get this without paying for the upgrade. If you were part of the free upgrade you would have had your copy by now
Once you have v3 on your unit just follow the instructions on page 23
Cheers
34by151
Posted Apr 09, 2010 · 22:38 UTC#383
Cheers
34by151
This is what I thought but when I called and asked spare parts about it, that's when I was transfered to the tech department and given the above information, guess I'll have to call back again until I get someone in spares that knows about it. Only thing offered was a April 09 map update for $270 and she said it didn't carry v3 upgrade as well.
Posted Apr 09, 2010 · 22:59 UTC#384
That sounds like the one. It will have 2 sd cards. The first one is the v3 update that also enables SUNA TMC but this will not work if you have a us model. In that case you need to alter the sys.txt to have the correct model after that update or use a us update set.
Once you have updated to V3 then do the map upgrade.
Cheers
34by151
Posted Apr 11, 2010 · 11:40 UTC#385
Works great thanks!
After a few very frustrating calls to Pioneer Aus to try n get Ozy maps for my US version gps unit x710bt, i tried this n with a bit of messing around it worked perfectly. cheers!
Posted Apr 15, 2010 · 05:16 UTC#386
TTS voices do not work for the reasons you have found. It's actually an Igo problem. You have to use non TTS voices
Hi everyone and thank you 34by151 very much for all you've done! I've installed the V17 map updates and was wondering if anyone has found away around the TTS issue yet (apart from not using TTS)? I've always found the TTS very helpful and would love to be able to get it working again if anyone's found a way?
Thanks and kind regards,
Clutrz
Posted Apr 15, 2010 · 09:42 UTC#387
Funny enough I have updated TTS software but have not had a chance to test it either on the AVIC or with the new maps. The Skin is taking all my time and I need to get that finished first.
Once we have released the new skin I will look at that, I suspect I will have a solution
Cheers
34by151
Posted Apr 16, 2010 · 01:54 UTC#388
You are a champion! Thank you very much.
Posted Apr 17, 2010 · 05:37 UTC#389
Signposts display is controlled by the skin and can be altered by changing the settings in you sys.txt and the signpost.ini in the data.zip
Found the laneinfo_signpost.ini file in the data.zip, increased it to 18 and it looks perfect thanks! I also changed the signpost_coloring value to 0 in the sys.txt so the signs come up green. I guess that when set to 0 it uses the value set by signpost_background_color, otherwise it uses the values in signpost_colors.csv.
I tried to change the _axx.xpd file so National Route shields (black on white) appear correctly - currently they appear as State Routes (white on blue). I copied the National Highway values and changed the colours to black on white - nothing changed. The original R15 maps had them appear correctly, but for some reason they don't anymore. They are definitely National Routes according to the map though (N23 and N52 around these parts).
Posted Apr 18, 2010 · 11:53 UTC#390
the new skin has the ability yo change the signpost colour (green/blue), size(normal, Small,Big) and display mode (Allays and on route)
Cheers
34by151
Posted Apr 20, 2010 · 11:20 UTC#391
Hmm....need any beta testers soon 34by151???
Think i will be up for it..... :D
Posted Apr 20, 2010 · 11:39 UTC#392
We have some in each region, however we will be announcing that in the the Hybrid thread. There will be a few things needed at that stage especially those that can contribute to the manual
Cheers
34by151
Posted Apr 22, 2010 · 09:40 UTC#393
How do I boot from SD?
Cheers
Posted Apr 22, 2010 · 12:13 UTC#394
Cheers
Insert SD card, turn on ignition
Cheers
34by151
Posted Apr 22, 2010 · 12:26 UTC#395
That's what I thought but it's not working. 4gb card with the 3 folders but won't boot into testmode or run the setup.
V3 firmware installed on a F90BT
Posted Apr 22, 2010 · 12:56 UTC#396
Is the card formatted as FAT32?
Are the folders execrated in the root dir as per the instructions?
cheers
34by151
Posted Apr 22, 2010 · 23:32 UTC#397
Yes to all and I'm running your setup although It's an older beta
Posted Apr 23, 2010 · 09:39 UTC#398
Follow the instructions on page 23
Cheers
34by151
Posted Apr 24, 2010 · 05:15 UTC#399
I thought I had it just won't boot into testmode
Posted Apr 24, 2010 · 05:32 UTC#400
How about instruction 1? "Download the 2 rar files to your computer"
You said you were not using these files
Cheers
34by151
Page 16 of 20
