I just installed an Avic 910 bt in my 05 Tundra and found out about the whole bypass ordeal. I didn't hook up the speed signal, parking break sensor or reverse sensor cause I didn't know the wirning on my truck. The question I have is do I need to hook up any of those and for the bypass is all i need to do is ground the brake sensor wire? Why do you move the mute wire? Any help with knowing what wires to use on the tundra or how to fix the bypass would be apreciated.
Posted Feb 28, 2010 · 17:17 UTC#1
