I Got Rid of my Key Beeps!
By Stephanie · Aug 16, 2008in Hacks/Mods💬 83 posts👁️ 38,729 views
Page 3 of 4
Posted Feb 21, 2009 · 02:08 UTC#51
can anyone PLEASE post the original wav files in the data/ sounds folder. i overwrote them when i replaced them with the silence.wav files by accident without backing them up. I would really appreciate it.
thanks
Posted Feb 21, 2009 · 22:47 UTC#52
If you have the 90bt, it can be done without hacking. Just go to your settings, navi settings and sound settings. The beeps are the master volume slider.
Posted Feb 23, 2009 · 03:55 UTC#53
No it can't.
Posted Feb 23, 2009 · 16:10 UTC#54
thanks
http://www.bit4net.com/files/avic/
Posted Feb 23, 2009 · 16:36 UTC#55
No it can't.
Yea it can. If you turn it down low enough with music playing and car running you won't be able to hear them.
Posted Feb 23, 2009 · 16:43 UTC#56
thanks for posting the original wav files and replacing those waves is the way to go. yes some beeps can be turned off but you will still get the beeps from the menu and map button and a few other buttons. replacing the wav files works great.
Posted Feb 23, 2009 · 16:53 UTC#57
No it can't.
That'll affect Navi side, not all the dings that happen elsewhere.
Posted Feb 23, 2009 · 17:57 UTC#58
No it can't.
It does turn the volume down on all parts of the system. Turn the master volume down almost all the way then turn up the navi voice up to compensate. Sounds are still there but very faint. I have not tried to turn the master volume down completely though.
Posted Feb 23, 2009 · 18:22 UTC#59
That's kind of defeating the purpose of having the overall system sound...
Posted Feb 23, 2009 · 18:28 UTC#60
It's a moot argument for me as I've made my own blank sounds. I know it worked when I tried a while ago.
Posted Feb 23, 2009 · 19:38 UTC#61
True...
Still, IMHO killing system sound to get rid of dings is an overkill, when there's a file replacement soliution.
Posted Mar 29, 2009 · 19:07 UTC#62
Step by step instructions.
Please Note: I assume no responsibility if you brick your unit. Following these instructions is at your own risk and peril.
I've made this as straightforward as I can, assuming a limited knowledge of computers, but really, if you don't know at all what you're doing, you probably shouldn't be doing this.
1. Get the testmode files from This Post.
2. Unzip that and copy the Testmode and MiTACAP folders onto an SD card
3. Grab the silence.wav file from the top of this thread
4. Make 4 copies of silence.wav and rename them so you have four files which are all silence, named: PSG1Hi.wav PSG1Low.wav PSG2Hi.wav PSG2Low.wav
5. Copy those files onto the SD card
6. Put the SD card into the Fxxx headunit and turn it on.
7. It will boot to test mode, with some info about copying stuff. Wait a few seconds then tap the X in the top right corner to get rid of that window.
8. You should now have a windows Start button in the lower left corner.
9. Use the Start menu to open windows Explorer. Do this twice so you have two Explorer windows going.
10. On one explorer window, navigate to My Flash Drive, Data, Sounds. You'll see 6 or 7 sound files in there. I *strongly* urge you to back them up.
11. On the other explorer window, navigate to the SD Card and find your four wav files.
12. Tap a wav file, tap the 'Edit' menu, tap 'Copy'.
13. Go back to the other explorer window, tap the 'Edit' menu, tap 'Paste'
14. Repeat for each file.
15. When done, just close the two explorer windows, then turn off the car.
16. Wait a few seconds, remove the SD card, and turn the car back on. Poke around in the AV menus, there should be no more keybeeps.
Has this been tested on Version 2.0?
Posted Mar 30, 2009 · 17:40 UTC#63
Yes, the file system is the same. I would have returned my F700BT if it were not for this fix. Those beeps are ridiculous and indicative of Pioneer's idiocy when designing the F-series.
Posted Apr 06, 2009 · 20:47 UTC#64
With the little helpful HOW TO guide this was SOOOOOO easy. Now if all of the other mods could be as easy! Thanks!!!
Posted Apr 06, 2009 · 21:34 UTC#65
I like the key beeps, just not at ear-splitting levels. I just editted the sounds and lowered volumes to a subtler level. I uploaded the sound files to the FTP
ftp://avic:[email protected]/cmh928
sound.zip and read the soundreadme to know where to put them from testmode.
They are included in my all-in-one file as well.
Posted Apr 18, 2009 · 18:43 UTC#66
:?: I tried to use the 200.5000 firmware update to get rid of the beeps by replacing the specified files with a (renamed) silence.wav but when trying to update the F900 reports '...........IGO/data/audio is wrong'.
Anyone knows how to replace the files with a silence without blocking the firmware update? :?:
Posted Apr 18, 2009 · 22:26 UTC#67
You can't use the updater to load modified files, there's an integrity check in there.
You need to install the update first, then boot into test mode and load your files after that...
Posted Apr 19, 2009 · 17:20 UTC#68
this works awesome it is what i did a long time ago and it makes my steering wheel controls respond faster as well.
Posted Apr 19, 2009 · 17:43 UTC#69
:D Tnx BorisM!
renaming the beep files in Testmode worked!
Gnasr74: it works also in the latest update (I just updated to 200.5000)
Posted Apr 19, 2009 · 19:19 UTC#70
:D Tnx BorisM!
You're welcome!
Posted Apr 21, 2009 · 15:00 UTC#71
CMH, is this an auto-installer? Or do I have to manually copy the zip file over myself?
Posted Jun 06, 2009 · 00:14 UTC#72
Thanks a lot for this easy hack. Even a dummy like me was able to do it and finally that infernal beep is gone for good!! Much appreciated. :D
Hans
Posted Jun 06, 2009 · 13:51 UTC#73
Hi. I've just tried to follow the step-by-step instructions, but when I put in the SD card I get an error message and that's all. I'm in the UK and running the most recent firmware (it's 2.000xxxx). Any help? Those bloody beeps are driving me crazy.
Posted Jun 06, 2009 · 16:18 UTC#74
I really don't know much, but when did you get the error message (is it right after the splashscreen)? If so, it might be a matter of redownloading the testmode.zip onto your SD card and trying again. I did the hack a little different from the OP in that I cut the files and pasted them onto the SD card (they are now on my PC) as opposed to replacing them. So far, so good.
HR
edit: I also have the 2.0 update so that should not be the issue (from previous posters experience, 2.0 or not does not seem to affect this hack at all)
Posted Jun 20, 2009 · 16:29 UTC#75
Thanks OP..!! Follow your instructions and finally got rid of this BEEP!! cheers!
Page 3 of 4
