hi man,
thanks for your work!!
i wanna help and test in my Z110bt updated to z120bt with Shortfuse crack
can u send the files to me?
hi man,
It was sooooo stupid... I had to "apply parking brake"... %)) so now I have all settings active.
Nice to hear that it wasn't related with HACKMODE ![]()
hi man,
No problem, link with files is in the first post in this topic,
also with 'how to' instructions
Post here, let me know if it works
on your device!
br
condi
on your device!
br
condi
Thanks, i have made a backup and now i going to my car and delete the av.exe file and replace with yours,,,
but how u solve the 30 seconds time limit? why we can change the navi.exe for a igo.exe and use the stand UI to get igo? have u tried?
sorry my english, im from Brazil.
in the future i hope use a USB MODEM to google for some strip club from my Z120bt hahahahahaha
Has someone found the map files yet?
Good News the hack work to my z110bt upgraded to z120bt, but i have some problems,
1 - i only can back to original Interface puting back my original AV.exe - maybe a version problem i will post my original av.exe
2 - i can´t test close the file manager because my touchscreen isnt properly calibrated?
3 - my unit restart randomly when i use the file manager, but get stable in Igo 8
4 - u try use the control panel from Windows ce, it opens , but when i click to open some shortcut nothin happens
5 - I would like try put the original explorer by windows ce and try get to desktop and start menu. Does some anybody have the missing explorer files?
6 - The Igo runs well , but i cant get the gps port , when i look in the windows folder i found a app named gps...something. maybe it turn gps on???
thanks again Ptk
You know you can upload zip files to the site, right?
i try upload but the site give-me a error!!
Error The server returned an error during upload.
give me a e-mail and i send to u
Ooops, fixed, and I attached it to the first post.
Ok the file is up! thks
thanks again Ptk
1) you dont have PRG1 directory in your system? if yes then try attached modified test version (with your Av.exe), let me know if it works,
2) its hard to hit the close button, try with pen or stylus, if not - then search for the calibration of touchscreen (calibration - was it in pioneers service menu?)
3) i've got to look into it - maybe its concerned in total commander app... or... maybe not ![]()
4-6) yes same in my unit, will look into it.
Also If you could upload your system backup, or at least write directory structure,
like: NAND/PRG0/Apl/; NAND/PRG1/Apl; NAND2.., NAND/Apl etc.
Where is what
this should help me to customize script for your unit ![]()
---edit: attachment deleted (not working)
Hopefully we can use this to fix the new XM logos.
How can I help with that? Just write ![]()
Where is what
hi man,
i have prg0 and prg1 but ....
i search in win ce structure today and try put the explorer.exe into windows folder, not work , win ce is read only, maybe a win ce image stored in \PRG0\Apl\MENU\image.img , but i cant decompress or see inside,
I solved the calibration in testmode monitor test function.
about restart i change u scrip to run FileManCE and no more restarts ( at least i hope)
i will try your new file now, see u later!
all files is about 45mb give a e-mail to send files!
thnks again
I can't seem to find where the XM logos are stored.
\NDATA\NDATA\AV\XMLPS and \NDATA\NDATA\AV\XMDPS ?
hi man,
thnks again
No way.... i test the new script and av1.exe not work, but at this time the screen goes blank.
the av.exe size in the prg0 ang prg1 are different
i check the win ce folder, there are a lot of missing files!
can u make a script to put all missing files into correct folders at start time? maybe overwrite all files in rom at start and run a full CE?
i have no sound working im my Windows CE , but radio still working.
about the randomly restart if i start any program after comander no more problem, but if only commander is running there problem again!
Ahah! Yep, you're right, I somehow looked over them.
Logo directories if anyone else wants them:
Hmm Z130BT copy ![]()
Is this means that you tested HACKMODE on this model?
I think that I know why you have problems to jump into normal software.
It can be caused by z110-to-z120 upgrade. I think that your PRG1 is from
old firmware. You should try to:
1) make another copy of your backup PRG0 directory,
2) rename unmodified copy of PRG0 to PRG1,
3) delete PRG1 from the avic,
4) copy prepared PRG1 to avic (should be with same content as PRG0),
5) delete from PRG0 Av1.exe, Av.mscr, and copy the old HACKMODE files.
Please post the results.
Br
Condi
Hmm Z130BT copy
Sorta, a Z110/Z120 upgraded to Z130 software.
Does it work with F310BT/U310BT ?
Hmm Z130BT copy
Br
Condi
Done
i delete all files into pr1 folder
a copy all pr0 into , its work!!
you are right , maybe my pr1 files are z110bt orignal files! Good Work again!
Now we need focus in get a better way to alternate into original pioneer and Windows ce
and get a fully function Windows.
Does anyone succeed to copy Windows folder from device memory? I can't... Look like copy operation blocked.
I have the z110 upgraded to the z120. I deleted av.exe from prg0 and copied in your files but when i stick in the sd with the hackmode.key it wont boot into hackmode just normal mode. radio still works just like it supposed to but no hackmode. Does it have something to do with the fact i have prg0 and prg1? Help me get this thing hacked!
Nope i try too and get same
are u using Hackfile from condi´s first post? or hack_test from another post
I have the some unit upgraded and i folow the instructions and works , my only problem ,has solved after, is returm to normal mode, try confirm the size of av.exe in pr0 = 8k and if u have all files in prg0 folder, the files on prg0 and prg1 are the same before the hack??
