F900BT FULL EW BACKUP !!!
By vitormvieira · Feb 07, 2011in Problems/Troubleshooting💬 71 posts👁️ 62,935 views
Page 1 of 3
Posted Feb 07, 2011 · 19:43 UTC#1
Dear All,
This is my first post but it's going to be VERY IMPORTANT for those, like me, that had a bricked F900BT. My AVIC, after a couple of months working very well, stopped working: Starting up and a few seconds shutting down permanently...
I've spent hours reading here at AVIC411 and in other sites, getting more and more confused. I've got an backup image here ( without maps ) and my device worked and rebooted every 3 minutes...
The following procedure was partially got from an italian forum ( pioneernavgate.blogfree.net )but again, besides the italian language ( even with the aid of a online tranlator ), it was a little bit messy. The way i got my AVIC working was a lot more simple :
HERE IS WHAT YOU NEED:
- Testmode v 2.3 ( you can find it here at AVIC411 )
- a first 2Gb SD card ( formmated in FAT 32 )
- a second 2 Gb SD Card ( formmated in FAT 32 )
- Download this: http://www.megaupload.com/?d=3YBUDX0P and after downloading it rename it to "avic f900_700_500 ver_3.000300.rar"
http://www.megaupload.com/?d=CAK7C9HA and after downloading it rename it to "avic f900_700_500 ver_3.000301.rar"
http://www.megaupload.com/?d=RAGYEFBX and after downloading it rename it to "avic f900_700_500 ver_3.000302.rar"
( IMPORTANT: disregard what the downloaded files say: part1, 2...just do what i've written above )
- Extract the 3 to a single folder.
- This folder will say " My Flash Disk". Copy this folder to the first SD Card.
- Copy "testmode" folder into the first SD card as well.
- Insert SD Card to the F900BT SD Slot and then turn the car key on. The "testmode" will allow you to access Windows CE of your device. With this you can start exploring it.
- At Windows you should go to "Start" - > "Settings" - > "Control Panel" -> " Storage Settings ". Here you' ll see the disk structure of your device. You should Dismount "DSK1" and then click on "NEW" and name it "My Flash Disk". With this procedure, your previous " My Flash Disk" is clean ( I've done this because before that i couldn't erase all the files in it ).
- Copy all files inside first SD Card's folder "My Flash Disk" to your device "My Flash Disk". This will take a while ( 15 or more minutes ) so, probably, your car engine should be running.
- After all files are successfully copied, remove SD Card from your device SD slot and shut your car engine.
At this moment, your device still doesn't work.
- Download Pioneer's new firmware for this model here hXXp://213.244.172.244/files/support/avic_apl_upgrade/AVIC-F700900/09%20model/AVIC_F700BT_F900BT_CNSD100FM_VER_3020200.zip and extract it to your second SD Card.
- With the car key turned off, insert this second SD to your device SD Slot.
- Turn the key on ( this will take 10 or more minutes ), probably starting the engine and keep it running.
- The device will be updated automatically. DON'T TURN THE CAR KEY !!! Let the Update proceed itself to the end. This will look sometimes that is stalled but let it run. The F900BT will reboot itself and, after a minute or so, IT'S READY !!!!
THIS WORKED WITH MINE :D ! I DON'T TAKE ANY RESPONSABILITY FOR ANY DAMAGE THAT MIGHT OCCUR IN YOURS ! :|
ENJOY!
Edited Feb 07, 2011 by vitormvieira
Posted Feb 10, 2011 · 12:02 UTC#2
Fantastic, I am so chuffed! I have tried 4 different downloads without success, but this one works brilliantly! Thank you very much.
Posted Feb 10, 2011 · 18:56 UTC#3
You're welcome! :smile:
Posted Feb 13, 2011 · 15:08 UTC#4
I was super excited.... then I realized it was for Western Europe. :sad:
Posted Feb 14, 2011 · 13:42 UTC#5
Dear All,
ENJOY!
Hey man,i have a f700 unit from the USA.I live in Europe and so i thought i might give it a try and just follow your instruction.It all went ok but at the firmware update,it says "incorrect software is on sd/usb".So what do you suggest i would do next!?Thanks
Posted Feb 17, 2011 · 19:44 UTC#6
Is it absolutely necessary to have two different SD cards? All I have is one 4GB card and I'd rather not go out and buy a new one if I don't need to...especially since I'm not 100% certain that this will solve my problem.
Posted Feb 26, 2011 · 19:33 UTC#7
Hi,
You can use just one SD card. The idea for using 2 was for preventing any mistakes...
Posted Mar 01, 2011 · 20:17 UTC#8
is there a solution for that problem, for CANADA unit ? i can't believe that Pionner didnt made a recall for this problem... -.-
Posted Mar 06, 2011 · 03:30 UTC#9
i have a us f900bt and i followed the steps exactly except for giving the new partition a name, shouldn't matter, and when i run the pioneer update it says file checking... incorrect software in sd/usb and stays at 0%
edit: i just realized this is for the European version not US/Canada. that was the issue, same procedure with US files worked great. thank you
Edited Mar 06, 2011 by ws6nightcat
Posted Mar 14, 2011 · 18:58 UTC#10
I've had the same problem, the system was starting up. About 10 sec after starting up the system, it shuts down. It won't start up again. Finally after hours of suffering and searching over the internet, I found this MAJOR help !!!
I had some problems to convert the download from above, but within 2 hours my system works again !! Also my lay-out from the roadmap is changed. Perhaps this is done by the update from the fireware that Pioneer gave availible...
Anyway this was a great help for me !! Thank you !!
Cheers
Paul
Posted Mar 29, 2011 · 20:16 UTC#11
woow thank u you rescued the life of my f900bt i was trying to bay a new model,now new look and more modes is possible,it works perfect for me,i went from version 2...to 3....but i need new maps and speed came for Europe,any one can help on this and thank u
Posted Apr 02, 2011 · 18:19 UTC#12
Thankyou very much! worked spot on!
Posted Apr 21, 2011 · 22:27 UTC#13
Did you use a different source for the files or this Euro link. I got an error msg trying the 3.0 but 2.007 wanted to update. I was going to copy all the other (US) files from a backup, but was concerned that the .007 update would cause problems..
Edited Apr 21, 2011 by whalepirot
Posted Apr 23, 2011 · 12:28 UTC#14
Tried this and the system now boots but "system startup in progress" stays on screen and I can't access any of the map features. Any ideas? I'm using a mac if that makes any difference?
Posted Apr 27, 2011 · 22:04 UTC#15
Where did you get the US files?
Nick
Posted May 03, 2011 · 15:22 UTC#16
Nice!!
Posted May 15, 2011 · 23:40 UTC#17
where are the U.S files for the second SD card
Posted May 16, 2011 · 18:50 UTC#18
Hi
followed everything you said, on eu f700bt.
on extraction got the following messages
! C:\Robert\Downloads\avic f900_700_500 ver_3.000303.rar: The required volume is absent
! C:\Robert\Downloads\avic f900_700_500 ver_3.000302.rar: CRC failed in My Flash Disk\APL2\iGo\CONTENT\MAP\Italy.fbl. The file is corrupt
ignored that...
deleted everything in my flash (kept saying wasnt possible to make new my flash
ignored that...
got to upload then it was a red screen saying "wrong s/w" or something similar.
so, i'll try again - any ideas (want to go on hols next week but 8 hrs in the car w/o radio will lead to divorce):)
Posted May 16, 2011 · 21:16 UTC#19
err less errors when i rename as you said :oops:
Posted May 17, 2011 · 15:20 UTC#20
so now got problem with update screen.
red background
says:
apl:3.000300 => 3.020200
data: 2.000100 => -.--------
map: 02.000200 => -.--------
ceimage: 6.1.7.0 => 6.2.2.8
file checking....
0%
[incorrect software is in SD/USB]
Question: do I need to wait longer or am i in trouble?
Posted May 17, 2011 · 22:29 UTC#21
Nick
@ws6nightcat: PLEASE PLEASE PLEASE tell us where you got the US files? I've tried a full format and reinstall with 2.06, 2.08 and 3.0 all with no success. My unit still starts up and hangs at the splash screen. I need to have the full factory file setup so I can get it back working. Then I can update the firmware again.
Posted May 31, 2011 · 20:38 UTC#22
Dear All,
ENJOY!
Posted May 31, 2011 · 20:52 UTC#23
hi all UK user
I had a nightmare with my unit after having it for over a year, one evening after driving home and starting my van next day my unit wont start fully , keeps rebooting over and over i spent an entire night reading and one whole day trouble shooting till i stumbled on and tried the instructions and downloads that vitormvieira, posted on 07 February 2011 - 08:43 PM, and the firmware i downloaded from pioneer uk website : http://www.pioneer.eu/uk/support/software/AVIC-F900BT/index.html#download_1
File name : AVIC_F700BT_F900BT_CNSD100FM_VER_3020200.zip and hooray its up and running as fast lewis Hamilton , Maps perfect, new look and everything is looking all new
Thanks to vitormvieira
big thanks
Posted Jun 01, 2011 · 10:07 UTC#24
Dear vitormvieira
I cannot honestly thank you enough for your post, i was having the reboot problem and was at my wits end, i followed your instructions and i have now got my AVIC F900BT back to normal and with a better update and maps
again thank you so very much
Posted Jul 03, 2011 · 09:06 UTC#25
I just tried this method and I get stuck here:
- At Windows you should go to "Start" - > "Settings" - > "Control Panel" -> " Storage Settings ". Here you' ll see the disk structure of your device. You should Dismount "DSK1" and then click on "NEW" and name it "My Flash Disk". with This procedure, your previous " My Flash Disk" is clean ( I've done This because before that i couldn't erase all the files in it ).
I'm in the Storage (Manager) and I'm able to dismount the DSK1. If I then click on New and enter the name My Flash Disk and press enter it says it cant create the folder. Since I'm not able to create a folder it doesn't feel safe to even try and delete the currect one. Am I missing something here?
Page 1 of 3
