avic z3 wiring
By tlyons68 · Feb 07, 2011in General💬 6 posts👁️ 2,746 views
Posted Feb 07, 2011 · 04:25 UTC#1
i bought a used avic z3 and need to know what i will need to get it working should there be 3 wiring harness that should of come with unit ? i only recieved 2 with this unit one goes to power supply and other goes to connector 1 but there is nothing in the connector 2 slot is this missing ? if so what do i need to buy for this part # would be great
Posted Feb 07, 2011 · 13:35 UTC#2
Wiring harness for RCA Connector 2 is pioneer part # CDE8084.
It's used for the "2 wire bypass", Rear view camera, back seat monitor output, and wired remote input.
parts.pioneerelectronics.com or ebay.
Posted Feb 08, 2011 · 16:20 UTC#3
Did your stock sirius antenna from your dodge ram plug i to the avic?also would the stock one from dodge work with the xm modual?
I have a 09ram and was wondering if this will work
Posted Feb 08, 2011 · 18:05 UTC#4
I had to remove the plastic clip from the stock antenna (it will disassemble without breaking), then it plugged directly into the Pioneer XM module.
Posted Feb 08, 2011 · 20:25 UTC#5
What kind of mods did you ha e to do to make the avic fit
