PIONEER CNDV-60 Backup Copy
By chad · May 19, 2006in Hacks/Mods💬 29 posts👁️ 10,715 views
Page 1 of 2
Posted May 19, 2006 · 04:13 UTC#1
I want to create a backup copy. I have a Dual Layer Burner and a DVD-R Dual Layer media. I just need to know how to duplicate it
- Charles
Posted May 19, 2006 · 22:31 UTC#2
what i do is using nero i click on copy and backup icon then disk copy
insert the original disk first so it makes a image copy of it once it is done then it will ask you for a blank disk
Posted May 20, 2006 · 05:31 UTC#3
Thats all? No special whatever method?
- Charles
Posted May 20, 2006 · 10:43 UTC#4
nope nothing fancy if you don't have nero you can also use alcohol120
Posted May 31, 2006 · 13:14 UTC#5
see i tried last night 3 diff times, first trying to go from dvd to dvd then ripping it to the computer as a image, then i think from a iso, either way they all errored out at around 5 mins left in burning, if anyone has any ideas they would be apprecieated.
thanks
Posted Jun 05, 2006 · 16:44 UTC#6
Me too. I used the lowest speed 2x and burn the CD but everytime, there will be error when verifying the files
Posted Jun 10, 2006 · 20:02 UTC#7
if you are using nero do a test burn before you actually burn your disc
Posted Jun 12, 2006 · 22:20 UTC#8
I fought this one for a while.
I flashed my firmware on my DVD burner to accept the -R DL discs I was using and it worked fantastic for 2 sets.
Posted Jun 14, 2006 · 21:12 UTC#9
+R DL works too. I just tested it. The +R DL are also a lot easier to get a hold of too.
Posted Jun 20, 2006 · 00:40 UTC#10
i had problems with + DL , which brand did you use , burner too ?
found some -DL's only to discover my burner didn't support it...
Posted Jun 21, 2006 · 15:41 UTC#11
Ritek (Ridata) on both + and -
Drive is a NEc ND-3540
Posted Jun 24, 2006 · 18:52 UTC#12
you gotta have your writer to change the bitsettings to DVD-ROM for proper compatibility
Posted Jun 28, 2006 · 06:14 UTC#13
Basically, this is how I did it
I use DVD Decryptor to create an ISO file. Then use Nero to burn the file at 2x (suprisingly, that is my minimum speed). Selected the Finalized Disc option and burn.
Thats all I think. It seems that the whole idea about burning backup copy of your navigation disc is still unknown! So many people with so many answers and nobody seems to be confident with their answers.
For example, which media works? +R or -R Dual Layer media? Some had used +R and worked. Some used -R and worked while some don't.
- Charles
Posted Jun 29, 2006 · 21:00 UTC#14
- Charles
They problem I've come across is that it starts backing up the disc and the asks for a virgin disc, after a little while it kicks it out saying the disc doesn't have enough space. How large space do I need or do I have el cheapo dvdrs??
Yndio
Posted Jul 05, 2006 · 18:43 UTC#15
Yndio
Did you use a Dual Layer DVD media?
- Charles
Posted Jul 26, 2006 · 03:33 UTC#16
If anyone has the CNDV-60 east.. i will pay for a backup copy of this.. please msg me thanks
Posted Jul 27, 2006 · 14:38 UTC#17
Its actually fairly simple. Check out my post here for more useful information: http://avic411.com/forum/viewtopic.php?p=7817#7817
Use DVD Decryptor if possible for this disc. Its very simple, and will change the booktype for you.
Hope this helps,
Let us know.
Posted Jul 28, 2006 · 00:03 UTC#18
I'm in canada.. if anyone want to have a copy.
i have both disk. East and West.
Posted Jul 28, 2006 · 02:34 UTC#19
I have East & West as well. PM me if you need copies.
Posted Jul 28, 2006 · 19:33 UTC#20
does anybody live in NJ so i can get a copy. I ncan use the burner in my laptop
Posted Jul 30, 2006 · 06:59 UTC#21
I am in the Toronto area and could use a set (or at the least east) as well. Torrents just dont cut it :)
Posted Aug 12, 2006 · 13:32 UTC#22
I am in NYC with the version 60 dvds. Let me know if someone needs a copy. All I ask is for the cost of the dual layer dvds, or just swap me 2 blank dual layer dvds for the copies i give you :)
Posted Aug 12, 2006 · 17:39 UTC#23
I am in Toronto and I finally got copies if anyone around the area needs a set =]
Posted Aug 13, 2006 · 19:00 UTC#24
I need a set of the CNDV-60mp to upgrade my N1... i'm located in NJ... i'll trade you with blank ddvd...
Posted Aug 20, 2006 · 21:53 UTC#25
I'm in South Jersey...Deptford. I do need a copy of the East. I will gladly reimburse you for the help. Let me know how we can hook up to do this...
Page 1 of 2
