Ipod Issue
By eXtReMeP4in · Dec 25, 2009in Problems/Troubleshooting💬 32 posts👁️ 5,104 views
Page 1 of 2
Posted Dec 25, 2009 · 05:20 UTC#1
Hey guys, I have noticed that when I use my ipod, only the left side of the my car's speakers work. When I move the sound all the way to the right using the AV sound settings, the volume is uber low and the music sounds distorted. This only occurs with the ipod however as both using cd's and the radio works fine for both sides of my car's speakers. Any ideas what's wrong?
Posted Dec 26, 2009 · 05:55 UTC#2
could it be
a. bad cable from ipod (try another cable)
b. bad output from ipod (either try another ipod, or ipod to another device)
c. (the worst if the other 2 don't tell you whats wrong)..a bad input on head unit
Posted Dec 29, 2009 · 13:40 UTC#3
Check your cables! You will find your problem!
Posted Jan 03, 2010 · 00:05 UTC#4
you're not alone, i just started having this issue myself.
cd audio, as well as AM/FM audio work fine on all speakers of the car, but then when i switch to my iPod, audio output gets shifted to the left side of the car. i feel as though it may be a bad iPod cable, but that's just a guess.
Posted Jan 03, 2010 · 17:06 UTC#5
Does anybody read my posts? You have your right ipod connector going to the wrong input. Check your connections. This is an easy mistake to do as there are several L/R inputs in the back of the harness. Recheck all your connections
Posted Jan 10, 2010 · 06:34 UTC#6
I've seen alot of explanations for this prob, as I had it myself. I took my unit out of the dash a couple of times, twisted the RCA connections and it fixed the prob. Catch is, it will happen again. I have the Pioneer cable going to my Nano. Reluctantly, I finally soldered the RCA connections and it's been working flawlessly ever since. It was a major pain, but worth it. You would think Pioneer would do a better job with their cables.
Posted Aug 02, 2010 · 20:58 UTC#7
In fact, your instructions help nothing.
Posted Aug 03, 2010 · 03:02 UTC#8
Have you verified that it's wired correctly by pulling it out of the dash a 2nd time? or are you just going to stubbornly say "of course I hooked it up right"
There's a reason the regulars ask these questions...
Posted Aug 03, 2010 · 07:48 UTC#9
I'm experienced in buliding car hifis (more than en years), you can be sure I know what I'm talking about. I have an Ipod Classic 6th gen. I works perfectly for a short time, then once the left side fades once the right side.
By the way in the menu of the headunit is an option for aux to choose what kind of source you have connected. "Ipod" has to be set otherwise you hear nothing. If I set to Ipod I can hear music, so it has to be the right input (in fact it is also marked on the cables, the other video input is for reverse cam, the other AV input is in the front of the hu). Also not so difficult to connect the red plug to the red, the white plug to the white).
So this "check your cable inputs" instructions help really nothing.
This is an easy mistake to do as there are several L/R inputs in the back of the harness. No there are no serveral harness, only one that clearly belongs to Ipod. Only one AV input is in the back of the car. I you connect your Ipod to RCA preouts, you won't hear anything.
Here in this forum I got the information that the RCA plugs hace to be resoldered to fix this problem.
Posted Aug 03, 2010 · 11:05 UTC#10
And we're supposed to psychically know this?
With a thread full of "me too"s" with multiple posters barely giving enough information to know they even HAVE an ipod, you have to give the folks that respond a break some times.
abb1 gave good general advice,
Posted Aug 03, 2010 · 12:31 UTC#11
You don't understand me. You cannot connect your to any other plug. This AV input looks like a package. Three RCAs (red, white, yellow) are in a group and marked with a label (AV input). The IPOD cable looks the same (red, white, yellow). The rest of the harness is completely different.
By the way this sentence was interresting: Does anybody read my posts? You have your right ipod connector going to the wrong input. He seems to be sure that he's got the solution and nobody can read the labels on the wiring loom.
- I cannot hear my radio...
- Check if it it is powered on... :)
Posted Aug 03, 2010 · 17:05 UTC#12
You cannot connect your IPOD to any other plug. Sorry.
Posted Aug 03, 2010 · 17:53 UTC#13
and that's in response to what comment? out of context it means nothing, AND it's inaccurate.
one can easily use a different cable and connect an ipod to the front input AV2
one can also connect the ipod cable audio to either the front or rear RCA OUTPUTS if they're not paying attention, they will physically fit, but they won't work correctly.
I count 4 completely different ways to connect an ipod, only 2 of which work, and only one that lets you control it from the AVIC.
Posted Aug 03, 2010 · 19:13 UTC#14
In your 4 completely different ways neither the left nor the right side speakers won't make any noise. The person that opened this topic had working left side speakers. To have any working speaker from IPOD, you have to use the AV1 input. So if he found the clamped set of AV1 and connected the RCA of the left side to it, I'm sure he found the right side, too.
This conversation makes no sense. :lol: Peace.
Posted Sep 09, 2010 · 01:49 UTC#15
I'm having the same problem with mine, but the distortion will vary from left to right. Sometimes it'll be perfectly clear, sometimes slightly bad, sometimes unlistenable. Does the same thing on both my ipod touch and my nano. If I unplug from the ipod and reconnect it it'll work for a varying amount of time. I'm going to guess likely a cable issue, but what do you guys figure?
Posted Sep 09, 2010 · 02:17 UTC#16
I am curious if this is true as to why you needed to ask for help on this forum. Then to make a negative comment to one our valued members that tried to offer you a suggestion you should not have needed from anyone here if you have been doing this for years. The idea that anyone would ask for advice then to completely disregard it makes no sense to me.
Posted Sep 09, 2010 · 09:14 UTC#17
Exactly. The same problem. Sometimes helps if you disconnect the Ipod, sometimes not. For a long time I thought this problem is caused by the Ipod. Now I'm going to rework the cable (maybe the headunit also). I'll give you the information if it helps.
Posted Sep 10, 2010 · 19:58 UTC#18
Look. That was not a negative comment. He asked if anybody does read his suggestions. I gave an answer that his suggestion helps nothing in this case.
You can have 30 years experience, if you meet something strange you may need to ask for help.
I already asked for peace, and tried to to fix up this quarrel. Please...
Posted Sep 10, 2010 · 20:02 UTC#19
So. I had an original Ipod cable. I have disassembled the RCA connectors of it. This is funny. Its quality is terrible. No any soldering, only poor quality pressing.
Posted Sep 10, 2010 · 20:15 UTC#20
Replace it with the Apple Composite AV Cable.
Posted Sep 10, 2010 · 20:54 UTC#21
Might be a good idea. I just soldered new connectors, but new customers should stay away from Pioneer's Ipod cable.
Do you have information if the USB connector of the original ipod cable has full functioning and not only for charging?
Posted Sep 10, 2010 · 21:12 UTC#22
No one said anything about the original cable. It wont work.
Posted Sep 10, 2010 · 21:50 UTC#23
original Ipod cable = original Apple composite cable.
Sorry for composition.
Posted Sep 10, 2010 · 22:04 UTC#24
Thats not the same cable.
Posted Sep 10, 2010 · 22:19 UTC#25
Ok, let's try it again: :lol:
Do you have information if the USB connector of the original Apple composite ipod cable has full functioning and not for charging only? Will it work with the headunit?
Page 1 of 2
