Z1 install 2003 F-150 Super Crew
By js117 · Jan 11, 2007in General💬 21 posts👁️ 3,138 views
Posted Jan 11, 2007 · 00:27 UTC#1
Am still waiting for this to come in and already have all of the components, Sirius, bluetooth, iPod but no Z1 and I already read about the unfortunate issues. Just looking for any information or help for installing this HU. Never instaled a NAV unit before and wonder if I need the double DIN install kit from Pioneer and what aftermarket harness is best. Thanks for any help
Posted Jan 11, 2007 · 03:54 UTC#2
It's a pretty easy install, the only slightly tricky part is mounting the unit. The 99-5805 metra kit will help you a bit as far as making it sit where it needs to. The harness for the truck is 70-1771. Your vss wire is gray/black in the secondary harness pictured in this post.
http://avic411.com/forum/viewtopic.php? ... highlight=
Reverse is black/pink in the drivers kick panel.
Have fun and happy installing.
Posted Jan 11, 2007 · 19:22 UTC#3
Thanks for the info although the imagshack photos do not come up. Also would it be the Metra kit 99-5804 because there is no 99-5805? Hopefully I actually get my Z1 before next christmas since I already have the extra components!
Posted Jan 12, 2007 · 23:04 UTC#5
Crap, I already orderd the 5804, oh well I will just sell on Ebay and order the right one. Still no ETA for arrival on my Z1 anyway so I have nothing but time. Hopefully the powersellersnyc.com site pans out that was on a previous link because I can't wait much longer from my current seller.
Posted Feb 03, 2007 · 22:30 UTC#6
Well I finally got it (Z1), the last one on Ebay where a seller actually physically had it in his possession. Anyway it is not installed yet but I did mount the iPod and Sirius in the center console where the factory CD changer would be (pictures to come). This seems to be a pretty good location since it is not visible and there is plenty of room. Now the GPS antenna I read does NOT need to be in view but can be hidden away correct? Also for the Sirius antenna does anyone have any recomendations for the placement. My current portable unit I just run through the sun roof but I hate that thing scrathcing my paint. Any suggestions on where and how to install this out of sight or at least off of my paint? I appreciate any help or links anybody has for me.
Thank You
Posted Feb 04, 2007 · 04:35 UTC#7
Most people here just put it on the dash with good results. If you do decide to put it on the outside of the truck, grab some 3m double sided tape. That's what I use to prevent the antenna from scratching the paint to hell.
Posted Feb 05, 2007 · 03:49 UTC#8
I stuck mine in my dash. At the very top, over the heating vent. There is only one layer of plastic (and a windshield) over it and it seems to work fine.
Posted Feb 10, 2007 · 19:00 UTC#9
I have almost everything wired up except the parking brake wire and the reverse sensor wire. Does anyone know where these are in my truck? I tried powering up my Z1 but got nothing so I am assuming it is because of that parking brake sensor wire not being connected. Also the Z1 doesn't fit in the slot which obviously means I need to cut somewhere, top or bottom, any suggestions since the climate control is near the bottom? You guy's have been great so far and I appreciate any more help/advice. Thanks
Oh yeah, any suggestions for the rear view camera? I can't find a nice spot anywhere that fits.
Posted Feb 11, 2007 · 20:16 UTC#10
Anyone? Just a bone so I can finish my install and post some pictures.
Posted Feb 12, 2007 · 15:19 UTC#11
What to cut, I don't remember been a long time. If the avic isn't powering up, then you have a blown fuse in the truck. It should power up even with those wires not connected.
Reverse is black/pink in the driver's kick harness to the rear. Parking brake I don't remember, it's the only wire coming of the the parking brake switch though.
Posted Feb 12, 2007 · 19:28 UTC#12
Do you know where the parking brake switch may be located?, Would it also be in the kick panel? As for the power issue the factory unit powers right up no problems but the Z1 does not. I just tried this again, ALL of the color coded wires are matched up, I used the metra kit and the fuse is still good. Please do not tell me the worse :shock:
Posted Feb 12, 2007 · 19:31 UTC#13
Check the pins in the metra harness. I've seen those get bent. The parking brake switch is at the rear of the parking brake assmembly.
Posted Feb 12, 2007 · 20:50 UTC#14
all of the pins are fine, I also checked the power and I am showing I have contant and ACC working properly. I did not use the ground on the harness, would that matter? I just wired the stock ground as shown on the metra kit. I tried plugging in the Z1 again and it still does not power up, it should do this automatically correct?
Posted Feb 12, 2007 · 21:16 UTC#15
Yes it should. You mean you didn't connect the ground from the z1 to anything, or you didn't use the ground in the metra harness. You have power and switched at the z1 harness.
Posted Feb 12, 2007 · 21:45 UTC#16
I did not connect the ground from the metra harness yet. I connected all of the other wires in the harness that apply. I do have power to the harness when I checked so it should be sending juice to the Z1.
Posted Feb 12, 2007 · 21:51 UTC#17
Ok is the ground wire of the z1 connected to anything?
Posted Feb 12, 2007 · 23:06 UTC#18
Yes, now it is, I had a bad ground so I extended it to a place on the truck I had a good connection. From the Great Carlos Mencia I was a Dee Dee Dee on this one. After I grounded it I was able to power it right up, yet I still can't find that parking brake assembly wire. One last question, will I have to now engage my parking/emergency brake every time I want to set the Nav, this seems like a pain.
Posted Feb 12, 2007 · 23:09 UTC#19
Yeah pretty much. You're other option would be to do the bypass. Depending on the manufacture date of the z1 will tell which method you use. go here for the bypass info.
www.sminntech.com/z1flash.html
Posted Feb 12, 2007 · 23:58 UTC#20
December 2006 model, also that link wasn't working. Thank You for all of your help
Posted Feb 13, 2007 · 00:37 UTC#21
sorry forgot the extension. Link works now.
