Adding multiroute to your mods - Tested Successful
By diaftia · Sep 17, 2009in Hacks/Mods💬 36 posts👁️ 4,719 views
Page 1 of 2
Posted Sep 17, 2009 · 17:41 UTC#1
You are going to edit a few files here. Start with getting the zip file attached to this post. In there you will need to copy multidraw_800_480.ui to the ui_pioneer\800_480\ui in your data.zip. Copy multidraw.ui and multicalc.ui to your ui_pioneer\common\ui folder in your data.zip. Copy all of the images to your 800_480 folder.
MultiDraw.rar
Once that is done open main.ui in the 800_480/ui directory and add the following line to the top section:
import "ui_pioneer/800_480/ui/MultiDraw_800_480.ui"
add this to the bottom section:
import "ui_pioneer/common/ui/MultiDraw.ui"
Next open the variable_def.ui file in the common/ui folder and add in the following (I did it just above the line with the *****12.16***** in it):
In the same variable_def.ui file add the following at the bottom of the file under the last variable:
Next open the favorite.ui file in the common/ui folder and add in the following to the section at the top below the vManageMode line:
Next open the browsemap.ui file in the common/ui folder and add the following to the bottom of the file:
Once that is done you need to add in a place to launch it in your NavigateMap_800_480.ui file in the 800_480/ui folder with the following action:
onrelease='nextstate d_StMultiRouteDraw'
Since this feature works when in route you want to make sure you use a visible model when the Navigation has route only for your button. The full code that I used was from my Current Speed Sign in the Diaftia mods:
I am pretty sure that is all the steps.
Posted Sep 17, 2009 · 17:48 UTC#2
WOW!! Again, thanks for the work! I can't wait to get home and give this a try!!!
Posted Sep 17, 2009 · 18:24 UTC#3
Great! Let me know how it works. I didnt QA these directions so if I missed an image or an error happens, and you are sure you followed the directions, let me know.
Posted Sep 17, 2009 · 22:39 UTC#4
Hangs at system starting when I turn the unit on. Does nothing else. I have rechecked the changes 3 times and get the same thing each time I try to turn the unit on.
Posted Sep 18, 2009 · 00:03 UTC#5
Thanks, looked at the files again. Add these in:
Add this at the bottom of the variable_def.ui file:
Also copy the AJG_ico_popup_exit.bmp file from the updated attachment at the top to the 800_480 directory and the multicalc.ui file to the common ui folder..
Posted Sep 18, 2009 · 00:10 UTC#6
Within the header section before or after the ***1.9 area. I dont' think it matters as long as its before the got the updated download now
Posted Sep 18, 2009 · 00:12 UTC#7
You caught me trying to ninja edit. It goes in the main area. Not the header section. Doesnt matter where. I personally put it above the ***1.9 area but it doesn't matter as long as its in the body/main section.
Posted Sep 18, 2009 · 00:14 UTC#8
Here is where I put it --
;*********************1.9**************************
-- Ooops missed multicalc.ui hold on I'll be back
Posted Sep 18, 2009 · 00:34 UTC#9
No go, system startup in progress and sits there
Posted Sep 18, 2009 · 03:45 UTC#10
OK I changed the title of the thread. I will try it on a fresh set of mods tomorrow and work it out. I will put up a new thread.
Posted Sep 18, 2009 · 17:53 UTC#11
I just followed the directions and ran the multidraw in an emulator with no problems. I think you might have placed something incorrectly someplace dpdurst. Let me know if you can find it and I will make sure to clear up the directions if needed.
Is there someone else that can test this as well?
Posted Sep 18, 2009 · 17:57 UTC#12
I'll give it a try tonight. Work gets on the way of all my modding :D
Posted Sep 18, 2009 · 18:41 UTC#13
Trust me... I started a new job this week and its seriously impacting my modification schedule. ;)
Posted Sep 18, 2009 · 19:07 UTC#14
I'll try to look again tonight, otherwise It will have to wait till I get back from Vacation. I checked and rechecked, will do again and see if I didn't miss something.
Posted Sep 18, 2009 · 19:54 UTC#15
Have you tried it in an emulator? I have noticed they are more prone to throwing errors that are correctable.
Posted Sep 18, 2009 · 20:34 UTC#16
where can i get the emulator from?
Posted Sep 19, 2009 · 00:08 UTC#17
Search on it. There are threads on how to set it up.
Posted Sep 19, 2009 · 04:07 UTC#18
The beginning of the directions say to bring 3 files to the common and 800_480 folder but only two are in the download....the Multical is missing. I'll try to find it in your fill mod.
Thanks,
Bryan
Posted Sep 19, 2009 · 05:00 UTC#19
Works!! This is such a cool Mod! The only files I was missing was the multidraw and I was missing ico_popup_exit.bmp and k_but_multiroute.bmp but I found those on you last download. Thanks for the great directions! I have one more questions. I remember reading in someone's mod that they touched the clock to get a screen and held down the clock for a second or two to get to another screen. Your post lists it as:
And I think the hold button mod is something like
onhold='blah blah blah'
Does anyone know the exact way to do that?
Posted Sep 19, 2009 · 13:06 UTC#20
doesnt work I have error : unknown layer referenced Identifier =[ui_multiroute]
Posted Sep 19, 2009 · 21:42 UTC#21
#1 All those files were put in the latest file I put up the other day. They are in there. Can you download the file again and make sure?
#2 onlongclick=
Posted Sep 19, 2009 · 21:43 UTC#22
Sounds like you skipped a step. I think it might be the main.ui step.
Posted Sep 19, 2009 · 22:39 UTC#23
#2 onlongclick=
yup. all there now.
Posted Sep 20, 2009 · 03:58 UTC#24
i followed your directions but for some reason i am getting a failed to ope AJG_ico_popup_exit.bmp and when i checked the file that image was in there. i went over the steps twice dont know what could be causing this.
Posted Sep 20, 2009 · 04:23 UTC#25
If you downloaded the file when I first created this it was not in there. Check to make sure its in your download.
Otherwise, make sure its in the 800_480 directory and not the common directory. From there it we just need to make sure it does not have a $ in front of it in the line in the multidraw_800_480.ui file. Otherwise there are no spaces in the file name or in the config?
Page 1 of 2
