iPod Not Pause when you switch sources?
By tombonneau · Mar 10, 2010in General💬 17 posts👁️ 3,193 views
Posted Mar 10, 2010 · 15:56 UTC#1
So I just noticed yesterday, I thought the ipod/phone paused when you switched sources, but mine continues to play. Is this just how it works or do I have a defective unit/cable?
Also, it doesn't look like the iPod/phone records play count when played through the Z110. Do other people notice this? Not a huge deal, but I have some useful smart playlists based off of play count which now start to become worthless.
Posted Mar 10, 2010 · 16:26 UTC#2
What IPod and IPhone are you using? What Firmware?
Mine pauses when switching sources when using the CD-IU50V.... with an IPod Touch 64GB 3.1.2 and Iphone 3GS 3.1.2...
Unfortunately, I don't know what play count is....
Posted Mar 10, 2010 · 16:30 UTC#3
Yea thats not normal for it to keep playing when you switch sources. Restore your iPod and re-sync your content. Play count with the unit is not supported.
Posted Mar 10, 2010 · 18:43 UTC#4
mine does this also :(
don't spose you could do a litle step by step please
i know i should RTFM :roll:
Posted Mar 10, 2010 · 20:41 UTC#5
Step by step for what?
Posted Mar 10, 2010 · 21:15 UTC#6
Restore & re-sync the iPod :)
Posted Mar 10, 2010 · 22:20 UTC#7
Plug it in to your computer, open itunes, hit restore, then re-sync your content.
Posted Mar 10, 2010 · 22:20 UTC#8
Here ya go... :mrgreen:
Posted Mar 10, 2010 · 23:44 UTC#9
Using 3.1.3. I guess I'll try to run a restore eventually. Not a huge deal as I usually just listen to one source at a time, but I thought when I tried it earlier it was pausing.
Posted Mar 11, 2010 · 06:27 UTC#10
Thanks for that, when I first got the F10 it used to pause, let's hope this sorts it
Cheers
Paul
Posted May 10, 2012 · 00:52 UTC#11
I realize this is an old thread, but my Z110 (software updated to z130) and iPod classic just started doing this. Before I go through the hassle of resetting my iPod, can anyone above confirm that this worked for them?
Thanks,
-Brett.
Posted May 10, 2012 · 02:02 UTC#12
My source pausing doesn't work on either my Z110BT updated to the Z130BT software or on my new Z140BH. I have a iPod Touch, which at some point has been reset in the last 2 years (that's how long the one system has been in the GTO). It never fixed the issue.
Hell if my iPod is connected and I start the car on XM or FM it starts playing the iPod in the background.
Also my Play Count IS updated. I know this because when I plug into my PC my counts go up and the iPod Touch is ONLY used in the two cars (it exists for that purpose, I use my iPhone as my "regular" iPod).
I can test again to see if the source switching works, but I'm going to say that this is how it is suppose to operate (although I can't get my iPhone 4S to play Bluetooth Audio on either unit, so maybe they just hate me).
Edited May 10, 2012 by LS3 MN6
Posted May 12, 2012 · 01:35 UTC#13
I can say that resetting the iPod has no effect other than to waste an hour+ of my life. I reformatted, copied my music back over, and the "no pause when switching inputs" problem persists. I guess the next step could be doing a factory reset on my head unit but that seems like another big pain.
Any other thoughts?
-Brett.
Posted May 17, 2012 · 01:36 UTC#14
EDIT - This happened to me again, so I came back here to remember what I did. I saw a post later in this thread by IdentityWithheld with a much simpler answer. No reset involved.
FIXED!
Here's what I did:
  • Went through all menus and noted the settings that I had so that I could restore what I wanted after the reset.
  • Disconnect car's battery for 5 minutes
  • Reconnect battery
  • Turn ignition to ACC so Pioneer powers on
  • Hold MODE + "Track <" when splash screen appears
  • Tap reset
Once this was done I had a fully reset Z110 and guess what? Now when I switch from the iPod to another source it once again pauses the iPod! This was driving me nuts, glad I figured it out.
Side note - The timing of when this feature stopped working roughly coincides with a visit to my VW dealer's service department for some recall work. I'm pretty sure they had to disconnect the battery to do this, maybe something got mixed up then?
-Brett.
Edited Apr 11, 2013 by zzoinks
Posted May 17, 2012 · 12:11 UTC#15
I'm too lazy to reset both my units and reprogram all my settings just so the iPod pauses (and probably so my iPhone syncs properly with the Bluetooth audio). Why this didn't work from the factory on mine is beyond me. I just installed my Z140 2 weeks ago.
I'll just pause/un-plug my iPod when I want to switch sources.
Edited May 17, 2012 by LS3 MN6
Posted May 22, 2012 · 17:40 UTC#16
I dont think this problem is that serious, but its very annoying. I've had this problem with DVDs & iPod videos continuing to play after switching sources.
What did I do to remedy the problem?
I noticed that when the rear monitor output is set to a particular source, THAT source will continue to play when the source is changed.
Why is this the case?
Because we all have the luxury of having a dual-zone headunit. The rear monitor output can "Mirror AV", thus, whatever video is playing up front (DVD or iPod/iPhone ONLY) will play in the back. Or you can set the rear source to "DVD", "AV1", or "AV2", and the source will continue to play in the back, no matter what the source is up front.
Keep in mind, only video from the DVD or iPod/iPhone can be shown in the back seat.
hope this helps.
Posted May 23, 2012 · 01:41 UTC#17
IdentityWithheld, you are the man.
Now mine pauses... I had my rear monitor on iPod when I set it to something else the iPod pauses 2 seconds after I switch sources.
