willing to pay paypal to someone to help me fix f700bt
By jman930 · Oct 06, 2009in Problems/Troubleshooting💬 3 posts👁️ 717 views
Posted Oct 06, 2009 · 21:43 UTC#1
basically i tried to do the unit reboot fix found here viewtopic.php?f=33&t=23558 and now my unit will not boot past the splash screen and if i press the menue button it shows the start screen but the only thing i can do is go into settings and in settings it says that i dont have a map version or firmware version... i know im deeply screwed so instead of buying a new unit walk me through fixing it and ill pay you for your time...
thanks,
Jon
Posted Oct 06, 2009 · 23:07 UTC#2
thanks,
Jon
have you tried deleting the entirecontent of the flashdisk and loading the hacked version of it, it will take time but i think if you get it working it's pretty much worth it,
Posted Oct 07, 2009 · 00:12 UTC#3
Try downloading and installing the 3.0101 update for the X710bt from the pioneer website. It may fix your issue and if it does not you really have lost nothing but a small amount of time. For what it's worth after I used the official upgrade on my F700BT I had constant reboots (after a few minutes of sitting at the starting up screen) that were a result of the license file not being copied over from the SD cards. I also had no map or software version listed. I manually copied the license file from the SD to the AVIC and I did the 3.0101 upgrade and everything works great now. BTW...my official 3.0 upgrade appeared to run perfectly. No errors from either SD card, 100% completion in about 45 minutes. Hope this helps.
