Need Help With Restore
By Granite · Jan 23, 2010in Hacks/Mods💬 7 posts👁️ 1,523 views
Posted Jan 23, 2010 · 21:22 UTC#1
Hi All,
I recently Bought a F7010BT. I wanted to do a 3.0 Upgrade But I Kinda Messed Up.Reflashed the Unit with no backup.
Here is what I have Done to get It Up and Running.
Downloaded the Wince,Testmode 2.3,F700BT Backup From Wiki.
I reflashed the Unit, Ran testmode 2.3 and loaded all the Backup Files but here is the Problem, When I restart the unit after the upload Nothing will come up on the Display unless I press the Map or Menu Button then I can Touch the ok or Source displays but all it will do is beep and nothing else.
Also I noticed when I loaded testmode the only icons that will display properly is the device and the recycle Bin on the main screen, So Am I missing Something that Should be downloaded or Run seperate from the files?
*****Update I got it loaded tonight but the only problem now is the system loading screen will not leave the main screen and it reboots every 4min or so.
Well it is back to the drawing board for me.*****
Posted Jan 24, 2010 · 10:43 UTC#2
I had that problem too..but changed one file and it was back to normal..let me know how it goes too I want update my f series too.
Posted Jan 24, 2010 · 13:06 UTC#3
Sure I will let you know later today.
Posted Jan 25, 2010 · 00:26 UTC#4
No progress yet, I have been trying to get the newest map files with alot of cursing since I do not have the proper download site to load it from.
I found a site late today to get the files downloaded but I will not be able to fix it till probably later this week.
So for now I guess I will have to keep reloading the radio every 5 minutes.
Well it is better than nothing.
Posted Jan 25, 2010 · 00:26 UTC#5
Posted Jan 25, 2010 · 04:57 UTC#6
Check out this thread:
viewtopic.php?f=34&t=25817
I posted the files you may need on Page 15.
Posted Jan 26, 2010 · 22:27 UTC#7
Thank You IT Guy, It is Finally up and Running.
Downloaded the Software and installed it this Morning, Much Faster and Nicer than the 2.0 OS
Thanks Again
