x920bt TestMode Work
By leandromartini · Nov 19, 2010in Hacks/Mods💬 29 posts👁️ 12,653 views
Page 1 of 2
Posted Nov 20, 2010 · 00:07 UTC#2
can anyone confirm this ???
Posted Nov 20, 2010 · 02:13 UTC#4
Ok it does appear this is totally legit and I have tested the file myself on the 120 and it does give file access. Unfortunately we have had this access to the file system of these units before and it still has not yielded a way to mod the software of the units. This member has claimed however that someone from Brazil was able to use this file to install Brazilian maps to his unit which up until this point at least was not possible. Stay tuned. :smile:
Posted Nov 21, 2010 · 00:20 UTC#5
Leandro, quando descobrir como faz pra alterar os mapas me avisa cara.. to corrento atrás de uma forma.. to louco pra comprar um Z120! Se quiser ajuda pra descobrir, posso te ajudar. só não tenho como testar aqui mais posso tentar te ajudar com a questão dos mapas.. qualquer coisa me manda uma msg privada que conversamos melhor.. Abraço!
In English:D
Leandro, tell me when you figure out a way to install brazilian maps. I'm crazy about this unit but with no GPS there are much cheaper solutions. Send me a private message if you need any help figuring out a way to alter the maps. We are all here to help you!
VBLUE, you have tested this on the z120? Can you confirm it works?
Posted Nov 21, 2010 · 00:52 UTC#6
Another waytTo enter X920BT testmode:
Turn Power On
While holding home button press: rew, fast, rew, fast, rew, fast (or fast, rew, fast, rew, fast, rew, can't remember right now which one is first).
Screen will go black, so release the home button and wait.
Posted Nov 21, 2010 · 02:53 UTC#7
Yes it does. :grin:
Posted Nov 21, 2010 · 03:36 UTC#8
Yes it does. :grin:
so given this is a software bypass possible now ???
Posted Nov 21, 2010 · 03:38 UTC#9
Well if you read what I wrote above the answer is no. This file does not allow us to mod the unit.
Posted Nov 23, 2010 · 18:33 UTC#10
Hmmm.....
Posted Nov 24, 2010 · 14:58 UTC#11
So, is there a way to install foreign maps on this unit?
Posted Nov 25, 2010 · 01:21 UTC#12
Apparently there is someone that has claimed to have done it but that person doesn't want to share the info so until there is definitive proof the answer to your question will remain no.
Posted Nov 25, 2010 · 05:35 UTC#13
Thanks for your reply. If I find a way of doing it I will definitely share it!
Posted Dec 10, 2010 · 04:13 UTC#14
Yes, you are in test mode, however, you are not in a windows environment like you are with WinCE that is found in the F series, or the X910. Therefore, you will not be able to change any files......ever! The advantage to not having a windows OS, is that it does not go through the booting process that windows CE does, therefore, it starts up much quicker and is more responsive. However, not being able to change the appearance, features, or newer maps is a poor trade off :(, one that I will never do.
Posted Dec 10, 2010 · 05:38 UTC#15
So currently, for the ones that needs foreign maps (Brazil in my case) the way to go is the X910BT, isn't it? Today I ALMOST bought the X920BT... It was on my cart... in the last page... And with some more research I've found the threads here that document the hacking is not possible... I was wondering that it could be done soon... but it seams it won't right?
Does anyone know about a coupon/discount/rebate for the AVIC-X910BT?
Cheers...
Posted Dec 10, 2010 · 16:07 UTC#16
Cheers...
Go with the X910! It is moddable and you will be able to update your maps as they come out, so you will ALWAYS have a system with the latest maps. Lol, my X910 has newer maps than the Z120 and the X920. After three years, these systems will be obsolete because of the maps and the X910 will still be up to date :)
Because of the OS, you will NOT be able to hack the X920 like you can the X910 or the F series.......EVER!
Edited Dec 10, 2010 by abb1
Posted Dec 10, 2010 · 19:33 UTC#17
Thx abb1. I will follow your recommendation and get the X910BT. How long does it take to boot? And here at the forum we should have threads already discussing how to add maps, change voices, etc right? (I will start searching...).
And last but not least, is there a way I could change the system language to Portuguese?
Cheers...
Posted Dec 11, 2010 · 18:35 UTC#18
Cheers...
It doesnt take long to boot. I start my car and then it depends on how long it takes to get a GPS signal. In general, it takes about 15 seconds for everything to, but then again, it all depends on your GPS signal. I dont know too much about the system languages. Everything about modding you will find in the F-series Hacks/Mods forum as the X series and the F series are the same (except the X920) as it comes to mods.
Posted Dec 12, 2010 · 07:12 UTC#19
Im working on a software bypass. First time doing something like this wish me luck!
Posted Dec 12, 2010 · 10:03 UTC#20
i found the function that checks for the Parkbreak its in the File "HMIManager.exe"
the function is called ?GetPBrakeStatus, I also found the Variable that stores the value for this function and edited it to 1. I used and hex editor and patched HMIManager.exe. I totally want to try this but i bought my Deck in Canada. so i don't think it'll work for me. patching this unit seems simple enough.
Edited Dec 12, 2010 by jazzzjackrabbit
Posted Dec 12, 2010 · 15:50 UTC#21
Hi jazzzjackrabbit, good you're trying and I wish you all the luck... :-) You've said "patching this unit seems simple enough"... That's a strong phrase... So, do you think u will be able to hack it soon?
And a question about X910BT... Does it displays the album art from MP3 files, reading ID3 tag? And does it accept ID3 v2?
Cheers...
Posted Dec 12, 2010 · 22:26 UTC#22
Cheers...
im working on it.. give me a couple of hours..
Posted Dec 13, 2010 · 00:49 UTC#23
So I patched the file a couple of times and it made the unit think the Park break was off, even tho the park break was ON, ya its pretty disappointing i wanted it to do the opposite. so it isnt as simple as a thought. but keep in mind im a total noobie at this. Ill keep on trying and and update you if i get anywhere.
Posted Dec 13, 2010 · 12:48 UTC#24
Well, at least there is someone trying to get it done... :-) Don't give up! :-D
*Note: Does anyone know if X910BT can display album art for MP3 files? And which version of ID3 tag does it support?
Regards,
Posted Dec 16, 2010 · 21:36 UTC#25
With regards to album art, it can display art if you use an ipod/iphone but no album art is displayed for USB/SD cards.
Page 1 of 2
