Condi's HACKMODE v2.2 - AUTOINSTALL! working also with F40BT, X940BT etc! [updated: 27.09.2012]
By condiczek · Apr 25, 2011in Hacks/Mods💬 1,207 posts👁️ 757,721 views
Page 18 of 49
Posted Jul 12, 2011 · 18:38 UTC#426
I've made already that kind of entrance into hackmode, but it was not working correctly.
SleepMessage is only delayed message, without possibility to make condition like yes/no etc.
We've got also thing like ChoiceDefault, and it would run pioneer soft by default for example after 3s,
but it was displayed ugly for me ;) question window - like for now - much better i think.
And yes - no news for now. Anybody here can correctly replace .dll .exe files in wince img?
Especially .exe .dll files in modules? If yes - we would modify EU090RGD.PRG and it could work..
Condi Check this http://www.pfaadtsoft.de/keybd.htm and http://www.pfaadtsoft.de/bootloader.htm and http://www.pfaadtsoft.de/flashupdate.htm
there a lot of tools in this site, can u adapt to run into our CE version?
maybe a light at end of tunnel!! akakakaka
bye
Posted Jul 12, 2011 · 18:41 UTC#427
Hi Guys ,
I need backup files of the unit 920bt Europe version , I f anybody have please post here link , thank you
Ciro i make a Full dump of my nand2 , its come with USA maps, it can help u??
Translate:
Ciro copiei a pasta nand2 pro sd, esta com os mapas do USA , Serve pra vc??
Posted Jul 12, 2011 · 18:44 UTC#428
Some Body know any software to use iphone with Windows Ce , from Usb or Bluetooth? i wanna try use my Iphone as a USB modem , or a VNC software to Wince ...
i wanna use my iphone like the New Pioneer APP RADIO ..
Posted Jul 12, 2011 · 20:37 UTC#429
Hey guys hows things comming along! I have stumbled upon this link that has alot of apps for Win CE devices.
Auto App Mart Has anybody looked into this? And if this was posted before, sorry missed it.
There are alot of apps/programs that could be useful.
My bad!!
Most of the stuff is for XP, MeeGo, Linux-CE. Nice stuff though, makes me wish I had my Viliv N5 back from getting repaired!
Edited Jul 12, 2011 by TMill
Posted Jul 12, 2011 · 21:09 UTC#430
Another question? Will Mio Pocket 4.0 intergrate with this Win CE 5.0 sys on our HU?
Mio Pocket 4.0
Mio Pocket has a nice set-up and works with GPS/Win CE devices well from what I have read.
Posted Jul 13, 2011 · 00:30 UTC#431
Hi Guys ,
What happen? so suddenly you disappeared, It looks like you got into troubles...
Posted Jul 13, 2011 · 02:13 UTC#432
read first post here: http://4pda.ru/forum...howtopic=231161
Our default Navigation software is not IGO.
So we need replace navi program first.
Igo runs on our units in hackmode but it can't find GPS port.
Thanks for the help but I can't open this page. What do you suggest I could use as navi system that it manages to find the gps port. I really need the advice.
Posted Jul 13, 2011 · 02:56 UTC#433
Sorry it is wrong link...
Please read 1-st post on 1-st page here. It shows current state of this hack. It shoud ansver all your questions.
Edited Jul 13, 2011 by Ralpharn
Posted Jul 13, 2011 · 12:32 UTC#434
Sorry, I'm new to all of this modding. Does this mean I'd possible be able to edit the registry and mod my x920bt to automatically rebuild the iPod VR dictionary every time? That's my biggest complaint about the stereo.
Thanks.
Posted Jul 14, 2011 · 00:07 UTC#435
Hey Using a Hex Editor i Open the UC090SND.ENU and UC090TTS.ENU, The First have a Lot of .Wav Files Inside and the second look like a Index to this file, to separate files just cut the header until the next and past at new file
HEADER START AT RIFF4 ..WAVEfmt ........"V..\+........ù.fact....>?..data.
AT the end of Second File (index) have the words correspnding to each wav
Maybe we can translate the wave or simply use new voices , like homer simpsons , or Snoppy Dogg hehehe
The Menu (AV.EXE) Language files at \USER\PRG0\Apl\LANGDATA\StringData\EUPTPTP.LNG
i will try Change with a Hex editor to Portuguese From Brazil
DHHUUUUU
Posted Jul 14, 2011 · 13:25 UTC#436
I'm going on vacation - last week of July. After that I will gonna replace my EU090RGD.PRG, we will continue all the hackmode thing :)
Before that - I can't be without gps/audio etc ;)
PS. last night I was dreaming that we had a full solution for gps port LOL :D
Edited Jul 14, 2011 by condiczek
Posted Jul 16, 2011 · 00:26 UTC#437
Hey Guys , I need help
My unit avic 920bt have loop , restart all time and don't enter more in mode test , file key don't work more , I did test laguage and when change for french sistem have error and restart and now don't stop restart , please help me thank you !
Posted Jul 16, 2011 · 14:51 UTC#438
@ciroalbano - Try getting into test mode manually and return everything back to stock like so: remove sd card, turn on ignition, keep home button pressed and press previous, next, previous, next and so on while keeping home button pressed until the unit restarts, it should enter testmode now.
Posted Jul 18, 2011 · 14:04 UTC#439
good job condi, you are in the way
Posted Jul 18, 2011 · 17:18 UTC#440
Condi and all
at Menu Settings / AV-Settings there are two buttons regarding Mute of the AV-Source (when f.e. a phone call comes in).
At my F30BT I can select different Mute-Scenarios (left button) but can not select different Mute Levels (All/-10db/-20dB) on the rigth button. AV-Source is ON and button is active, but Mute Levels are not displayed in the button.
Have you ever seen that on a Navi with hackmode?
Originally it worked correctly!
Thanks for your suggestions
Bernd
Edited Jul 18, 2011 by Bernd
Posted Jul 18, 2011 · 17:36 UTC#441
Condi and all
Bernd
hmm got f30bt, and also cant change mute level.. more interesting thing is that with original files it also cant be changed hmm.. check it with your backup files, maybe my copy is modified in some way already..
Posted Jul 19, 2011 · 14:11 UTC#442
Please forgive my ignorance but what can you do with the hackmode?
I have an AVIC-F920BT does this let you install the CNSD-210FM Update or have I got the wrong end of the stick?
Posted Jul 19, 2011 · 23:15 UTC#443
Just to confirm... Right now one of the problems related to running homebrew executables, is that any of them linked to coredll.dll or ceshell.dll will not work?
Posted Jul 19, 2011 · 23:43 UTC#444
It seems like it has US map update. so if you have non-US model it is not for you.
Posted Jul 20, 2011 · 19:05 UTC#445
That's not a problem, almost every app which i modified to use other dlls than limited in our devices - worked without any problems. Its problem, but its easy to bypass. I've got all the gps software running fine like tomtom, garmin, automapa, igo etc. But its just a software. We have problem with busy hardware, like gps port and audio. We need to get free gps port, and other hardware resources.
Me and all the great guys here - we just gave opportunity to further hack avics. All the working utilities such as DiskRW, working registry etc. - this is for all of you to test and try to get some useful result ;)
Edited Jul 20, 2011 by condiczek
Posted Jul 21, 2011 · 00:13 UTC#446
My reason was because I have a Z130, and would rather write a UI replacement and make it open source for people to use. Mainly because I believe MioPocket is not open, so you are limited to the scripting and if it crashes, you are out of luck. Hopefully, this way we can also take advantage of the android protocols (communicating to CE) as well as some of the open source apps that work great and would be excellent for the head unit.
Has anyone gotten a kernel debugger running to pick up any loose RETAILMSG or DEBUGMSG (in case pioneer left any debug code in there)? Many drivers tend to spit initialization messages out. I spent quite a bit of time doing kernel and user mode debugging in windows (both regular flavor and CE) so thats why I'm asking. There may be a decent chance that a dependency is being triggered by the app tying up the port.
The fact that this uses WinCE 5 to me is very promising because the dev time is stupid fast.
I haven't dug into the bin, but do you know if they have the DX stack running, or are using native frame buffer calls?
Edited Jul 21, 2011 by Anonnie
Posted Jul 21, 2011 · 06:15 UTC#447
Condi, did you try to install portsplitter for GPS receiver? Maybe Sygic will find the gps port if igo doesn't.
Posted Jul 21, 2011 · 13:38 UTC#448
Sounds to me like you might be able to help us get past the next barrier with your experience with WINCE. Condi has made it possible to run other GPS software but cannot gain access to the GPS Port. It seems to me that we need to replace the contents of EU090PLT.PRG (platform?), EU090RGD.PRG (registry?) and EU090BOT.PRG (boot?) in order to have a fully functioning WINCE running in order to run any program and/or modify the skin.
Posted Jul 21, 2011 · 14:17 UTC#449
If I could get a stack dump, I can do a rundown on each of the PIDs and their associated TIDs to see what is tied up in the context. From there we'll know the exact process and thread that is holding any of the ports open, alter the loading order and allow ourselves to load the dependencies to tie it up.
Understand that I just picked one of these up a few days ago, so I'm not as familiar as others with the hardware. If it has a serial port (that we can tap) we can try to enable kernel debugging and from there the sky is the limit. I can do pretty much anything with it and trap every Psxxx Load, or at least the opens to objects that are not in the FS path.
I'm thinking the ND-TMC10 tuner may have a serial port as its back communication due to the slow speed of the data on the FM sideband. That could at least give us a point to push a remote debugger connection. Anyone know which com port thats tied to?
On a side note, admins might want to link this to the "Z" section of the forums as I would have never found this if I hadn't been snooping around all of the sections of the forums to learn things, since this particular thread is not exclusive to the "F" series of the HU.
Posted Jul 21, 2011 · 14:26 UTC#450
Back up with testmode and then load up Condi's Hackmode! He has provided some tools that will run on the unit (some you may need to download in this thread) but I don't know if any of them can do a stack dump, perhaps you can figure that out once you begin digging around.
Page 18 of 49
