GTIMatt's Mods
By GTIMatt · Mar 23, 2009in Hacks/Mods💬 346 posts👁️ 60,843 views
Page 1 of 14
Posted Mar 23, 2009 · 16:28 UTC#1
After a few requests I have posted my data.zip file for anyone who wants to try it out. I've put a couple of screenshots below to show how it looks when a route is present and when it's not.
Here is a list of mods included in my data.zip:
Change to linear compass and move
Move clock and reformat
Add GPS strength indicator (Click to see GPS detail)
Add UK style Speed Limit Display
Clean up route blue boxes
Add 2 new blue boxes: 1 for clock, compass and speed limit and 1 for route info
Remove Map Scale
Moved speedcam warning box to bottom right
Move 2D and Info button to top of screen
Add POI button (visible whether route active or not)
Added new buttons for when no active route - Find Address, Go Home, History and Favourites)
Add buttons for when route is active (Delete Route and Mute/Unmute voice)
Changed Route info to show date, elevation and speed when no route active (when route active fields displayed are the ones set in settings)
Press actual street icon for traffic
Moved stop simulation button so it doesn't cover my custom buttons
Display house numbers by clicking on current street name (click on house numbers to remove)
Display Lat/Long when clicking on compass (remove by clicking on Lat or Long)
Call Itinery from next street name bg
Show Turn Restriction Graphics
Toggle between Time/ETA to dest
Toggle between Time/ETA to Waypoint
Toggle between distance to dest/distance to waypoint
When distance to dest changed to waypoint change time/eta to dest to time/eta to waypoint and vice versa
Stop/Start record track by clicking on clock, clock is white when not recording and red when it's recording
Speed Camera Warning Changes:
- Show correct camera type icon in warning box
- Spoken warning stating Camera type and speed limit (note: voice in English and only in mph for standard UK speed limits)
- Beep (not barking dog!) if over speed limit in last 500ft before camera (only on fixed and redlight+speed)
- Average camera warning now shows average speed for section (before it showed distance which was always zero)
- Press camera icon on average speed warning to cancel warning as standard igo expects the cameras to come in pairs but in the UK there are sometimes an odd number so it leaves the warning active until you turn the system off.
Known Issues in this release:
No spoken warning on average speed cameras
No overspeed warning on average speed cameras
Spoken warnings aren't always heard if when navigating if it occurs when an instruction is being said (happens when guidance muted or unmuted)
Average speed warning sometimes shows an incorrect average speed in the thousands!
AS USUAL ALL THE USUAL DISCLAIMERS APPLY! I HAVE BEEN RUNNING THIS EXACT DATA.ZIP ON MY SYSTEM FOR THE PAST 3 DAYS AND HAVE HAD NO ISSUES OTHER THAN THOSE LISTED IN THE KNOWN ISSUES SECTION. HOWEVER YOU USE THIS FILE AT YOUR OWN RISK AND I CANNOT BE HELD RESPONSIBLE IF SOMETHING GOES WRONG! ALWAYS TAKE A BACKUP COPY OF ANYTHING YOU REPLACE SO YOU CAN RECOVER FROM ANY ISSUES THAT MAY ARISE. IF YOU FIND ANY BUGS IN THIS PLEASE POST IN THIS THREAD AND I WILL TRY TO DEAL WITH THEM (PLEASE BEAR IN MIND I HAVE A REAL JOB, LOL).
To install follow these instructions:
Download GTIMatt.zip from here:
http://www.mediafire.com/?y31qmnfnjqi
Unzip it, there will be 2 files, DATA.ZIP and transportm.ttf (this is the std UK traffic sign font and is needed for the speed limit mod). Copy both of these files (don't forget to back up DATA.ZIP) to My Flash Disk\APL2\Igo on your avic.
Hope you enjoy it and please post any feedback in this thread.
Matt.
****** 25th March ******
Added call to find address from the 2nd instruction box so that an address can added when a route is active as per a request (useful for quickly adding a via address).
****** 28th March *******
Here is a link to a beta version of my mods: http://www.mediafire.com/?nymzknfxq5n
This is the first version of incorporating km/h (30kph-120kph) and extra mph (such as 45mph mainly for US users) warnings into my data.zip. I have added an option of custom to the existing off, simple and when approaching audible options. If you select custom you can then click on the spanner to get to the sub options. Here you can set if you want to be warned in mph or km/h. I have done some brief testing without any issues but I'd love it if anyone wanted to try it out and see if they come across any problems. I have had a lot of requests for adding the km/h warnings so I wanted to get it out as soon as possible even if I haven't tested it fully.
*****I've found a problem with my latest mod, the barking dog is back. I think it's because I added the custom option to the warnings as value 3 and the pioneer code doesn't understand it and seems to default to the simple option. so the dog barks when you are over the limit. I think I know how to fix it but I won't get the chance to look at it until tomorrow.*****
**** 29th March ****
Think I have fixed the barking dog issue mentioned above, I tested it on a camera and the dog didn't bark, just gave my custom warning and beeped for being over the speed limit. The link from 28th March points to the new fixed version. Let me know if you still have problems.
*** 4th April ****
Posted new version. See here: http://www.avic411.com/forum/viewtopic. ... 35#p157535
*** 9th April ***
Posted ner version. See here: viewtopic.php?f=34&t=23003&p=158721#p158721
Posted Mar 23, 2009 · 17:43 UTC#2
Thank you very much for sharing. I've been following your mod with much interest. I'll try it on my f700 today and comment on the result. :D
Posted Mar 23, 2009 · 18:11 UTC#3
Thanks Matt.
One of the cleanest, well thought out Mods I've seen to date.
Posted Mar 23, 2009 · 22:15 UTC#4
I opened up the sound file and played them, they seem to be cut off at the beginning. is that correct? Also how do I get the Itinery screen up cause you said "call Itinery" not sure what that means.
Can the custom boxes color be changed to a small shade of red? Im looking at the code and im not exactly sure where to begin.
thanks!
Posted Mar 24, 2009 · 00:07 UTC#5
I am getting an invalid file when downloading
Posted Mar 24, 2009 · 08:25 UTC#6
Hi Matt,
I love the mod you've done and I'm going to try it on my Australia F900BT. It's the best looking one I've seen yet.
Just one question? Will the ogg speed files you've added still work in kph?
Posted Mar 24, 2009 · 08:43 UTC#7
hey gtimatt,is it possible for you to show mods indivudially so that we can apply the ones we like? like the one with lane information and so.
Posted Mar 24, 2009 · 09:18 UTC#8
Not sure what happened but I just downloaded it onto my work PC without any problems. I did notice however that as I zipped it up on my mac when you open the zip there are some mac os files there and you need to go into the GTIMatt folder to get the data.zip and the font files that you need to copy to the avic.
Posted Mar 24, 2009 · 09:24 UTC#9
Hi Matt,
The sound files will play but obviously will say a speed in mph and it won't be straight swap so it won't say 50mph in a 50kmh zone but probably something like 30mph in a 50kmh zone (hope that makes sense!). I had to join 2 sounds together (the camera type and speed limit) and as I don't need kmh I didn't bother making them. I do have the original sounds though if you wanted to make the files yourself. I have also commented the code in common\ui\speedcam.ui to show what should need to change if you use kmh.
Posted Mar 24, 2009 · 09:30 UTC#10
That would be quite a lot of work as it took me a lot of time to put these together. I have however commented all the code for each mod so I'd suggest you download the zip and have a look through it and if you had any questions I'd try to answer them. A lot of the mods are detailed in some of the other threads here though. If there was 1 or 2 in particular that you were interested in I could post more detail but not for the whole lot.
I'm not sure what you mean about the lane information as I didn't make any changes to that, the lane information you can see on my screenshot is standard funcationality.
Posted Mar 24, 2009 · 09:32 UTC#11
Matt,
Would love the sound files I can have them. I just put on my unit and the speed and alt all shows in kms and meters which is great. I can play with the sound files when I have time.
Do I need to activate the speed warning in settings for it to play the ogg files or is it all built into the data zip.
Thanks for you help.
Michael
Posted Mar 24, 2009 · 09:41 UTC#12
thanks!
I just downloaded the file to my work pc and the ogg speedcam sounds played as I would expect them too there was nothing cut off.
The itinery screen is displayed when you have a route and you click on the long blue box at the top of the screen showing the next street.
I created new boxes so if you want them a different colour then you will just need to replace the bmp files in ui_pioneer\800_480\ with ones looking like you want. I used Paint.NET to create a png and then used iPaq 31x image explorer to convert it to an igo format bmp to keep transparancy (both these programs are free). The bmp you will need to change are:
st_info_bg.bmp - box containing compass, clock and speed limit
info_bg.bmp - route info box
746_32K_OM-003_32.bmp - Next Instruction box
746_32K_OM-005_32.bmp - 2nd Instruction box
746_32K_OM-007_32.bmp - Next street box
tr_bg.bmp - background for turn restriction (only shown when a valid turn restriction is present)
Hope this helps
Matt.
Posted Mar 24, 2009 · 09:51 UTC#13
Matt,
Michael
Michael,
I think you need to activate the warnings (mine has always been turned on) but it doesn't matter about the sound warning as it sets that in the data.zip to use the custom ogg files rather than the standard one. If you want to go back to standard warnings then there is a commented line of code in common\ui\model_variables.ui that you should be able to set to go back to a standard audi warning (off, simple etc) but I haven't tested this.
I have attached the sounds I used as the basis for my warnings. BorisM has also posted some sounds that are already combined and include kph ones but they sounded a bit robotic to me so I decided to make my own.
Anyway, enjoy!
Matt.
Posted Mar 24, 2009 · 10:00 UTC#14
akkasoglu, I think the lane information appears when you upgrade the maps. I've just update my Aussie maps from V14 to V15.1 thanks to 34by151 and the lane information appear automatically. I was using a stock data zip.
Thanks Matt for the audio files. When I get them done I'll upload them if that's okay so that any other kph folk can use it.
Posted Mar 25, 2009 · 00:30 UTC#15
After putting in my HD radio module I decided to give your mod a try. Haven't driven anywhere but appears to be working. Am a little worried though because my gps was showing weak to average signal. But after a few minutes it went up to high. I hope I didn't knock it down from where I had it mounted in the dash.
So good job on all you did.
Posted Mar 25, 2009 · 03:35 UTC#16
Matt,
Had a drive with your data.zip today. It's very good. Clean and easy to read and it has everything on the screen.
I've made kph ogg files as per yours and uploaded them into the same location (I deleted the mph ones) and I've called them 0_30kph.ogg, 0_40kph.ogg 0_50kph.ogg etc. Do I need to update any scripts to work with the new kph.ogg files? I don't have many speed cameras near my house to test it on but I want to make sure i've set it up right so that I can go for a big drive and test it out on a few redlight cameras.
Also is there any other areas that you modified to display mph instead of kph?
Michael
Posted Mar 25, 2009 · 06:46 UTC#17
Hi Matt,
Before i put the data file on my system, question: is there a button to put in a new destination while there is allready a route active???
Or is it possible for you to make this mod for me?? I think its not very hard. I've tried with the mav mod. But my knowledge of programming is not very big.
Thanks in advance
Posted Mar 25, 2009 · 07:40 UTC#18
Matt,
Michael
you will need to modify speedcam.ui in common\ui to call your sounds instead of mine, you will also need to replace the runif commands to call the correct sound for the correct speed (I've commented the code with the chunk you will need to use).
I don't think there is anywhere else that I hardcoded mph so everywhere else should so whatever units your system is set too but if you find anything that doesn't then let me know.
Matt
Posted Mar 25, 2009 · 07:41 UTC#19
Hi Matt,
Thanks in advance
I can probably make this change for you, I just need to find a good place for the button as it's pretty cramped at the moment.
Posted Mar 25, 2009 · 08:58 UTC#20
Matt,
Michael
hey lacehim.. if you succesfully done this, would you mind sharing it... I think like me alot of people would love gtimatt's mod in combination with kph sounds instead of the mph ones...
Posted Mar 25, 2009 · 09:14 UTC#21
Matt,
Michael
It would be great if you could upload your sounds and I will incoroporate them into my data.zip as well by hopefully choosing the correct version based on the speed limit unit of the speed camera as there seems to be others who would like to use this file but want the speedcam sounds in kph.
Posted Mar 25, 2009 · 11:59 UTC#22
I've just finished modifying GTIMatt's data.zip with kph sounds as per his original spec. Australia has a number of differing speed limits so I've increased the number of files from 30kph (any slower and you could get a ticket walking) through to 110kph in 10kph increments. I haven't tested it yet and also I don't know if I have got it right because I haven't done much data.zip modification. I will be loading it on my unit tomorrow morning and I will make a test speed camera on a nearby street corner.
Maybe you could give it the once over Matt to make sure I haven't stuff it up. I hope it's okay for me to upload the modified Data.zip to share. You've done a great job and hopefully this helps out all the European and Australia owners in kphland.
Here's a link to the data.zip if you are desperate to test it out and another just for the audio files I mashed together from GTIMatt's audio files. I just used the female ones but making a male one shouldn't be a hassle.
GTIMatt's Data.zip with kph http://rapidshare.com/files/213343272/DATA.ZIP (updated removed the ">" as per Matt's post)
You will also need to put this font file info the same folder as the data.zip http://rapidshare.com/files/213722048/transportm.ttf
Kph Audio Files used in Data.zip http://rapidshare.com/files/213316264/output.rar
Let me know if it works or if I stuffed it up.
Posted Mar 25, 2009 · 12:37 UTC#23
Hi Matt,
Thanks in advance
I've put a new data.zip up (see original post) that includes a new mod to call the find address screen when in route by clicking on the 2nd direction instruction box. I didn't have the room to add a new button but this should work fine.
Posted Mar 25, 2009 · 12:45 UTC#24
GTIMatt's Data.zip with kph http://rapidshare.com/files/213316263/DATA.ZIP
The only thing I would say is I think it will call the wrong speed limit as you're looking for < 30 etc so if it was a 30kph camera it would be the < 40 condition that would fire and tell you it's a 40kph limit. I think for kph you can get rid of the < sign and just have something like this:
	runif %navigation.curr_speedcam.speed_limit.value < 30 'playsound "0_unknown"'
else_runif %navigation.curr_speedcam.speed_limit.value 30  'playsound "0_30kph"'
else_runif %navigation.curr_speedcam.speed_limit.value 40  'playsound "0_40kph"'
else_runif %navigation.curr_speedcam.speed_limit.value 50  'playsound "0_50kph"'
else_runif %navigation.curr_speedcam.speed_limit.value 60  'playsound "0_60kph"'
else_runif %navigation.curr_speedcam.speed_limit.value 70  'playsound "0_70kph"'
else_runif %navigation.curr_speedcam.speed_limit.value 80  'playsound "0_80kph"'
else_runif %navigation.curr_speedcam.speed_limit.value 90  'playsound "0_90kph"'
else_runif %navigation.curr_speedcam.speed_limit.value 100 'playsound "0_100kph"'
else_runif %navigation.curr_speedcam.speed_limit.value 110 'playsound "0_110kph"'
else_run 'playsound "0_unknown"'
The only reason I have the < in my code for mph is because it seems that the %navigation.curr_speedcam.speed_limit.value is in kph even if the camera is set to mph so you have to do a < comparison as no one seems sure exactly what they have stored in kph for the mph limit so the < gives a bit of margin for error (hope that makes sense!) Alternatively you could keep the < in and just increase the values by i.e < 31, < 41, < 51 etc.
Posted Mar 25, 2009 · 13:31 UTC#25
Matt,
Thanks for checking it for me. I just used your script without the ">". I'm learning as I go! Thanks for explaining it to me I understand it much better now. I've uploaded that data.zip http://rapidshare.com/files/213343272/DATA.ZIP and deleted the old one.
Page 1 of 14
