I applied the 3.01 update found Here and installed the 2010 maps. When I pair my DroidX running Froyo 2.2 the above error message alerts about Tel.exe. I've tried replacing that file with one from another software version with no results.
I've tried to delete the pairing and start over. After I enter the PIN and it connects then it requests phonebook access from my Android. That's when the AVIC crashes and reboots. Is there another file associated with this pairing/phonebook process other than Tel.exe that should be replaced? How can this problem be present since I just did a fresh format, install WINCE, and copied over the fresh Flash Disk files?
Thanks for the help ![]()
