IGO 8.3 complete folder
By timemaster · Sep 22, 2009in Hacks/Mods💬 6 posts👁️ 1,984 views
Posted Sep 22, 2009 · 17:08 UTC#1
Can someone post complete igo 8.3 folder from APL2/Igo.. with hacked ezrider ? I can't find it :( but I need it for 2009.06 EU Maps..
I have 3.003 update from tomolas thread and work's great
F900bt EU
thanks
Posted Sep 23, 2009 · 10:59 UTC#2
Tomola's flash has already Igo8.3
I'm already using 2009.6 maps of europe with it and there's no trouble.
Posted Sep 23, 2009 · 21:53 UTC#3
I finally found it in this thread : viewtopic.php?f=34&t=26795
many thanks to tommern_nor... igo 8.3
But thanks for information, maybe I have some error somewhere :(
You speak about tomola's 3.0003 EU version ?
What's about 3.1 for EU, is here some mirror of dumped "My flashdisk" ?
thanks
Posted Sep 23, 2009 · 22:17 UTC#4
Zelig, what did you have to do to get the 2009.06 maps working with Tomola's flash? I got the Teleatlas map already - will I need to replace EZrider.exe (which I got) and the licence file (which I don't got :wink: ) or, are the ones on Tomola's flash ready for new maps?
Posted Sep 24, 2009 · 07:20 UTC#5
You will need to replace the EZRider if you want to use maps that weren't issued by Pioneer.
You will only need a license replacement if you want to use maps of an area that wasn't already on your AVIC.
i.e. if you only had Western Europe maps issued by Pioneer then you can update all of those without a license file but to add USA or Eastern Europe you will need the license file. If you had Teleatlas map of UK then you can replace it with a newer one without replacement of the license, if you didn't then to use that map you need a license.
Hope this helps
TZ
Posted Sep 24, 2009 · 08:35 UTC#6
Yes, That's the one i use.
Haven't found it yet. If someone has, please shere the information. :wink:
Zelig, what did you have to do to get the 2009.06 maps working with Tomola's flash? I got the Teleatlas map already - will I need to replace EZrider.exe (which I got) and the licence file (which I don't got ) or, are the ones on Tomola's flash ready for new maps?
Yes. you have to use the hacked Ezrider ( the new one for 3.0 firmaware) to make them work. I also added (added, i didn't erase any of the other) the Global licence to it just i case, and all works well.
