Stan/Andr2000 v3.0 main screen by dpdurst - update 3/15/10
By dpdurst · Oct 13, 2009in Completed Mods/Themes💬 155 posts👁️ 38,999 views
Page 1 of 7
Posted Oct 13, 2009 · 22:34 UTC#1
Here is the awesome Stanislov/Andr2000 v3.0 setup with a new front end to it. I love the new changes they have done for 3.0, but never liked having the big screen on the left of the main screen when not navigating so as you can see below in the screen shots I have done some modifications. Current screen shots below show non-navigate and navigate mode of operation.
Not sure where its going next... gonna play some XBOX with the wife for a bit.
I'll update the newest Andr2000 as soon as I see if some more updates come out.
Currently uses the Dec 2, 2009 Andr2000 change
3/15/10 update
1. Click and hold the bottom street sign causes screen to black out
2. Click and hold Time during non-navigation toggles date and time
3. Other fixes by Andr2000 for this version
10/29/09 update
1. Next and Current street backgrounds match with transparency
2. Clock moved under speed, new cockpit background
3. Satellite icon upper right corner (sat dish shows status sat dish shows status) when no navigation,
And 2 vertical bars when navigating
4. GPS screen has globe with satellites around it now color of sat wings show status
5. Fixed MPH readout so when using Kilometers it will change to KM/H instead
6. Return to Cockpit button is on the map plan screen left side
A. New ezrider.exe that should now show correct altitude in feet up to 21120 feet
10/21/09 update
1. Added route progress bar when in navigation mode and also will show up same place during simulation mode. Upper right of screen white/black bar and orange icon moves from left to right. To enable go into visual settings and advanced settings toggle on or off
10/19/09 update
1. New icons added for street and next waypoint and also GPS on the screen
2. Top and Bottom for street and next street show more details
3. Street on bottom if to much is on the line it will animate and scroll
4. Added new speedwarn icon that is bigger
5. Freeway signs are now smaller and don't take up so much room. Don't overlap icons on right
10/14/09 update
1. Fixed the issue in navigation mode, clicking on the clock or time under the speed will toggle through 3 settings, current time, eta to destination and ete to destination
2. More alignment fixes in the cockpit detail screen
10/13/09
1. Time format when not navigating moved to top right with new background. This hides when speed cam warning fires off and shows distance instead and also hides when you have a route running.
2. Added GPS screen access by clicking on top right of screen where GPS icon is. This works only when GPS icon is present.
3. Removed big Cockpit on left of screen during non-navigation modes and added small speed and speed limit screen that matches and lines up with main cockpit during navigation mode
4. Added my shortcut icons across top of screen with new icons.
5. Changed icons on right of screen to new picturs
6. Added delete route and new mute speaker icon when route is present
7. Added shortcut to access day and night mode schemes easier.
8. All icons fade out after a few seconds. Compass does not.
9. Clicking on the speed icon still brings up the cockpit mode display and I have positioned the readouts vertically to be more inline with each other.
All schemes and other stuff you can find at the bottom of this post
Download the data.zip here - update 3/15/10 http://www.gpssoftware.us/avic/stan/data.zip
Download the data.zip here that has front end US flag theme - update 10/30/09
Rename the file to data.zip - http://www.gpssoftware.us/avic/stan/data_flag.zip
Download the data.zip here that has front end Cross of St George theme - update 10/30/09
Rename the file to data.zip - http://www.gpssoftware.us/avic/stan/data_cross_st_george.zip
Unzip the sys.zip file and copy to the apl2/igo folder and then copy the new font to the apl2/igo folder
If you running the new Andr2000 3.0 mod then you don't need the below files you already have them. However it won't hurt if you copy over the ones you have or just want to replace them.
Download the sys.txt file - http://www.gpssoftware.us/avic/30/sys.zip
Download font needed with this mod as well - http://www.gpssoftware.us/avic/stan/digital.ttf
To get the sky and such going you need to get the files listed below and have the sys.txt listed above. All the schemes are modified to show solid 3d color buildings if you have the appropriate building files:
Testmode files needed to get into the unit. Unzip and copy the testmode folder to SD card
http://www.gpssoftware.us/avic/30/testmode.zip
1. Hacked EZrider.exe for the 3.0 - update 10/29/09 - Should now show ALT above 1 mile as feet
Unzip and copy the ezrider.exe to the APL2\igo folder
http://www.gpssoftware.us/avic/30/ezrider_alt_mod.zip
2. New GFX folder - 9/30/09, unzip and copy the folder into the main APL2\igo folder -
http://www.gpssoftware.us/avic/30/gfx.zip
3. Tons of new Schemes unzip and select what you want and move to the APL2\igo\content\scheme folder
Updated on 9/17/09 5:50pm, now show textured buildings. Removed 2 that didn't belong, small size now.
http://www.gpssoftware.us/avic/30/scheme.zip
Updated Schemes II and Night Schemes available now 9/29/09 - Download, unzip and copy to your existing scheme folder. Download the new GFX folder update above #3, new schemes II are for all 4 seasons and should have the textured buildings, the new night schemes have new and more clear backgrounds for the following skies: clear, rainy, cloudy, fog
1. Schemes II
http://www.gpssoftware.us/avic/30/scheme2.zip
2. Night Schemes
http://www.gpssoftware.us/avic/30/night_scheme.zip
Posted Oct 14, 2009 · 14:11 UTC#2
nice!
Posted Oct 14, 2009 · 16:52 UTC#3
Hi.Installed this mod but noticed after a while the icon for 3D,2D N Up just vanishes off the screen.Anyone got any ideas please?
Posted Oct 14, 2009 · 17:53 UTC#4
What do you mean vanishes? They dim out but they just don't disappear or at least they haven't just disappear off the screen where I can't push the thing. I have been running this for days with no issue's with icons.
Posted Oct 14, 2009 · 18:13 UTC#5
The icon just completely vanishes off the screen!It was there when I first installed it and then it was gone.I have just reinstalled the data file again and deleted all the save files but it really did just vanish.
Posted Oct 14, 2009 · 18:36 UTC#6
Update.Reinstalled and all appears ok this time.Do you think it was because i overwrote the existing data file instead of deleting it?Is it always good practice to delete the files and that install the new?I really do like this mod,specially how easy it is to see the miles and time to destination.
Posted Oct 14, 2009 · 19:07 UTC#7
I always overwrite the data.zip and never delete first so not sure what happened. Maybe something in flash got corrupted. But specifically that button is stock and never touched so it would be odd that anything in the mod would have caused that issue.
I guess I should have pointed out and I should post that you do need a new font file from the original Andr2000 update for 3.0 but I still don't think that would cause that one icon to disappear.
Posted Oct 14, 2009 · 19:16 UTC#8
Posted the sys.txt file I use as well as the digital.ttf font that would be needed with this mod in case this is the first time your running the new Andr2000 mod. If you already have the mod installed then all you need to do is change the data.zip file for the new changes.
Posted Oct 14, 2009 · 22:21 UTC#9
Updated at 10/14/09 @ 3:15pm
Download from first post.
Posted Oct 15, 2009 · 11:42 UTC#10
To all responsible, Stanislovovich, Andr2000, dpdurst.... - this is some beautiful work. Thank you for all your time and efforts. Cheers!
Posted Oct 17, 2009 · 12:55 UTC#11
This is a good mod.keeps things nice and simple and yet displays all the info you need.I like it a lot. :)
Posted Oct 19, 2009 · 06:20 UTC#12
Update first post to now include the downloads for the Schemes, GFX folder and sys.txt. Also you can get the testmode and ezrider.exe file if you need them from there as well
Posted Oct 19, 2009 · 16:15 UTC#13
10/19/09 update - download from first post.
2. Top and Bottem for street and next street show more details
Posted Oct 19, 2009 · 16:48 UTC#14
Nice one David.Can you tell me if the progress bar is always visible when navigating?Thank you.
Posted Oct 19, 2009 · 17:02 UTC#15
There is no progress bar, I assume you see I had GPS turned off and simulating a route, the bar for that is present to get the picture I wanted.
Posted Oct 19, 2009 · 18:43 UTC#16
I have only had the chance to simulate a route up to now.My Avic is fitted in my RV so i won't be able to road test until the weekend.I noticed that a progress bar was visible during route simulation and had hoped that it would still be there during an actual "live"route. :(
Posted Oct 21, 2009 · 04:48 UTC#17
Updated 10/20/09 -
Added progress bar when in navigation mode. This is on the very upper left of the screen white bar and green icon moves from left to right. This is the only place to put it without cluttering up the screen. I don't have any plans to move it at all.
To enable or disable go into visual settings and then advanced settings and its at the bottom.
Posted Oct 21, 2009 · 07:17 UTC#18
Updated 10/20/09 -
David.Thank you for adding the progress bar,a personal favorite of mine :)
Posted Oct 21, 2009 · 10:37 UTC#19
This is such a great mod. I'm curious, was there ever an option to delete individual addresses on the history menu rather than the entire list? I don't remember which nav unit that I've had recently had that option. It was nice, though. Cheers.
Posted Oct 21, 2009 · 13:52 UTC#20
Updated 10/20/09 -
David.Regarding the progress bar.Should it be visible in route simulation(mine isn't)and should it be on screen as soon as you set a destination?(again,mine isn't)I have set it to ON in the settings/visual/ etc but as yet I haven't seen it on any screen.Any ideas please.
Posted Oct 21, 2009 · 19:14 UTC#21
Updated 10/20/09 -
Look at the top left of the screen in both instances. Its right even with the top line for the background of the next street name. its pretty small. I'm looking to make it bigger but not moving it from that position. Its there.
Posted Oct 21, 2009 · 19:50 UTC#22
OK David Thank You.Bigger would be good :)
Posted Oct 21, 2009 · 20:08 UTC#23
Give me about 15 mins. I am finishing up the change and I think you will have no problem noticing it at the top left of the screen now. Its a white/black checkerboard line with lime green ball that moves across it. It should be visible in both normal route and simulated route. (I have tested both)
Posted Oct 21, 2009 · 20:33 UTC#24
Thanks David,you are a top man.
Posted Oct 21, 2009 · 21:03 UTC#25
All fixed, too much going on, on the left side of the screen to leave it there. I did make it bigger and moved it to the right side above the total distance and GPS status icon. Its pretty easy to see now. I may have to come back later and change the moving icon to orange or something like that but it works now both in navigation and simulation mode. Enjoy
Page 1 of 7
