klm42 said:
Thanks for the quick response. Since I'm new to all of this, is there anything specific I should tell my installer to look for
Just don't let them talk you into grounding the parking brake wire all the time. They can connect the parking brake wire correctly, but if you use your emergency brake, then it will ruin the headlight flashing (while the parking brake is on). So either have them connect the parking brake and don't use it or leave it disconnected (but if you leave it disconnected, if you don't flash your lights then you won't have a bunch of functions which are normally reserved for when your parking brake wire is grounded (parking brake is on).
Also some installers think they shouldn't connect the VSS wire for this bypass to work, that's nonsense. If he can hook into it, great, if not, then it cause he can't find it, not cause he wants your flashing trick to work. It can be connected correctly and this will still work.
klm42 said:
should I just have him tie the orange/white lead into the parking light wire no matter what since I'm pretty sure the car doesn't have an illumination wire?
Are you sure? Is your installer sure? A lot of times there is something on the radio wiring harness. As long as the parking light wire you speak of goes to 12V when the lights are on and ground when the lights are off. Some car's wiring might need a relay or something, but any installer, knowing you need 12V with the lights on and ground (or floating) when it's off should be able to figure out something. And when I say ground or floating when the lights are off, it can be just disconnected from 12V when the lights are off, you don't actively have to ground the wire, I believe that there is an internal pull down in the Z1.
klm42 said:
Also, how can I tell if it goes to 12v? Thanks again for all of your help as I just want to make sure the process is done correctly. 8)
You would need a volt meter and/or the wiring diagram of the vehicle. Or knowledge of the car's workings. How can you tell if it's hooked up correctly? There is a "diagnostic" screen which lists the Illumination wire status. It will change when you turn the lights on and off. It will also get dimmer, but that's hard to see in bright daylights.
