I Got Rid of my Key Beeps!
By Stephanie · Aug 16, 2008in Hacks/Mods💬 83 posts👁️ 38,729 views
Page 1 of 4
Posted Aug 16, 2008 · 21:34 UTC#1
In WinCE mode, on the Flash Drive, there is a directory DATA. Inside data is SOUNDS. There are a handful of wav files in that directory. The following ones seem to be the keybeeps:
PSG1Hi.wav
PSG1Low.wav
PSG2Hi.wav
PSG2Low.wav
There are four other wav files in there too, but those first ones seem to be the key. I simply replaced them all with a wav file of silence - I had a "silence.wav" that I copied over and renamed to each of those files, and then moved those silent wavs into \DATA\SOUNDS
One reboot later, and presto! No more keybeeps! And I'm talking about the AV stuff - I know you can disable them in the GPS program but I *think* this disables them everywhere...
silence.wav.zip
Posted Aug 16, 2008 · 22:06 UTC#2
Good work! Gotta love windows based stuff... makes almost anything possible.
Posted Aug 16, 2008 · 22:47 UTC#3
hifisi, have you tried this? not doubting you stephanie, but just wanna see if all my dreams came true...
Posted Aug 17, 2008 · 00:55 UTC#4
No, I haven't. But I see no reason why replacing the sound files for the beeps with silent/empty sound files with the same file names wouldn't work.
Posted Aug 17, 2008 · 01:02 UTC#5
I made a backup of the original files before trying it. I'd suggest if you want to try it as well Nicky, you make backups too.
Still, the only reason I can think of for this not working would be if these particular files are copied into a few different locations, i.e. a copy for the GPS program, a copy for the AV program, a copy for the Phone / Contacts program... in which case each copy would have to be dealt with. I've not tested the phone/contacts since I replaced the wave files, but I know the GPS key-beeps can be silenced through the settings, and I know that I've silenced the key-beeps in the AV program by doing this. If the phone/contacts still beep, that's just a matter of finding the hidden wav files and dealing with them too.
Posted Aug 18, 2008 · 05:39 UTC#6
nice job I just did it yesterday as well and was going to upload a rar file for everyone to use the silence sounds and just copy it over from an SD card :) but you beat me to posting it :P
Edit:
Stephanie, we really need to find a way to reapply any updates we want that was we can customize a lot more of the interface.... that would be huge if we could do it. I have some ideas on how to force it to update but thats risky and I dont want to brick my new $900 headunit :P
Posted Aug 19, 2008 · 18:43 UTC#7
nice... encourages me a bit to see what other mods we can do to this thing.
Posted Aug 20, 2008 · 14:35 UTC#8
My intense desire to get rid of my key beeps is trumped by my fear of bricking my F90. Although I'm pretty good with installing these units, I'm not sure how to do this mod - would anyone be so kind as to write up a step-by-step tutorial? (After which this thread should be made a sticky - this is one mod these F-series units really need!)
Posted Aug 20, 2008 · 17:31 UTC#9
Step by step instructions.
Please Note: I assume no responsibility if you brick your unit. Following these instructions is at your own risk and peril.
I've made this as straightforward as I can, assuming a limited knowledge of computers, but really, if you don't know at all what you're doing, you probably shouldn't be doing this.
1. Get the testmode files from This Post.
2. Unzip that and copy the Testmode and MiTACAP folders onto an SD card
3. Grab the silence.wav file from the top of this thread
4. Make 4 copies of silence.wav and rename them so you have four files which are all silence, named: PSG1Hi.wav PSG1Low.wav PSG2Hi.wav PSG2Low.wav
5. Copy those files onto the SD card
6. Put the SD card into the Fxxx headunit and turn it on.
7. It will boot to test mode, with some info about copying stuff. Wait a few seconds then tap the X in the top right corner to get rid of that window.
8. You should now have a windows Start button in the lower left corner.
9. Use the Start menu to open windows Explorer. Do this twice so you have two Explorer windows going.
10. On one explorer window, navigate to My Flash Drive, Data, Sounds. You'll see 6 or 7 sound files in there. I *strongly* urge you to back them up.
11. On the other explorer window, navigate to the SD Card and find your four wav files.
12. Tap a wav file, tap the 'Edit' menu, tap 'Copy'.
13. Go back to the other explorer window, tap the 'Edit' menu, tap 'Paste'
14. Repeat for each file.
15. When done, just close the two explorer windows, then turn off the car.
16. Wait a few seconds, remove the SD card, and turn the car back on. Poke around in the AV menus, there should be no more keybeeps.
Posted Aug 20, 2008 · 17:48 UTC#10
Excellent - thanks Stephanie!
Posted Aug 20, 2008 · 17:56 UTC#11
thanks stephanie. i'm going to give this a atry
Posted Aug 21, 2008 · 01:21 UTC#12
Did this mod this evening and silenced my key beeps, but I noticed Voice Command isn't working (get nothing when I push the knob). These sound files don't affect the voice command function, do they?
Posted Aug 21, 2008 · 01:53 UTC#13
They shouldn't - did you just modify the four of them? I've never used voice command myself, so I can't comment on if it's affected things for me or not. I can't think of why they would though, the unit wouldn't even 'know' something has changed.
Posted Aug 21, 2008 · 02:09 UTC#14
Yes, I just modified (replaced) the four specified .wav files in the Sound folder. I don't use the Voice Command much, either; I just noticed that a push on the center button no longer activates it - don't see how anything in the Sound folder would affect that function. I'm happier with those stupid key beeps muted, anyway, so I won't miss the Voice Command. Thanks again for posting the detailed instructions on this mod!
Posted Aug 21, 2008 · 02:13 UTC#15
Are you waiting a little while after bootup to try voice commands? If you do it right away, the system is too bogged down to function correctly.
Posted Aug 21, 2008 · 02:19 UTC#16
Yeah, I've waited quite awhile after bootup...nothing.
Posted Aug 23, 2008 · 03:27 UTC#17
**Update** - Tried the "Restore Factory Settings" (from Top Menu, go to Settings-->Navi System-->Restore Factory Settings) option today and now my Voice Command works again! Have no idea if I did something during the process to get rid of the key beeps that caused Voice Command to quit, but at least it's back. And still no key beeps, so all is well.
Posted Aug 23, 2008 · 05:50 UTC#18
I don't like the factory beeps so I replaced them with less annoying sounds. The silence is nice but I kinda like having some sort of effect. There's plenty of .wav files you can find on the net that make it sound much nicer!
Posted Aug 27, 2008 · 13:28 UTC#19
Why would a hack be required to get rid of the button beeps? theres an option within the nav settings to turn off the beeps for the entire system.
atleast one mine there is
my unit is a F900BT and it has a blue and a white sticker on the box so maybe I have an updated one compared to the first update??
I actually don't mind the beeps, it lets me know the functions are going through when it seems like it might be freezing up
Posted Aug 27, 2008 · 13:32 UTC#20
The system (nav) settings for eliminating the key beeps only covers the nav unit software. It did not silence them in the AV section or other settings screens. At least, this is the case on a North American unit with software 1.017.
Posted Aug 27, 2008 · 22:45 UTC#21
This worked perfectly for me!! Thank you so much! This had been driving me crazy since day 1 with this unit.
Dave
Posted Aug 30, 2008 · 22:27 UTC#22
Thank you! This form is so confusing.... this is cleat and easy for me too do!
Also, does this get rid all the beeps on the main screen!
Posted Aug 31, 2008 · 00:54 UTC#23
This worked perfectly for me and I swear it made the whole thing run smoother with a lot less hanging time!
Great mod!
Posted Aug 31, 2008 · 04:06 UTC#24
what we should be looking for is that option in the settings where it allows you to disable the beeps in the navi... but make it work with the whole unit, it might be possible with the script editing but i think Stephanie needs to have a look
Posted Aug 31, 2008 · 04:14 UTC#25
The navi is basically stand-alone software, it's separate from the rest of the functions. Unfortunately the scripting in the iGo software is unable to affect the rest of the system, as near as I can tell.
Page 1 of 4
