BMWJ17 said:
I have called three car stereo installation places and they have all said the same thing that the Z-1 would require a "Re-Wire" of my stereo system speakers = "Couple Hundred Bucks". Anyone care to elaborate or have any experience with this? I would be very greatful for any input on this Thanks.
If your car has a head unit in the dash and then an amplifier in the trunk (my 1996 Crown Vic had this) you will need to re-wire your speakers. What happens is that your new Z1 head unit has a built in amplifier in the head unit and it outputs directly to the speakers. This is installed in your dash, but your speakers are run to the trunk (or where ever the amp is) not the dash. The speakers go to the factory amp. And if your head unit is in the dash there is nothing to conenct your head unit to. I would run the speaker wires to the back of the car and into the speaker wires there, as opposed to re-wiring the speakers.
The other possibility is that you have a factory amp, you might be able to use it. If you could get the audio from the head unit to input into the factory amp, that might work too.
Not 100% sure about your particular car, but I would assume that's what they meant. Call Crutchfield and see what they say. Just tell them you were thinking of installing a head unit in a 06 mustang and see if they say anything.
