No sound w/ Sirius only
By hazmater · Feb 14, 2010in XM/Sirius/HD Radio and Traffic Receivers💬 6 posts👁️ 3,501 views
Posted Feb 14, 2010 · 22:56 UTC#1
HI - I have the Sirius attachment to my Avic 700 and it has worked fine for 10 months. This morning, all appeared normal but there is no sound, just for the Sirius. All other items with the Avic are working fine. Even the Sirius displays normally, (channel info, signal strength, etc.). Any thoughts? thanks in advance.
Posted Feb 16, 2010 · 18:23 UTC#2
Update - I disconnected the battery for about 30 seconds and then reatteched it. It's allgood now. Must have reset something.
Posted May 26, 2010 · 18:56 UTC#3
Mine just stopped working today so I'm looking for answers. I'll disconnect the battery when I get home and see if that helps.
So sick of this POS radio (D3). My first Sirius reciever died, my backup camera stopped working, my screen freezes when it's cold outside and now this :evil:
Posted Aug 01, 2010 · 02:40 UTC#4
Did disconnecting the battery work for you? I have the same issue. I can see all the information, I just don't get any sound through Sirius. I am just thinking about switching to XM, but I want to make sure there isn't any other issues first.
Posted Oct 11, 2010 · 21:46 UTC#5
I'm having the same issue with Sirius sort of. I installed the cd-sb10 and a scv1 Sirius tuner to my avic z120bt but the volume is very muted with sirius selected. Any other source is fine. If I remove pwr to the scv1 with pwr still on the avic the volume returns to normal but after I turn the car off and return I have the cycle the pwr on the scv1 again. I've tried 2 different scv1 tuners and checked that the ip bus cable is connected properly. Any thoughts?
Posted Nov 11, 2010 · 03:35 UTC#6
Make sure you're using a *Sirius* antenna, and not an XM one. Also, make sure you haven't spliced it in any way, and make sure it's mounted in a place with a clear view of the sky, etc.
Some good advice about antennas in this thread:
http://avic411.com/index.php?/topic/29841-issue-with-xm-receiver-on-pioneer-z120-audio-cuts-out-sometimes/page__p__220832__hl__%2Bsignal+%2Bstrength__fromsearch__1#entry220832
