really?
I left my torrent program up whole weekend but no seeds at all
maybe i'll try again and leave it all day and all night ![]()
K.J
really?
K.J
Any luck downloading? I'll leave mine up for a while after download. Noticing one other peer on my torrent that needs it as well ![]()
The tracker is screwed up. Not my fault, openbittorrent is apparently having a lot of problems.
Enable DHT, it should help.
Took a look at my settings, and DHT is enabled. I'm using Vuze (Azareus) and it's called Decentralized Tracking. No luck on the DL though. I'll try to troubleshoot it later tonight if the download won't start today. Thanks for your help!
Alright gents I'll see if this can be attributed to anything other than the tracker. Let me hunt down some issues I've thought of and I'll get back to you.
wtf... it just magically began seeding out to SOMEONE... I don't know what to make of this.
WHOEVER USES SBCGLOBAL.NET AND BITTORRENT v7.1, POST IN THIS THREAD AND ENLIGHTEN US ON YOUR SETTINGS.
Edit: Strike that, I'm starting to get more and more peers on this... I don't know wtf is going on but whatever.
yeah i'm seeding to 2 peers right now.
For what it's worth, Vuze didn't seem to want to connect to the tracker properly, just kept querying it. Utorrent likes it (a lot) since I'm seeing 11 seeds and 11 peers with a DL speed of about 500kB/s! Great job all, and thanks for the help. I'll be seeding for at least a week.
Strange... my seedbox runs on uTorrent and I'm still getting tracker errors. DHT connects fine though, that may be what you're seeding through. ![]()
Spot held for massive update on RE project.
I've got good news, and bad.
Short on time, will update this a bit later.
-Technyne
I was using Vuze and couldn't get any seeds but after switched to Utorrent and it worked great and no problem.
so don't use Vuze on this and just use Utorrent, it will work!
K.J
Whatever it takes to get this done. I've already seededuploaded 30 gigs, so I'm guessing there are a lot contributing.
I need someone to seed this, I can't download it because nobody is seeding, please help.
There are seeds, use uTorrent. Vuze/Azureus isn't working for this for some unknown reason.
For some reason, it says that "No connection could be made because the target machine actively refused it." Im using uTorrent too. Anyone know whats wrong?
can someone please seed this!!
Yes - please - someone update with a new torrent and seed so we can all enjoy the update.
thanks
There are 12 seeds, are you using uTorrent?
Well - I tried again this morning, and low and behold - there are 4 seeds @ 100%. Please stay online whilst I grab it!
THANKS !!
I got all of the update to work. Now its just the 2nd part of the bt update wont update on the unit. Im stuck on 3.10
I'm currently out of the country until the middle of this month, when I return to California I will start looking into uploading this to a new tracker. Until then, my seedbox has been turned off to save money on my electric bill while I'm away.
The issues with the tracker I used are starting to become a headache and I feel it'd be easier to manage (and less problematic for our members) if I just found a new tracker to use.
I'll keep you all updated if I am successful. I am also going to reload the OS on my seedbox and right now, that project takes precedence over this torrent so it might take me a week or two before this gets done. Please bear with me.
some one seed please!!!
Thanks! Seeding
Anyone seeding at this time.
How to get the AU version?
Please help to find the Australian version
