Abb's Chrome Nav Mod 'All-in-One' V4.0
*First off, I would like to thank and give credit to these Modders, who without, given their knowledge and contributions to these forums, a lot of these mods, mine included, would not exist. These Modders are 'IDT, Diaftia, N-S-E-W, BorisM, MrBlue, and 34X151'
New features from V3.25:
• New Chrome theme (Main/AV) with many graphical improvements included in download to match Nav mod.
• Latest 'Warning screen removal' is included
• The Trip Computer has been redesigned and the scripting has been changed to make the Trip Computer more reliable
• New backup feature to backup your entire 'My Flash Disk'. A 2GB SD card is required for this operation
• AV is now permanent in this mod as it is redesigned for visual appeal. This can still be hidden by clicking on the 'AV Hide' button which is now located on the top header bar beside the phone icon. AV will automatically be hidden during simulation and reappear when simulation is complete.
• A shortcut has been added to the Applications Menu to access the 'Control Panel' without going into 'TestMode'
• A shortcut has been created in the 'Extras Menu' to view 'speedlogs'. This can now be viewed to determine the entire speed in 5 sec intervals (can be changed) for any trip or route.
• A shortcut has been added to the 'Route Menu' to add any route to Favorites. This was achieved before by only going through several submenus.
• 'Time to Turn' info was added to 'Splitscreen Map'
• Many Graphical improvements
• File sizes were reduced to allow smooth operation of mod with new features. File size is now 19.1 mb
• New GFX folder and new schemes folder with a few new schemes that I have created.
• New 'all-in-one' has NEW chrome theme with graphical improvements and Carvers latest 'no nag' fix.
Screen Shots
ON ROUTE
NO ROUTE W/ NEW AV
MAIN MENU
NEW ROUTE MENU
NEW APPLICATIONS MENU WITH NEW FEATURES
EXTRA'S MENU
SPLITNAV
NEW REDESIGNED TRIPMETER
SPEEDOMETER
DIGI DIAL
DEST DIAL
NEW MAIN SCREEN
IPOD
SIRIUS
Installation Instructions!
THIS MOD IS FOR FIRMWARE V3 AND LATER ONLY!!!
Extract all of the folders/files from the .rar file you downloaded, onto a freshly formatted SD card with a testmode folder. You only need to deal with 4 different folders on your AVIC and they are labeled on the folders themselves that the files are in within the zip once extracted.
Also make sure you have a full back up of your FLASHDISK. Really, you are going to edit a lot of files here and it will be nice to go back if you want/need to.
Once the SD card is inserted into your AVIC, power it on and boot into testmode:
1. Click Start - Programs, Explorer then click on SD Card
2. Click on Start Again - Programs - Explorer then click on My FlashDisk - you should now have 2 Explorer folders open in the quick start menu at the bottom of your windows screen.
3.Using the SD card window click on the folder called 'put ALL CONTENTS IN 'MyFlashDisk' folder'. Move the 'System' folder found inside into 'MyFlashDisk' along side APL, APL2, etc..
4.Using the SD card window click on the folder called 'put ALL CONTENTS in 'MyFlashDisk-APL' Folder'. Move ' CommonLib.dll', 'Image.res', 'MainMenu.exe', and 'SystemSetting.exe' into the APL folder
5. Using the SD card window click on the folder called 'put ALL CONTENTS in 'MyFlashDisk-APL2-IGO' Folder'.
6. Scroll your pointer over the 8 files titled "bnt.ttf", "DATA.zip", “BULLPEN3D.ttfâ€, “Digital.ttfâ€, "DS-DIGI.TTF", "TAHOMA.TTF", "TAHOMABD.TTF" and "sys.txt", as well as the 2 folders, "3DCars' and "Extension" to select them all. If you are running an F500, or are using a unit in the EU, then edit the semicolons at the top of the sys.txt file before copying them over to the AVIC.
7. Go up to EDIT at the top window click COPY
8. Go to the FLASHDISK explorer window at the bottom of the screen and open it
9. Navigate to APL2-iGo
10. Click EDIT at the top window and PASTE all 8 files and both folders
11. When the prompt comes up asking you if you want to change files click the option that says "YES ALL" wait for it to copy files (because you made that backup right?)
12. You need to delete the user files so that your settings are built fresh with these new mods. They are in “My Flash Disk\User\UserData". Delete the ENTIRE "iGo" .
13. Power off your ignition to turn the AVIC off.
14. Pop out your SD CARD and then power back on to restart AVIC. DO NOT REMOVE THE SD CARD WITHOUT TURNING OFF YOUR AVIC FIRST!!!
NEW SCHEMES - Instructions
-Install my GFX folder (after it has been extracted) to 'MyFlashDisk/APL2/IGO' folder. Afterwards it should look like this:
'MyFlashDisk/APL2/IGO/GFX'
-Install my schemes into 'MyFlashDisk/APL2/IGO/CONTENT/SCHEMES' folder. Once it is installed, you should be able to open up the CONTENT folder and see all my schemes along with 'Pioneer_blue_day.zip' scheme
*YOU NEED MY GFX FOLDER FOR THE SCHEMES TO WORK
**If this is too complicated for you, DO NOT TRY THIS!
*To install the NEW GFX folder, delete the present one first and then add the new one! THIS IS A MUST!
Donations
I have NEVER asked for donations EVER, but a lot of forum members are encouraging me to take them as a way to receive thanks in the form of 'Beer Money'. I have agreed to take donations as a form of appreciation for all this hard work. Any donations will be greatly appreciated, but they are by no means mandatory. Donations can be accepted by using PayPal and forwarding payment to [email protected]
DOWNLOADS
