Chuck88's Mod v3.4b with Pioneer FW 4.0 and Primo 2.0 - Updated 2013-04-13
By Chuck88 · Nov 09, 2010in Completed Mods/Themes💬 851 posts👁️ 212,464 views
Page 23 of 35
Posted Oct 07, 2011 · 14:06 UTC#551
I have installed it over 3.0210 and it works super !!
Some of the option i realy like are within reach :-)
1 question , is there a way to switch from speedo meter to your currently using source (eg cd or usb) and back ?
I use the meter a lot but to get there is no fun :-)
Sorry but I don't understand your question. :(
Posted Oct 07, 2011 · 14:19 UTC#552
Wel i use the speedometer alot , but i also change my songs :-)
When i select another album or whatever i need to go back to the map and click on the km meter (or miles :-)) to get back to it ,
how can i place a button on the menu or nav screen to go there directly ?
Posted Oct 07, 2011 · 15:25 UTC#553
Are you using Primo v1.2 or iGo8 MOD v3.4?
Posted Oct 07, 2011 · 15:31 UTC#554
igo8 mod 3.4
your latest ,
Posted Oct 07, 2011 · 18:01 UTC#555
igo8 mod 3.4
your latest ,
Sorry but given the lack of time in my life :mrgreen: , I don't intent to continue to mod, hope that you'll learn that yourself to modify the UI script files, you will see, it is not that hard. Or else hopefully some other forum members can lend a hand to you.
Edited Oct 07, 2011 by Chuck88
Posted Oct 07, 2011 · 19:33 UTC#556
Hi Chuck.Is there an easy way to switch between Primo and Igo?Do you know if it possible to install the IGO favorites file onto the Primo so that your favorites are available through the Primo mod.Many thanks Chuck.
I tried to link the Primo's favorites, ect to iGo8 but it screwed up iGo8 and reset all default values. You could try copying some of the files with the same name from USER\UserData\iGo\SAVE to Primo\SAVE; however I am not sure that Primo and iGo8 use the same file for favorites.
Posted Oct 07, 2011 · 19:36 UTC#557
Great release Chuck thanks! Don't start talking all that retirement and getting back to my life nonsense, we need you here! :-P
Posted Oct 07, 2011 · 20:33 UTC#558
Ovalball, you know how to go from iGo to Primo, and to switch back to iGo, you can use Primo's tool to scan external program and you will find an item called "CwGoIgo8.exe": just click on it to go back to iGo.
However by doing so, all the hard keys will no longer be mapped to iGo after iGo started, just like the same issue with Primo because it has to be linked by MainMenu.exe in order to communicate together (during initial loading).
Maybe ryar will do us some magics and make the connection!
Posted Oct 07, 2011 · 20:37 UTC#559
Long enough here for me, even my two kids are starting to ask me why I'm always in this forum, and "chat" with people that I don't know ... not a good example for them, especially I deny their accesses to such forums! :mrgreen:
I will be wandering around though, but one thing for sure: to support Primo, you're the star now!!! :D
And if you don't mind, I suggest keeping all the discussions here from now on, so we can make all info available within one single place. :wub:
Posted Oct 07, 2011 · 20:39 UTC#560
You guys don't forget to download the TTS PRO package from ryar's original thread. You can then clean it to have only the language of your choice in order to save disk space.
Posted Oct 07, 2011 · 23:35 UTC#561
I would prefer it if Primo discussion stays in the Primo thread. There will be future updates provided there are new developments, and there are users using other mods with Primo.
Posted Oct 08, 2011 · 00:32 UTC#562
Agreed!
Posted Oct 08, 2011 · 10:13 UTC#563
Ryar,thanks for your reply.I hope you can find time to continue to explore further improvements with Primo as I have found it to be a very exciting package.Perhaps Chuck will get bored and start to work his magic with mods to Primo?I know how time just flies when you start getting involved with mods,upgrades etc,but when the forum appeared to grind to a halt a couple of months back I really did miss itî˜So thanks Ryar for giving this place a new lease of life,long may it continue.
Posted Oct 08, 2011 · 14:08 UTC#564
Adam,
Looks like most people are comfortable with YELLOW ...
I'm sorry but I don't have lot of time. If you know a bit how to edit the UI files under "\My Flash Disk\APL2\iGo\DATA.zip\ui_pioneer\800_480\ui\*.ui", change all occurrences of "color=#f8cc28" to "color=#ff0000" to switch all YELLOW to RED.
If you want to do it selectively, you may want to look at navigate_800_480.ui and chuck88_800_480.ui.
You can use WinRAR to open DATA.zip and edit within WinRAR, then save back to DATA.zip when prompted.
Good luck!
Adam,
If you can be more specific to what text items you are referring to,I will have a go at changing them for you.
Edited Oct 08, 2011 by ovalball
Posted Oct 09, 2011 · 04:12 UTC#565
Adam,
ovalball,
Adam was talking about "I need to ask You if one change can be made to Your mod - the info in top left corner ("coming turn arrow icon" and "distance left to the turn") and maybe streets names at the bottom of the street - could those be changed to RED COLOUR - when driving, especially at evening and night, that original orange colour is very hard to see ?".
Glad that you have elected to help those in need and welcome to the club! :-P
Posted Oct 09, 2011 · 07:45 UTC#566
Always happy to help anyone if I can,but unfortunately my knowledge is very limited.I can just about change text sizes,colours etc but I know that is only scratching the surface.I am just so glad the forum is ticking along again,I missed my fix of 411 when things ground to a halt.
Posted Oct 09, 2011 · 12:28 UTC#567
In the map when you click the Km (right top corner) you get the digi speedometer.
How can i create a button in the main menu for that ?
If someone can explain me how to do that i can figure the rest out ( i think)
Posted Oct 09, 2011 · 13:25 UTC#568
It is not possible to have a link in the main menu because the main menu is not part of the navigation software. Someone has to hack the MainMenu.exe so it is very unlikely you'll get help on that.
Posted Oct 09, 2011 · 13:31 UTC#569
And in the start screen from navigation ?
instead of favorites ?
Posted Oct 09, 2011 · 13:38 UTC#570
Please post a photo of your "Start Screen". I don't know which one did you mean.
Posted Oct 09, 2011 · 15:00 UTC#571
Adam,
Good luck!
I am willing to try to do that - would you be kind enough to post more detailed description how to do that... And once again - Thank You for the job done.
Posted Oct 09, 2011 · 15:22 UTC#572
Adam, take a photo of the MAP screen and let me know exactly which fields you would like to change from Yellow to Red.
Posted Oct 09, 2011 · 17:55 UTC#573
Chuck
Will you be able to post on the forum the steps required to make the changes Adam has requested please?I am slowly getting there but would appreciate any help in how to changecos ours and/or size of things like next turn arrows etc.I can change the size of text,co ours of text but am struggling where to find the bitmaps?for the next turn graphics.The more we can do the less we will pester youî–Thank you.
Posted Oct 09, 2011 · 19:46 UTC#574
The first screen you see when a 900bt is started, where you can choose between source , telephone end navigation.
when i hit navigation there i want the button fo the speed meter .
Posted Oct 10, 2011 · 01:26 UTC#575
MoNo_eGo, Extract the attached UI file with folder structure to "\My Flash Disk\APL2\iGo" and you're good to go, not perfectly polished but it is OK for your usage, I think.
Ovalball, check on the changed UI file when comparing to the released one in v3.4 to see the single change at the end of the file. Just want to tell you that there is no easy and straight forward way to mod, you have to get used to it and have a good text editor to start with, then use your imagination to find stuff within existing UI file, then derive (or guess) out the associate BMP file.
Let's continue ...
For the above change, first I open all UI files under ui_pioneer\800_480\ui into the editor and search for all occurrences of "Destination Menu"; there are many .... pick the "right" one (!!!), then you can see one is under the state called "<state st_AdvMenu_UC>" within start.ui, and this state use layer "<uselayer ui_AdvMenuMsnd/>", then you search for layer "ui_AdvMenuMsnd", you will find the layer definition "<layer ui_AdvMenuMsnd z=30>" under the file start_800_480.ui, so you can embed "<BUTTON xxx bmp="CW_icon_speedometer.bmp#2" x=700 y=2 z=10 onrelease='NEXTSTATE st_DigiSpidometr'>" at the beginning of the layer definition for the SpeedoMeter access.
Once you get used of it, you'll be able to change anything you want.
This is the same for color: you have to search for the name of the label, possible names for time, speed, etc, then see what is in it etc.
I'm doing that all the time, and sometime it is frustrating, because there are so much code that are left-over from so many modders, and lot of them are not used! I didn't and can't finish filtering out all the unused code, still at the present time.
If you can ask specific question, I will find time to answer you without problem my friend. But I'm not ready to write a HOW TO for this matter at this time, other than lack of free time, simply because I don't know where to start.
ui_pioneer.zip
Edited Oct 10, 2011 by Chuck88
Page 23 of 35
