Hi all,
Who knows where to find the CNDV-1000HD European Maps on the net? I searched and searched with no results! Alot of peopel are offering the maps on Ebay, but I think there is an Acronis image to download.
Thank you for your help
Hi all,
Hi Travolta,
I just bought a new HDD from "vaernes" (member here), on ebay. It works perfect with 1000HD Europe maps 2010.... ![]()
Hi looking for some pictures CND1000HD europe map, you can copy the DVD to see if he wants to share some fellow qeu I have a 60Gig hard drive with no password needed qeu CNDV900HD
thanks greetings
thanks greetings
Not understanding what you want!!!!
@kriis
Can you make a new image from your HDD and share it? This will be great.
Regards
Does anyone have an image of partition with maps of Europe 2010 for the AVIC-HD3???
how can i contact this guy,he is not answering my email,
any idea
thanks
Is this Europe or Russia ??
I look and I tell you
These are Russian maps.
I have those in Europe who wants to PM.
I guess no one has the Europe maps then.......These are Russian maps.
edit - maybe Jaloga has them
I have the Europe, I respond PM
Thank you,
any idea
thanks
Are you talking about me?
I have no messages from you. Must be someone else then.
I am also looking for the CNVD-1000HD upgrade for a Avic-HD3 system.
Could anyone assist - I am new to this sort of thing.
How can I get the update - a few points on how to install....
Appreciate any help you could provide
thanks
look at your private messages, I will help
Hi, I am also looking to update my Avic HD3 with the 2010 maps and software for European maps. Any help with obtaining the update and instructions on how to apply it would be most appreciated. How can I tell from the unit which maps are loaded at this time? Thanks.
Does anybody knows where we can download the EUROPE version for HD3 image?
Hope somebody has posted anywhere.
thanks..
I've found very easy and safe method to update the maps in HD3 device! You can read about it on Toyota's forums.
You need only to substitute 2 files: region.kwi and alldata.kwi. I've used the files from 110MT update (2012) and IT REALLY WORKS!!! Everything is fine with my avic after replacing the files.
Please note there's not enough space at the partition to copy these files, but you are allowed to delete "MAP" folder from the ones named 0A to 15.
UPDATE: it's almost all OK with the navi except for road descriptions not displayed on the blue background located on top and bottom of LCD. Does anybody have an idea how to fix it?
Hellow,
Can you tell me the link where you can see this, there are many forums toyota.
Thank you
please check this for instance:
http://us.lexusownersclub.com/forums/topic/49418-nav-system-usa-to-europe-conversion/
hello,
First, thank you for the information and that after all this time, you still have localized or you've searched the links.
Can you explain how you have maps installed a 110Mt in the HD3? I just found the installation disk but not the maps already installed. I guess if i burn the DVD will not let me install on the HD3 and BE ABLE to change the 2 files you mention.
a greeting
can you explain how you did, please?
you need to copy those 2 files from main folder of 110MT maps to /00 folder onto your Avic HDD and replace them. You need also to delete folders 01-16 since there's not enough space, but first you have to unlock HDD and attach it to your computer in order to execute required operations. I suppose you know how to do it.
hello
I tried it and it works. I've done on the basis of an ISO of Russia and when I try to set a path, leaving me alone Russian addresses. If I set a route directly on the map, browse perfectly but of course, is the problem of this upgrade method, set the path.
I think the solution is to change another file but do not know which. I will do tests with other maps (USA). If I get something, notice.
Sorry for my English. I speak only Spanish and translate with google.
