Sensis (WhereIs) R17 Map
Sensis Release Date Feb 11 2010
Usual Disclaimer:
These files are for hobbyist use only. Use them at your own risk I can not be responsible for your actions if something goes wrong. Make sure you take a backup of your system prior to any changes
This Update is for V3 Firmware only
Contained in this release:
Autoboot Installer
Australian Sensis (WhereIs) R17 Map (Released Feb 11 2010)
3D Buildings
3D Petrol Stations
Updated POI's
Updated Speed Cam
Spoken Street Name Corrections (Phoneme.ph file)
Map Warning Bypass
Updated EzRider
Undated Map License files
Updated Terrain (more detailed elevations)
This release has been tested on the Australian AVIC-F900BT
Download files from
http://www.4shared.com/file/255176936/71433445/V3UPDATE03part1.html
http://www.4shared.com/file/255182192/8fe049e8/V3UPDATE03part2.html
Requirements
1. Your AVIC MUST HAVE V3 firmware pre-installed. If you are unsure about this search and read the forums on how to work this out
2. 1 Blank SD card 2GB or larger
Instructions
1. Download the 2 rar files to your computer
2. Put the Rar files in a new directory and extract them using winrar
3. Insert a blank SD card into your computer
It MUST be blank (no files at all on it)
It MUST be formatted using the FAT file system
It MUST be 2GB or larger in size
No exceptions to this
4. Copy the 3 extracted directories to the SD card
5. You will now have created an SD card with 3 subdirectories (backup,update and testmode) in the root
6. Boot your AVIC on the SD card and follow the on screen instructions
NOTE:The Installer will create a backup of your AVIC in the backup directory before updating the maps
Enjoy
34by151
